Vanagon VR6
Page: Previous  1, 2, 3  Next
ChrisMac
ChrisMac is offline
PostPosted: Thu Sep 02, 2010 5:30 pm    Post subject: Reply with quote
240Gordy wrote:
I wonder if all that stuff on top of the engine could be flipped over to the other side. Likely would require fabricating an intake manifold . . .
I think this might be a slightly better way to go. Create a little more clearance I think.
Click to view image
James 93SLC
James 93SLC is offline
PostPosted: Thu Sep 02, 2010 6:35 pm    Post subject: Reply with quote
Very minimal gains using the short runner. See how high the valve cover sits on the one end? That's the limiting issue regarding height.
Plus the short runner takes away from the broad torque that the VR6 has. They only really work best for the turbo applications they are designed for.
91 Vanagon Carat
93 Corrado SLC
Photos: http://picasaweb.google.com/slc.corrado
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka"
casey79westfalia
casey79westfalia is offline
PostPosted: Tue Sep 07, 2010 11:37 am    Post subject: Reply with quote
Ok, so I am doing the vr6 and I am looking at more and more pics to get this all worked out. I am not sure why the above users vr6 motor is sitting so much higer and needed the notching opposed to the one in the attached pic below. I am assuming it was for more breathing room but is it necessary? The other thing that bothers me is that the engine compartment looks so empty on the right side making the engine look so out of place. The schimmel intake would really make use of that empty space on the right as well as a custom intake or even proper placement of the air intake to take up the space. I am hoping to get this thing to fit just like this one. These pic are of a vr6 in a syncro. Ideally I am going to make this conversion look as clean as possible. I am extremely obsessive and a perfectionist so I am making this project no exception. If anyone lese in interested in this conversion feel free to follow along. I will get a thread going once I actually start the process.
If anyone has any complete vr6 motors laying around let me know, im looking for one locally but havent found the right one yet. Preferably under 75k miles but will consider higher mileage motors for rebuilds.
66 Westfalia
87 Westfalia Syncro "Phoenix"
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Currently looking for 62 Double Cab, 66 Westfalia Parts!
(Rear seat and pedestal, bumpers, mirrors)
http://www.baycountrymotors.com
My 87 Syncro Westfalia 1.8t Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=418933
"Do it the right way, or you'll pay for it"
View user's profile Send private message Send e-mail Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
casey79westfalia
PostPosted: Tue Sep 07, 2010 12:42 pm    Post subject: Reply with quote
P.S
What are the differences in vr6 motors? I know there were the earlier vr6 corrado/jetta glx and passat version, then there were the later jetta 99- up vr6's. Is one smaller then the other? Are they similar?
66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
James 93SLC
PostPosted: Tue Sep 07, 2010 1:12 pm    Post subject: Reply with quote
casey79westfalia wrote:
P.S
Early VR6 are 12 valve heads (2 valve per cyl and 175ish hp). I think starting in 2001-2002 they came out with the 24 Valve VR6 with 200+ hp. Both of these are 2.8 liter motors. 2004 brought out the Golf R32 which has a VR6 3.2 liter 225hp motor.
Stick with the 12 valve motor. The 24 valve has variable cam timing and would be harder to adapt.
Finding a 12V with 75K might be hard. Luckily they are very stout motors and can be rebuilt without spending stupid $$$. Just stay away from ones with spun bearings or broken pistons Laughing
91 Vanagon Carat
93 Corrado SLC
kamzcab86
kamzcab86 is offline
PostPosted: Tue Sep 07, 2010 1:16 pm    Post subject: Reply with quote
P.S
Up to 2002, the VR6 was a 2.8L 12V (for '99.5+ model years, the VR6 got a horsepower and compression boost). From 2003 onward, the VR6 was a 3.2L 24V.
Dimension-wise, I believe they're all pretty much the same. The 24V is, of course, the heaviest of them all.
2016 Golf GTI S
casey79westfalia
PostPosted: Tue Sep 07, 2010 1:26 pm    Post subject: Reply with quote
Thanks guys. So up to 2002 the vr was 2.8 12v. Thats the motor I would feel most comfotable working with since its what I had in my old corrado. Ill most likely find a good vr6 motor and rebuild it to insure its quality before the install.
66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
James 93SLC
PostPosted: Tue Sep 07, 2010 1:47 pm    Post subject: Reply with quote
That's right. The 24 valve didn't appear till the 3.2 liter.
Yes, later OBDII motors with the coil pack ignition will be the best donor.
If compression #'s look good, you can freshen the motor with new timing chains/guides, and maybe the headgasket if you have the $.
Please post updates on your conversion. I might follow that route instead of the Bostig. I love the VR6 in my Corrado and would love to do one in the van.
91 Vanagon Carat
93 Corrado SLC
James 93SLC
PostPosted: Tue Sep 07, 2010 1:49 pm    Post subject: Reply with quote
FYI One thing that I don't like about the later motors (AFP I think) is the plastic intake manifold. They have a rod inside them that changes the runner harmonics at higher RPM, and they wear and rattle over time.
91 Vanagon Carat
93 Corrado SLC
casey79westfalia
PostPosted: Tue Sep 07, 2010 2:27 pm    Post subject: Reply with quote
James,
I miss my corrado slc so bad. That motor was the best vw ever built. I will keep you posted on the progress. I want to document it well so others can do the conversion and we can all improve on each others mistakes.
66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
casey79westfalia
PostPosted: Thu Sep 09, 2010 8:04 am    Post subject: Reply with quote
Here are some pics of the above vr6 install. I am using this as my inspiration. I actually dont mind the raised decklid when I realize how clean it could be done. Plus I actually like the idea of having storage/tool compartments right around the engine when a problem arises. Even a nice light on the lid so that I can see the engine compartment at night. This is gonna be fun.
My biggest concern is the wiring. I am sure that I can do the mounting and get it to look good in there. What I am not sure of is how I am going to make sense of how the wiring connects to the vr6 and all the computer related stuff. I am going to study all the vr6 swaps so i can get it clear in my head.
[/img]
66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
casey79westfalia
PostPosted: Thu Sep 09, 2010 9:23 am    Post subject: Reply with quote
James,
You mentioned that all engine until 2002 are similar, here is a 2000 and it looks like this.
66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
PaulGinAZ
PaulGinAZ is offline
PostPosted: Thu Sep 09, 2010 2:22 pm    Post subject: Reply with quote
Casey I am currently in the process of swapping a 12V OBDII VR6 into my Tristar Syncro which has quite a bit more deck clearance than a Vanagon. With that being said if you are looking for a VR6 motor in the Baltimore area I would refer you to Dave Graf the owner of New German Performance up in Aberdeen, Maryland. He is a personal friend of mine and is a great resource for finding such a beast.
As far as differences between the various VR6 configurations it is going to fundamentally come down to the early ones (1992-1993 Corrado and Passat) being a distributor-based OBDI motor and the later ones are all coil pack motors and OBDI till 1994 and OBDII afterwards. All of them have the same basic specifications until 2000 when the mkiv Jetta/GTi cars came out and they changed intake manifolds to the picture you posted above. After 2003 you had the option of a 24v motor in 2.8 guise and then the R32 motor right after that.
Either way the VR is a very stout motor and has one of the best sounds in a modern passenger car. VW Logo
-1989 Syncro Tristar TDi on Air Ride
-1980 Scirocco "S" with 16v Oettenger
-1996 VW Cabrio VR6 turbo
-2014 Silverado 1500 High Country
-2010 BMW X5 3.0 Sport (wifes)
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger Gallery Classifieds Feedback
James 93SLC
PostPosted: Thu Sep 09, 2010 2:27 pm    Post subject: Reply with quote
James,
Same engines...different manifold systems.
That's a 12V with the plastic intake manifold. Under it, it's the same old block and head that the Corrado has.
I think it was starting the mid 1999 year that got the plastic manifold on the 12V motor. Then in 2001 only the Eurovan got the the 24 Valve VR6 (different block and head than the 12V) and then in 2002 the Golf got that motor, which then was increased in size for the 2004 R32 Golf.
Any 12V motor from 1992 to 2001.5 is the same as far as the head and block go. Even the early distributor motors can be run as a coil pack with the correct timing chain covers.
There is now a 3.6 Liter VR6 powering the Audi TT, Passat and Toureg.
91 Vanagon Carat
93 Corrado SLC
casey79westfalia
PostPosted: Thu Sep 09, 2010 2:37 pm    Post subject: Reply with quote
Got it. Thanks James.
66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
MKIII and Sons
MKIII and Sons is offline
PostPosted: Thu Sep 09, 2010 7:16 pm    Post subject: Reply with quote
lots of misinformation in here.
allow me to clarify a few things for you guys
early OBDI AAA VR6s where distributor engines '91 thru '93 found in the B3 passats and early corrados
'94 and '95 are still OBDI but turned to the coil pack for spark
these are found in late model B3 passats, early B4 passats and early MKIIIs
'96 thru early '99 are OBDII VR6s found in late model B4 passats and MKIIIs
when the MKIV came around it is still the same 12v VR6 from '99 to '01
in '02 they introduced the BDF 2.8 24V VR6 in some GTIs and early GLIs
this utilized variable valve timing. the block is still the same but the heads have changed.
the BDF was used from '02 thru early '04
when the '04 R32 was introduced it was essentially the same engine but with a 3.2 bottom end and larger ported head.
AAA designates a 2.8 12v VR6 good for 170hp
BDF designates a 2.8 24v VR6 good for 201hp
the blocks may have subtle internal differences but the mounting points are exactly the same. I.E. you can bolt MKIII 12v mounts onto a MKIV 24v and vice versa.
hope this helps
broke.status
carterzest
carterzest is offline
PostPosted: Thu Sep 09, 2010 8:18 pm    Post subject: Reply with quote
from the Vanagon gathering White Salmon thread...This smelled like my brand new 1997 GTI VR6..simply amazing conversion...
Beautiful custom rack
Power!
Under the VR6
Happiness=Portland, Oregon in the rearview mirror!
casey79westfalia
PostPosted: Fri Sep 10, 2010 12:22 pm    Post subject: Reply with quote
So clean. I hope I can make mine look that good.
66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
James 93SLC
PostPosted: Fri Sep 10, 2010 1:07 pm    Post subject: Reply with quote
??? Confused
I don't believe any misinformation has been stated about fitment, and you've just restated the same info posted more or less. The real issue at hand here is which year VR6 would be the best candidate. I vote that being a 12V OBDI or II motor that has the simplest electronics package (no DBW). Yes the 24V and R32 motor mount the same, but getting the electronics and VVT systems to work in a Vanagon would get very difficult. Issues of immobilizers and DBW are just a few and all cost extra $$.
early OBDI AAA VR6s where distributor engines '91 thru '93 found in the B3 passats and early corrados (edit: Many 93 Corrados are coilpack)
All of those you quote are the same 12V block and head. No differences other that distributor vs coilpack and single vs. dual timing chains, and of course intake manifold systems. Of which all of those engines can run with the appropriate parts. As you do point out.
this utilized variable valve timing. the block is still the same but the heads have changed. the BDF was used from '02 thru early '04
Disagree here. The 24V block and 12V block are not the same internally. A 24V head will not bolt up to a 12V block and vise versa. Yes engine mounts are the same, but the ancillary components required would make conversion a nightmare.
And actually the 24V 2.8 first appeared in North America in 2001 (before the GTI) on the Eurovan.
hope this helps
You've addressed engines, but with no mention of each years operational differences (other than coil pack vs. distributor). Drive by wire was introduced in later years of the 12V, plus the intake manifold differences. Getting the later ECU to work with the immobilizer system is an issue...etc.
Doing a conversion entails more the just mounting it. Someone undertaking this route is likely looking at a more or less complete engine (i.e. includes throttle body, intake, maybe ECU...etc.), and knowing the issues adapting each is very important to the conversion process.
91 Vanagon Carat
93 Corrado SLC
xoo00oox
xoo00oox is offline
If you need a hand with the wiring harness I can make one for you that will only require about 4 wires for you to hook up. I have 2 complete engines/transmissions/suspensions sitting on my floor, OBD 1 and 2. I can hook up a fuel pump and start them on the floor to test wiring. Also keep the diagnostic plugs so you can scan it. I just made one for some ice racer guys this past winter.
Page 2 of 3
