flahernando Samba Member
Posted: Thu Sep 02, 2010 12:55 pm Post subject: Splice a ps |
The power steering pipe on my 85 is leaking right at the bend that goes under the van near the rear axle. I was wondering if this pipe can be spliced say with copper tubing and compression couplers.
I dont know what pressure is involved in the high side of the power steering but figure if I can use compression fittings then I could just do both lines and be done with it.
I cant afford a new set of pipes and this is not a restoration but it is a daily driver and I wouldnt mind having power steering. It has a brand new rack complete with ends and I was told the pump works but the lines leak.
Any ideas? |
andy syncro-nutz Samba Member
Joined: August 22, 2010 Posts: 539 Location: Upper Ottawa Valley
Posted: Thu Sep 02, 2010 1:09 pm Post subject: |
Thanks for the input but---
What safety. It is running and driving now but there in no fluid in the lines and the pump has no belt. It is basically manual steering now and isnt a problem. I just figured if I can get by I would like to hook up the power steering.
I have to get by on a small disability income so $225 is a bunch and would take better than a year to save up. Thats why I am wondering if the compression fittings will work. If they fail the worst that can happen is back to manual steering.
I didnt want to waste the fluid and parts-labor if this has been tried and will not work. I am looking for opinions or fact about the compression fittings. |
Classicvibe Samba Member
Joined: August 03, 2009 Posts: 743 Location: Salt Lake City
Posted: Thu Sep 02, 2010 1:50 pm Post subject: |
| flahernando wrote: |
Love our vendors! But in a pinch you can have those same lines built for just over $100. That still sounds like a stretch, but the piece of mind is awesome! _________________ On a mission, the destination is just an excuse.
Syncro Solstice 2022...see you there!
1986.5 Wolfsburg Syncro Westfalia Poptop Weekender Transporter |
pinealservo Samba Member
Posted: Thu Sep 02, 2010 2:12 pm Post subject: |
Short answer is no, plumbing-aisle fittings and copper pipe are not designed to work at the pressures in the PS system. Apparently the Vanagon pump produces especially high pressures.
Here's some info from another thread:
| tencentlife wrote: |
| I was way low on my working pressure guess. It's three times as much with this system. The system pressure is supposed to test at 1668-1740psi (115-120 bar). See Bentley p.48.7. |
The cheapest option that would work is probably to pull the lines from a junkyard vanagon. Second cheapest would be to have hoses custom-made at a hose shop. |
Posted: Thu Sep 02, 2010 2:23 pm Post subject: |
| What Safty??? how many motor cyclist's are killed every year by people driving around irresponcibly spewing oil on the roads? And not to metion if you need to swerve around that kid on the road with a limited and dangerous vehicle! That safty not just your own but everybobys! |
Low67vdubinnocal Samba Member
Posted: Thu Sep 02, 2010 6:28 pm Post subject: |
| Like was mentioned above a good used one from a pick and pull type yard if your able or take your tube one in to a hose maker. Out west there is Delta rubber or almost any Hydraulic repair shop or your local Napa auto that sells truck parts or even your Cat and John Deere dealers. Metric crimp fittings are very common now or can be ordered pretty quick. Just shop around for the best price on hose fittings and Labor to make it. |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10156 Location: Abiquiu, NM, USA
Posted: Thu Sep 02, 2010 9:04 pm Post subject: |
OK, after all that handwringing, what are you dealing with? Could it be that it is the low-side line that is leaking? If so, you can use copper, rubber hose, probably bendy drinking straws, to tie it all together; it is under pretty low pressure at most, just make sure you maintain at least the same pipe size so as not to limit flow. The low side return pipe is the one that leads directly to the plastic PS reservoir, by the way.
If it's high side, and a hardline, best bet is to take it to a Parker hose shop or heavy equipment shop and have a replacement made. If you were in a pinch and can match sizes correctly, you could safely patch the hardline using compression fittings but only with steel line, rated for at least 2000psi (not a big deal for steel line), never with copper; copper would burst at these pressures. But for all that effort you would always be better off having a new hardline made in one piece. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Experience is death to doctrine. |
Thanks. I didnt know the pressure was that high. The compression fittings are out of the question. I will have to make do with just manual for now, although I really cant tell the difference.
I know that not being connected will ruin the new rack but for now no options are available. Thanks much for the input. I appreciate it. |
Posted: Thu Sep 02, 2010 9:07 pm Post subject: |
Won't hurt the rack at all. Drive on. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Posted: Thu Sep 02, 2010 9:09 pm Post subject: |
| Great. I am glad about that. Thanks |
Terry Kay Banned
Posted: Thu Sep 02, 2010 9:23 pm Post subject: |
<< I will have to make do with just manual for now, although I really cant tell the difference.>>
Excuse me Arnold---
<<I know that not being connected will ruin the new rack but for now no options are available. Thanks much for the input. I appreciate it. >>
Double flare where it's broke & splice in a patch pipe.
Ditto on making a stop at any Parker Hose & Fitting dealer with the dripping old line in hand.
It won't dent your ADC check big time. _________________ T.K. |
heidi85ho Samba Member
Joined: October 17, 2009 Posts: 305 Location: Williamsburg,Virginia
Posted: Fri Sep 03, 2010 11:38 am Post subject: |
| I have been driving my 85 without the power steering for 10 years. Hate power steering! Much more stable on the highway without. Easier on tires too, as you are usually rolling before turning. No more grinding of rubber on pavement when turning the wheels of a stopped vehichle. Keep on rolling!! |
