DaBlackSamba Samba Member
Joined: August 22, 2010 Posts: 317 Location: west eugene, or
Posted: Tue Oct 05, 2010 11:35 pm Post subject: rotor question |
i have a 73 fasty, and looking for front rotors, my parts store i am going thru have the calipers for it, and they are listed as type 1 thru type 3 calipers, but as for the rotors, they are listed as 4 lug bug rotors, are these the same as the type 3 rotors? _________________ 1968 VW variant |
cfvwtuner Samba Member
Joined: June 10, 2005 Posts: 438 Location: Central Connecticut
Posted: Wed Oct 06, 2010 3:17 am Post subject: |
As far as I know, the only thing interchangeable with a bug on the 73 will be the wheel bearings.
The rotors are larger, the calipers are type 4/914 ones.
They were the same as Ghia up untill 71 1/2.
I converted my 1972 Square to the earlier spindles so I could use the much cheaper and easier to find stuff. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18050 Location: Eugene, OR
Posted: Wed Oct 06, 2010 4:42 am Post subject: |
I have good used 67/71/72 rotors and calipers Here in North Eugene. PM me. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23338 Location: Oklahoma City
Posted: Wed Oct 06, 2010 5:42 am Post subject: |
| cfvwtuner wrote: |
Actually the late type 3 rotors are "EARLY" type 4 rotors...that fit 411/914 to august of 1972 only....not after. Ray |
Posted: Wed Oct 06, 2010 12:12 pm Post subject: |
i got a pair of calipers, and it specified type 1 and type 3, they both looked like it, but the holes were WAAAAAAAAAAAAAAAY off, the ones that came on there had a bolt spacing of 3" from center to center hole, and the ones i found were 2.25: center to center hole _________________ 1968 VW variant |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80144 Location: Sneaking up behind you
Posted: Wed Oct 06, 2010 12:15 pm Post subject: |
Your 73 Type 3 uses part number 411 407 075 rotors. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Wed Oct 06, 2010 12:57 pm Post subject: |
do you happen to know the caliper part number, and is there a difference from drivers side to passenger side? _________________ 1968 VW variant |
Glenn  Mr. 010
Posted: Wed Oct 06, 2010 2:03 pm Post subject: |
| DaBlackSamba wrote: |
| do you happen to know the caliper part number, and is there a difference from drivers side to passenger side? |
Front left 311 615 107 B
Front right 311 615 108 B
Member #1009
#BlueSquare
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11497 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Wed Oct 06, 2010 7:12 pm Post subject: |
awesome, thanks for the part numbers, it is a big help, i found a site called VW help,and its got a few part numbers, and the calipers i had said 67-3/73, and the numbers you provided said 71-73... i think thats a little weird _________________ 1968 VW variant |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23533 Location: Kimball, Mi
Posted: Wed Oct 06, 2010 8:21 pm Post subject: |
Yeah, the calipers you just bought are the early style (66 to 71), then the next are 72 & 73 (NLA). The bolt spacing is farther apart, along with a spindle change and a larger rotor. This is why when people ask about upgrading the "early" style disc brakes, it's first recommended to go to the "later" style. However, as you have found out, nobody carries the "late" calipers (other than a Porsche shop), and the rotors are hard to find as well. A friend of mine swapped to the early spindles just so he could get parts for his 72 Squareback. I know this is probably a step backward, but at least he can get parts. You could send your late calipers to Jim Adney for rebuilding IF you want. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Posted: Thu Oct 07, 2010 5:27 am Post subject: |
| Bobnotch wrote: |
Yeah, the calipers you just bought are the early style (66 to 71), then the next are 72 & 73 (NLA). The bolt spacing is farther apart, along with a spindle change and a larger rotor. This is why when people ask about upgrading the "early" style disc brakes, it's first recommended to go to the "later" style. However, as you have found out, nobody carries the "late" calipers (other than a Porsche shop), and the rotors are hard to find as well. A friend of mine swapped to the early spindles just so he could get parts for his 72 Squareback. I know this is probably a step backward, but at least he can get parts. You could send your late calipers to Jim Adney for rebuilding IF you want. |
Where do you get that nobody carries the late T-3/early type 4 caliper?
I can find them all over the place. Rockauto have three diffenet brands of them ranging from $41 to $55.
These calipers fit a WIDE range of cars from volvo's to Saabs. Ray |
Posted: Thu Oct 07, 2010 2:05 pm Post subject: |
i heard that they are the same as the 914's? _________________ 1968 VW variant |
Posted: Thu Oct 07, 2010 8:31 pm Post subject: |
| raygreenwood wrote: |
| Bobnotch wrote: |
Post up some part numbers, or the year and model they cross over with, so we can make a list for those who are looking for them.
Do you have a source for the late t-3/early t-4 rotor too? _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Thu Oct 07, 2010 8:44 pm Post subject: |
thanks for bringing that up bob, that would really be useful to know for future reference _________________ 1968 VW variant |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Oct 07, 2010 8:50 pm Post subject: |
| Quote: |
| 411 407 075 Brake disc -~ from Ch. No. 3122000001 |
| Quote: |
311 615 107 B Caliper assembly left without brake pods
311 615 108 B Caliper assembly right without brake pods
They also show another caliper for an M594 M code. Has a 361 part number. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
