1966 Bus - Now rebuilding after fire
Page: 1, 2, 3 ... 16, 17, 18  Next
RPGreg2600
RPGreg2600 is offline
PostPosted: Sun Nov 07, 2010 10:23 pm    Post subject: 1966 Bus - Now rebuilding after fire Reply with quote
Just picked this up yesterday. Need to replace all the tie rod ends and the rear main seal before I can start driving it around, but have driven it around the block. Also has some rust in the rockers, jacking points and the rear outriggers.
More pictures here:
http://picasaweb.google.com/rpgreg2600/Bus#
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Nov 07, 2010 10:29 pm    Post subject: Reply with quote
Cool!
You need:
The stock air cleaner.
Plus either block off the fresh tubes from the shroud if you are running J-tubes or get the hoses back in there if running heat exchangers.
Metal fuel line, and new German cloth covered flexable fuel line.
Before driving it any farther!!!
In Stereo, Where Available!
RPGreg2600
PostPosted: Sun Nov 07, 2010 10:32 pm    Post subject: Reply with quote
Yes, I need an air filter, anyone have a factory one laying around?
Eric&Barb
PostPosted: Sun Nov 07, 2010 10:44 pm    Post subject: Reply with quote
Would try the "Classifieds" on this website, and you can always do a "Wanted Ad" there.
You can get into trouble advertising in the forums....
VolksFire
VolksFire is offline
PostPosted: Sun Nov 07, 2010 10:59 pm    Post subject: Reply with quote
Congrats. Nice to see someone local got Dagan's bus. Have fun with it, and welcome to TheSamba. Check out or local group as well http://www.norcalaircooledgroup.org/
Jahnai Pearson - VW Restoration Technician
Current ownership (always changing):
60 Double Door Panel
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
79 Dasher Wagon
82 Quantum Coupe
96 Golf GL
RPGreg2600
PostPosted: Sun Nov 07, 2010 11:43 pm    Post subject: Reply with quote
Oops, sorry. Would a later model air filter like this: http://www.thesamba.com/vw/classifieds/detail.php?id=1026789 fit or do I need to get an early style? I'd muh rather spend $20 than $100.
EODinert
EODinert is offline
PostPosted: Mon Nov 08, 2010 7:02 am    Post subject: Reply with quote
Just get a cheap paper filter until the proper filter finds you at the right price.
'61 rag top beetle, '73 type 181, '66 13 window deluxe
74 Cosa
74 Cosa is offline
PostPosted: Mon Nov 08, 2010 7:31 am    Post subject: Reply with quote
Isn't it fun to take that first drive in your new ride?
Have fun!
chrome
chrome is offline
68 on ait cleaners sit on a uh table i guess, while your style hangs from the 2 hole bracket to the right of the engine
65 21 window
57 T1 ragtop
58 ghia vert
68 fastback
73 Thing
74 Thing
54 chevy 210
63 mercury meteor wagon
Eric&Barb
PostPosted: Mon Nov 08, 2010 8:17 am    Post subject: Reply with quote
Paper air cleaner will do in a pinch, but stock works much better.
You should be able to piece a 1964-67 setup together for much less than $100.
BarryL Premium Member
BarryL is offline
PostPosted: Mon Nov 08, 2010 8:20 am    Post subject: Reply with quote
Not bad at all. Be safe and dive in.
ToolBox
ToolBox is offline
PostPosted: Mon Nov 08, 2010 9:27 am    Post subject: Reply with quote
Or get the correctly sized fuel line that will not fail in a year with the US fuel blends.
GLHTurbo
GLHTurbo is offline
PostPosted: Mon Nov 08, 2010 9:40 am    Post subject: Reply with quote
so the german hose will fail in a year with US fuel? What do you use?
1957 Beetle
1966 Bus
RPGreg2600
PostPosted: Mon Nov 08, 2010 1:42 pm    Post subject: Reply with quote
Hey guys, thanks for the advice, I will try a paper filter for now and keep an eye out for a stock oil bath. I know eric from nor cal relics through a Land Rover group I belong to, I'll have to poke around is pile of parts.
Anyway, another question. I just pulled the motor to replace the rear main seal and any others I can easily replace. I noticed that the bell housing on the transmission has ben ground out larger than stock. What would be a reason for doing it? Only thing I can think of is to fit a later model engine if they have a bigger flywheel?
Here is the engine number, anyone know what engine that would be? I'll try doing a search.
orangebug60guy
Twin #1
orangebug60guy is offline
PostPosted: Mon Nov 08, 2010 2:03 pm    Post subject: Reply with quote
6v to 12v grind to fit the bigger flywheel?
Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation.
Adam
Adam is offline
PostPosted: Mon Nov 08, 2010 4:59 pm    Post subject: Reply with quote
Was this the one in Petaluma?
PostPosted: Mon Nov 08, 2010 5:23 pm    Post subject: Reply with quote
My understanding is that H5 is 68/69 1500cc
shawn407
shawn407 is offline
PostPosted: Mon Nov 08, 2010 6:53 pm    Post subject: Reply with quote
The trans was definately ground out because it was originally a 6 volt setup. It's very common and you have nothing to worry about. I see this all the time at work.
Clara
Clara is offline
PostPosted: Mon Nov 08, 2010 7:17 pm    Post subject: Re: Just picked up a 66 bus Reply with quote
That shit'll buff out!
Sweet bus Very Happy
VolksFire
PostPosted: Mon Nov 08, 2010 7:24 pm    Post subject: Reply with quote
yes
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
79 Dasher Wagon
82 Quantum Coupe
96 Golf GL
Page 1 of 18
