CV Joint Orientation Information GKN Lobro
busman78
busman78 is offline
PostPosted: Thu Sep 16, 2010 7:59 am    Post subject: CV Joint Orientation Information GKN Lobro Reply with quote
Due to conflicting information all over the web and this site as to which way to orient the CV Joint for installation I contacted the GKN Driveline factory to get the final word, at least for GKN Lobro CV Joints. Per the email I received with the drawing, the single line side goes to the shaft and the three line side goes to the flange. the center hub on the single line side also has a chamfer and the three line side of the center hub is flat cut with no chamfer.
Below is the drawing and pictures of a GKN Lobro CV Joint from both sides.
Jalabert
Jalabert is offline
PostPosted: Thu Sep 16, 2010 12:24 pm    Post subject: Reply with quote
That's awesome work. Maybe this could be merged with the thread with the link that aeromech put up showing how to reassemble a CV and made into a sticky...?
'73 westy, 1700 type 4 with 34icts
babysnakes
babysnakes is offline
PostPosted: Fri Oct 15, 2010 7:08 am    Post subject: Reply with quote
Thanks for posting this. I packed my new lobros last night, planning on mounting them today. This was my question.
Desertbusman
Desertbusman is offline
PostPosted: Tue Mar 15, 2011 5:49 pm    Post subject: Reply with quote
I've never seen a joint with 3 grooves on one side. And that single groove is opposite the flange. Most joints only have one groove. And depending on the source, that single groove sometimes is inside and sometimes is outside.
71 Superbug
71 Westy
busman78
busman78 is offline
PostPosted: Tue Mar 15, 2011 6:43 pm    Post subject: Reply with quote
These were Lobro's, as for other off brands I have no idea.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Mar 15, 2011 7:41 pm    Post subject: Reply with quote
The ones we had also show 3 and 1.
George Carlin:
Skills@EuroCarsPlus:
curtis4085
curtis4085 is offline
PostPosted: Wed Nov 30, 2011 8:45 pm    Post subject: Reply with quote
So my Lobros came today in the mail so I figured this should be a fun messy project. Well have a few questions. I had to use a large round cylinder to help drive the CV joint onto the axle. One side went on pretty smooth and the other I had to give her a few hard taps to get her all the way seated back. Other thing to note is the one side that went on hard the circlip fit real nice and tight. The other easy side the circlip spins and seams lose I need to get some longer handled pliers to tighten it up. Where did I go wrong. ANy pointers?
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
old DKP driver
old DKP driver is offline
PostPosted: Wed Nov 30, 2011 9:01 pm    Post subject: cv joints Reply with quote
Way back when i was a tech i would put the new CV's up inside the shop heater in the winter time to warm them up before installing them. Very Happy
Curtis,
As for the loose circlip if you have up and down play even with the new style joints that have the "built in thrust surface" you may still be able to install one of the old washers to remove the excess play.
Or, if you are saying the Snap ring is just to loose take it off and bend it a little.
V.W.owner since 1967
curtis4085
PostPosted: Wed Nov 30, 2011 9:10 pm    Post subject: Re: cv joints Reply with quote
Curtis,
not much or any play in joint to circlip. the circlip after install i could not squeeze tight. it spins in the grove. What do people use to pinch these thing together
Special Thanks to:
Desertbusman
PostPosted: Wed Nov 30, 2011 9:19 pm    Post subject: Reply with quote
Pince it before putting it on or much better yet is a new one. Was the groove in good shape?
71 Superbug
71 Westy
curtis4085
PostPosted: Wed Nov 30, 2011 9:29 pm    Post subject: Reply with quote
yep new..maybe I open it to far during installion. I will pull it off and try to tighten it up and reinstall. I had to call it a day. Way messy job. Thank god for rubbe gloves and shop towels. And I for got to change clothes into something I could toss. To excited to get the job going.
Special Thanks to:
Desertbusman
PostPosted: Wed Nov 30, 2011 9:32 pm    Post subject: Reply with quote
I bet you learned the importance of taking a leak and turning off the phone before you started. Laughing
71 Superbug
71 Westy
curtis4085
PostPosted: Wed Nov 30, 2011 9:34 pm    Post subject: Reply with quote
so true. Learning all the way. And i have made similar boo boo when the with comes in the shop and breaks my stride.
Special Thanks to:
SGKent is offline
PostPosted: Wed Nov 30, 2011 9:38 pm    Post subject: Reply with quote
see section 5.2
http://www.ratwell.com/technical/FAQ/FAQContent.html
George Carlin:
curtis4085
PostPosted: Wed Nov 30, 2011 10:03 pm    Post subject: Reply with quote
SGKent wrote:
see section 5.2
one of the first reads for sure. and many threads and bently. and you tube. It seems i may have done ok. I am so hard on myself, want perfection all the time. For it being my first axle rebuild it will insure my next is near perfect. I hope.
Special Thanks to:
Brionp
Brionp is offline
PostPosted: Wed Nov 30, 2011 10:28 pm    Post subject: Reply with quote
And while we are on the subject I just wanted to share this:
For all the tool geeks out there. These are some old craftsmen snap ring pliers, or reverse pliers. They haven't been made for a while. But you can still find them on Ebay. And you would think they were custom made for the circlips. Some even have dimples on the tip that hold the clips that much better.
porschpow
porschpow is offline
PostPosted: Mon Mar 12, 2012 5:21 am    Post subject: Reply with quote
Good stuff. Thank you very much for this. I will be putting new boots on my bus and while I am there I will repack the bearings. I am assuming I need to clean off the old grease before I repack it, correct?
-1973 Volkswagen Bus Westy (Weekender)
1.8 liter from 1.7(original)
-2011 Subaru Outback
-1986 Honda Magna
SGKent is offline
PostPosted: Mon Mar 12, 2012 7:37 am    Post subject: Reply with quote
yes. Dry and inspect too.
George Carlin:
Durk
Durk is offline
PostPosted: Wed Nov 06, 2013 7:55 pm    Post subject: Reply with quote
This post started years ago because of conflicting information I saw about proper CV joint assembly. There is still conflicting information out there, but in my assembly I'm going with the orientation provided by the original poster who contacted the GNC Lobro factory directly. I had been following the Van Cafe writeup on CV joint assembly until it seemed to conflict with other information on orientations of the 3 main parts. Also, the Van Cafe article shows a Lobro joint with only one groove on the outer ball hub, and the ones I just received from them have 4 grooves total.
There seems to be no dispute that the chamfered edge of the ball cage goes in, or toward the axle. What seems to differ is which side of the inner ball hub goes in. It seems to me that the Van Cafe article is showing what I believe to be the wrong direction to install the inner ball hub, with the more rounded edge toward the axle. When I called Van Cafe I was told that the more rounded edge faces out, or away from the axle which is what the Lobro factory said. Also, Van Cafe said that it doesn't matter at all which side of the outer ball hub goes in or out. Like I said, I was following the Van Cafe writeup, but am glad I found this post because I think this is the correct way. Any comments?
Desertbusman
PostPosted: Wed Nov 06, 2013 10:08 pm    Post subject: Reply with quote
I.D. chamfer towards the shaft and flat end with no chamfer against the clip. And the sharpest edge of the clip towards the shaft end and not against the hub.
But I don't think any of the CV's on either my bug or bus have Lobros. At least I don't think any have 4 outer grooves.
71 Superbug
71 Westy
