rear bumper mount changeover
52 split
Location: the best island in the world, vancouver island
52 split is offline
PostPosted: Sat Oct 09, 2010 2:35 pm    Post subject: rear bumper mount changeover Reply with quote
i see replacement bumper mounts from wolf parts and kdf service as 52-60, a long mount. and also a listing for pre 53,a shorter mount. what month in 52 did the mount change to the longer version. trying to know what would be right for my car. thanks
52 split
52 split is offline
PostPosted: Mon Oct 11, 2010 7:09 pm    Post subject: mount Reply with quote
someone here must know.should my june 52 have long or short mounts . i tried the search section but did not see my answer. Sad
eurodub
eurodub is offline
PostPosted: Mon Oct 11, 2010 7:44 pm    Post subject: Reply with quote
my june 52 has short ones. 27june52
1960 1200 model 117 deluxe ragtop
1976 MK1 Golf
Zwitterkafer
Zwitterkafer is offline
PostPosted: Tue Oct 12, 2010 10:12 am    Post subject: Reply with quote
June 52 definitely has the short mounts. These were changed to long mounts at some point in the 6 month Zwitter period (Oct 52 to Mar 53), IIRC.
- Zeuxius, 400 BC
52 split
52 split is offline
PostPosted: Tue Oct 12, 2010 11:06 pm    Post subject: re mount Reply with quote
looks like i have to remove or modify the last owners resto job, it is really nicely done. Sad can the long mount just be shortened or is it completely different . thanks guys for your help.
virtanen
virtanen is offline
PostPosted: Wed Oct 13, 2010 12:01 am    Post subject: Reply with quote
To go deeper the split rear bumper mounts, also split has two different lenghts, one is 195 mm and other 205 mm. I have no idea when each was used, my 1/52 and 6/52 has shorter ones, as my friend's 10th October manufactured 1951 has too. But an other 16th October 51 manufactured has longer ones. Maybe 2 suppliers and mixed?
The difference is on the front end.
205 mm (my own made):
195 mm (borrowed Wolf):
Zwitterkafer
PostPosted: Wed Oct 13, 2010 9:48 am    Post subject: Reply with quote
Interesting, I did not know that! The longer version of the short mount has a flange at the front end, for maybe a couple of extra spotwelds? I hope they were used interchangeably; if not, no peeking under the rear fenders please!
- Zeuxius, 400 BC
eurodub
eurodub is offline
PostPosted: Wed Oct 13, 2010 10:03 am    Post subject: Reply with quote
i noticed that a few weeks ago as i must change mine soon. kdf service does the longer version, while wolf the shorter. i still don't know what i must get but after cleaning the supports ill know for sure, there's still original metal left
1976 MK1 Golf
virtanen
virtanen is offline
PostPosted: Wed Oct 13, 2010 1:21 pm    Post subject: Reply with quote
I can make both split versions, the shorter model is easier Very Happy
Hebster52
Hebster52 is offline
PostPosted: Mon Nov 25, 2024 1:03 am    Post subject: Re: rear bumper mount changeover Reply with quote
What would be correct thickness of sheetmetal for the bumper mounts?
1mm too flimsy, 1,2mm fine or 1,5mm?
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
Two Glove Boxes
Two Glove Boxes is offline
PostPosted: Mon Nov 25, 2024 9:55 am    Post subject: Re: rear bumper mount changeover Reply with quote
Mika (Virtanen) can chime in since he produces high quality ones.
1950 Deluxe Sedan Build
Two Glove Boxes IG
