Pics of the inside of a VW Beetle tunnel needed . . .
TC/TeamEvil
TC/TeamEvil is offline
PostPosted: Tue Sep 14, 2010 10:42 am    Post subject: Pics of the inside of a VW Beetle tunnel needed . . . Reply with quote
Does anyone have any pics or links to pics of what the VW Beetle tunnel looks like on the inside? I'm wondering where all of the brackets for the clutch tube are located, how high the E-brake tubes are, where the shifter rod runs, that sort of thing.
I know that I could pull everything apart, just start chopping, and learn through experience, but a handful of pics of where things are located before I begin would be a BIG help ! ! Even partial pics of either end or already chopped up spines/pans would be helpful.
Thanks,
T
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Sep 14, 2010 10:53 am    Post subject: Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
BL3Manx
BL3Manx is offline
PostPosted: Tue Sep 14, 2010 11:08 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/album_search.php?...t_dir=DESC
gr8cobbler
gr8cobbler is offline
PostPosted: Tue Sep 14, 2010 12:36 pm    Post subject: Reply with quote
BL3manx continues to impress, Glenn must have a doctors scope or something, I had to use a sawzall to answer the question. Laughing
Hope the extra angle helps answer your needs.
Gary
Being a cheap old fart is just a front for my actual lack of money. Smile
Iguana
Iguana is offline
PostPosted: Tue Sep 14, 2010 3:19 pm    Post subject: Reply with quote
The guy you want to thank is Graham from VW Drivers Club QLD.
Check it out .... http://www.vwdcqinc.org.au/insideabug.html
BL3Manx
BL3Manx is offline
PostPosted: Tue Sep 14, 2010 5:01 pm    Post subject: Reply with quote
Definitely, I just had seen them posted in the Gallery section before. I am curious about a couple things on that chassis though. How come its LHD?, I thought Australia was RHD. Also, why is there both an old style heater control knob and a late model seat belt anchor nut plate?
sfretwell
sfretwell is offline
PostPosted: Tue Sep 14, 2010 5:56 pm    Post subject: Reply with quote
I found this in my collection of drawings. Hope it helps.
TC/TeamEvil
PostPosted: Wed Sep 15, 2010 7:04 am    Post subject: Reply with quote
Thank gang ! ! As usual, answers all of my questions. I was most concerned with the e-brake tubes being so high and close to the wall(s) of the tunnel, plus I didn't want to break any of the tabs/brackets/etc.
Terrific info/pics/diagram ! !
T
Berf
Berf is offline
PostPosted: Sat Oct 02, 2010 12:41 pm    Post subject: Reply with quote
Here's a pic at the front of the tunnel. Sure would like to see Glen's pic with the shift-shaft out of the way. I think I've got an idea what the bracket originally looked like.
glennSKii
glennSKii is offline
PostPosted: Thu Feb 21, 2013 3:55 pm    Post subject: Reply with quote
hello.
i am new here. and i just got a baja last week after 20 years abroad without a Vdub.
My parking brake is busted. i took it off to repair and repaint. when i did this, the piece with the teeth fell straight down into the tunnel to the tunnel floor. anybody know the best way to get it back out?
thanks.
glennSKii
clonebug
clonebug is offline
PostPosted: Thu Feb 21, 2013 4:05 pm    Post subject: Reply with quote
You might be able to grab it with a flexible magnet wand......
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
glennSKii
PostPosted: Thu Feb 21, 2013 5:40 pm    Post subject: Reply with quote
ah. thanks. where do they sell those? (i dont want to order from the net because that would take too long. i wanna do it by morning).
do they have them at autoparts? hardware store? walmart?
thanks.
glenn
BL3Manx
BL3Manx is offline
PostPosted: Thu Feb 21, 2013 5:53 pm    Post subject: Reply with quote
How about just a piece of wire with a hook bent on the end.
Dale M.
Dale M. is offline
PostPosted: Thu Feb 21, 2013 5:54 pm    Post subject: Reply with quote
thanks.
glenn
Most auto parts and hardware stores have telescoping magnetic wands for picking up "dropped things"... Usually about $2 to $5 range....
Something similar to this....
Dale
glennSKii
PostPosted: Fri Feb 22, 2013 12:11 pm    Post subject: Reply with quote
Thanks so much! i got the magnet thingie last night and used it this morning. pulled it out first try! (once i drug the magnet around a bit, trying to be certain i connected with the part).
a loose , long woodscrew came out too! so i will fish around and se if i can pull anything else out before the parking brake gets reinstalled.
my first try at getting advice here in the forum. Smile
so we are 1-for-1.
glennSKii
dustymojave
dustymojave is offline
PostPosted: Tue Sep 15, 2015 10:10 am    Post subject: Reply with quote
so we are 1-for-1.
glennSKii
I'm glad you got help quickly.
One thing that puzzled me is that your user info indicates a location of Poland and yet you ask about getting the magnet at an auto parts store or Walmart as if you are in the US. Have you just moved back to the US from having spent some time in Poland? While the Iron Curtain is long gone, I expect things are still a little different in Poland than they are in the US. I used to work with an engineer who had been a rally Champion in Poland when the Iron Curtain was up. He told stories of what it was like for a motorsports guy there at that time.
Richard
SoCalBajas Member
[email protected]
ptjjb@yahoo.com is offline
PostPosted: Tue Sep 15, 2015 11:36 am    Post subject: Reply with quote
so we are 1-for-1.
glennSKii
There are some amazing very old VW kubelwagens, schwimmwagens, type 1s and ambulance/fire engine vans. And you came back without something amazing.
