Hurst Rear Bumper Mounting
March Hare
March Hare is offline
PostPosted: Sun Apr 27, 2008 7:22 am    Post subject: Hurst Rear Bumper Mounting Reply with quote
Ok,,since having learned ( perhaps the hard way ) about these beasts,,I have noticed that the rear mounting ones seemed to be 'flawed' ( least as far as I can see..Where the rear mounts to the 1/4 panel is there actually anything there besides sheet metal? ie some sub structural support or something ? Otherwise it would seem that if you got tagged in the back end that not only would you have bumper and the obvious damage to deal with,but also a nice tear in your 1/4 from the bar pushing forward.
"we know who you are Bronze and we know where you live ..."
#24312
campingbox Premium Member
campingbox is offline
PostPosted: Sun Apr 27, 2008 7:57 am    Post subject: Reply with quote
I ran some 2" square washers on the very front bolt when I installed the set on the Boise bus. The center two bolts are inbetween the corner seam and the wheel well seam so I suspect it's a fairly strong area.
chiroracer
chiroracer is offline
PostPosted: Sun Apr 27, 2008 9:02 am    Post subject: Reply with quote
See you on the road skag!!!! EB
66 bajawestfalia
2/1600 buggy Kreger chassis 4 baja 1000(waiting to re emerge)
71 911 track car
65 kombi EZ camper (sold to OG owner in oregon)
69 class 11 racecar Sold to GH racing now the famous Dora SCOREchampion
70 class 11 prerunner
Clara Premium Member
Clara is offline
PostPosted: Mon Apr 28, 2008 8:27 am    Post subject: Reply with quote
The Hurst bumpers have extra brackets as well as the bar that goes from left to right.
The Hurst brackets are white in the pic above.
The original brackets are grey.
Those early bumpers through 58 are just flimsy.
tantau
tantau is offline
PostPosted: Fri Oct 15, 2010 4:38 pm    Post subject: Reply with quote
What's the difference between "early" vs "late" on the rear hurst bumpers... is it something to due with the bumpers??? Looks like the rear would fit either way... (I have a '61)
M
"He who controls the spice, controls the universe"
EmpiGT
EmpiGT is offline
PostPosted: Fri Oct 15, 2010 4:43 pm    Post subject: Reply with quote
On original Hursts early and late rears is where the lower tube stops. Early stopped at the lower mounting bolt on the bumper, like the one pictured above. On the later ones the tube extended past the mounting bolt on the bumper and wrapped into the wheel well some. But both types were for use on pressed bumpers. I think all repros out now are the early hurst style and that is the style you need to run on your late bumpers so they can sit farther back and you won't have the tube bent in to the side of the bumper or battery corner.
Here's a picture Clara posted. This is the best one I could find of late Hursts, notice the lower portion of the tube going into the wheel well.
tantau
tantau is offline
PostPosted: Fri Oct 15, 2010 5:15 pm    Post subject: Reply with quote
I see what your saying for the "OG" style.... but for repros, your saying they commonly look like the top pic, but modified to fit properly?? Someone mentioned it's a bracketing thing for the repros...
Thx for the insight... Smile
M
UZI
Platinum FUBU
UZI is offline
PostPosted: Fri Oct 15, 2010 5:18 pm    Post subject: Reply with quote
i've never seen these "early" rear hursts. every set i have had have all been this "late style"
Extravagant Lifestyle
EmpiGT
EmpiGT is offline
PostPosted: Fri Oct 15, 2010 6:26 pm    Post subject: Reply with quote
That's funny Gibbs. you said this in 06
UZI wrote:
that bus EmpiGT found appears to be a late 57/58. it also has the same type of rear hursts as the KING panel. i'm thinking the kind that snub off at the rear bumper are an earlier version.
Alot of discussion about this on page 3 of this thread
http://www.thesamba.com/vw/forum/viewtopic.php?p=1425695&highlight=#1425695
UZI
Platinum FUBU
UZI is offline
PostPosted: Fri Oct 15, 2010 6:30 pm    Post subject: Reply with quote
too much liquid LSD. what can i say. i still am not seeing any pics of original snub end rears.
PostPosted: Fri Oct 15, 2010 7:06 pm    Post subject: Reply with quote
Ten for you and ten for me.
I have the set off busnutbob's '58 sunroof standard, the one with the glass cab divider, and they are the snub end type.
UZI
Platinum FUBU
UZI is offline
PostPosted: Fri Oct 15, 2010 7:17 pm    Post subject: Reply with quote
is that how many rears i've had? 10? i think i've had 14 fronts.
kombicol
kombicol is offline
PostPosted: Fri Oct 15, 2010 7:37 pm    Post subject: Reply with quote
While on the topic of rear hursts, does anyone know if there was another set for single cabs?
I have a set of the volkscafe early rear set and they foul on the sharp corners, wheras the ones of this single clear easily. Was there another set made with a tighter radius for the single cabs?
PostPosted: Fri Oct 15, 2010 8:56 pm    Post subject: Reply with quote
I have no idea how many you have had. I'm not sure there are ten original rear sets in existance.
Sunroofgod
Sunroofgod is offline
PostPosted: Fri Oct 15, 2010 9:46 pm    Post subject: Reply with quote
These are sets that Damon out of Old Volks Stockton made about 10+ years ago. One or two sets were made for single cab corners.
kombicol
kombicol is offline
PostPosted: Fri Oct 15, 2010 10:05 pm    Post subject: Reply with quote
^^ Thanks,
At least now I know why the set I have don't fit and his did.
Now I need to decide if I want to try and modify the ones I have or forget about putting them on the rear.
UZI
Platinum FUBU
UZI is offline
PostPosted: Sat Oct 16, 2010 5:22 am    Post subject: Reply with quote
there has to be. i have had at least six.
bill may
bill may is offline
PostPosted: Sat Oct 16, 2010 9:24 am    Post subject: Reply with quote
Heil Machine Co. is making the rear hurst copies now. Justin made a set for Robzkombi and i am picking them up at octo to deliver to Rob. Rob has a DCab. i am not sure on year of it. stop by my green 65 bus if you want to see them,or Justin should have extras for sale at octo.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
FritzCP
FritzCP is offline
PostPosted: Mon Oct 18, 2010 6:03 pm    Post subject: Reply with quote
Thats my 58 sc I sold last spring. I still have the bumpers front and rear if anyone is interested in them. PM me if you do - thanks
Fritz Custom Products
Lou V.
Lou V. is offline
PostPosted: Tue Oct 19, 2010 7:49 am    Post subject: Reply with quote
There should be a flat stock washer about 4" long and has square holes for carriage bolts. that's what came with the original rears that I had.
eejermon wrote:
"The Shasta Snow Trip. It's not for pussies."
