Camber compensator
off-vdubbin
off-vdubbin is offline
PostPosted: Fri Oct 08, 2010 11:24 pm    Post subject: Camber compensator Reply with quote
Has anyone ever used this or tryed it on a baja
http://www.jcwhitney.com/camber-compensator-swing-...id=6668449
off-vdubbin
PostPosted: Sun Oct 10, 2010 1:19 pm    Post subject: Reply with quote
anyone have any info on this pro's con's do you think it would help out at all?
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Oct 10, 2010 1:23 pm    Post subject: Reply with quote
They work for street use, but I do not know how well they would work for off road.
Gary: OK. Ima poop.
JDub113
JDub113 is offline
PostPosted: Mon Oct 11, 2010 2:15 pm    Post subject: Reply with quote
I have a swing axle baja too. This would not be good for offroad becuase you won't have any down travel of the rear wheels and would be more likely to get a tire in the air and get stuck or have to back down an obstacle.
I want to fix my camber and was thinking about a trans drop.
JDub113
JDub113 is offline
PostPosted: Tue Oct 12, 2010 12:29 am    Post subject: Reply with quote
Check the gear reduction box thread out, I just found it.
http://www.thesamba.com/vw/forum/viewtopic.php?t=203039&highlight=reduction+box
off-vdubbin
PostPosted: Tue Oct 12, 2010 6:15 pm    Post subject: Reply with quote
cool thanks for the info do you think smaller rear tires would help it has 33 12.50's on the rear now and 31 10.50 on the front
JDub113
JDub113 is offline
PostPosted: Tue Oct 12, 2010 11:35 pm    Post subject: Reply with quote
Actually a taller tire would help... I'm new at this too, but you have to lower the rear some, which I don't know how to do... Since you are already running 33s, if you have the fender clearance maybe all you need to do is lower the rear.
