RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Sun Nov 07, 2010 10:23 pm Post subject: 1966 Bus - Now rebuilding after fire |
Just picked this up yesterday. Need to replace all the tie rod ends and the rear main seal before I can start driving it around, but have driven it around the block. Also has some rust in the rockers, jacking points and the rear outriggers.
More pictures here:
http://picasaweb.google.com/rpgreg2600/Bus# |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26427 Location: Olympia Wash Rinse & Repeat
Posted: Sun Nov 07, 2010 10:29 pm Post subject: |
Cool!
You need:
The stock air cleaner.
Plus either block off the fresh tubes from the shroud if you are running J-tubes or get the hoses back in there if running heat exchangers.
Metal fuel line, and new German cloth covered flexable fuel line.
Before driving it any farther!!! _________________ In Stereo, Where Available! |
Posted: Sun Nov 07, 2010 10:32 pm Post subject: |
| Yes, I need an air filter, anyone have a factory one laying around? |
Posted: Sun Nov 07, 2010 10:44 pm Post subject: |
Would try the "Classifieds" on this website, and you can always do a "Wanted Ad" there.
You can get into trouble advertising in the forums.... _________________ In Stereo, Where Available! |
VolksFire Samba Member
Posted: Sun Nov 07, 2010 10:59 pm Post subject: |
Congrats. Nice to see someone local got Dagan's bus. Have fun with it, and welcome to TheSamba. Check out or local group as well http://www.norcalaircooledgroup.org/ _________________ Jahnai Pearson - VW Restoration Technician
Current ownership (always changing):
60 Double Door Panel
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
79 Dasher Wagon
82 Quantum Coupe
96 Golf GL |
Posted: Sun Nov 07, 2010 11:43 pm Post subject: |
| Eric&Barb wrote: |
You can get into trouble advertising in the forums.... |
Oops, sorry. Would a later model air filter like this: http://www.thesamba.com/vw/classifieds/detail.php?id=1026789 fit or do I need to get an early style? I'd muh rather spend $20 than $100. |
EODinert Samba Member
Posted: Mon Nov 08, 2010 7:02 am Post subject: |
Just get a cheap paper filter until the proper filter finds you at the right price. _________________ '61 rag top beetle, '73 type 181, '66 13 window deluxe |
74 Cosa Samba Member
Joined: June 06, 2006 Posts: 535 Location: The Midwest
Posted: Mon Nov 08, 2010 7:31 am Post subject: |
Isn't it fun to take that first drive in your new ride?
Have fun! |
chrome Samba Member
Joined: March 21, 2003 Posts: 746 Location: back in NorCal
| RPGreg2600 wrote: |
| Eric&Barb wrote: |
68 on ait cleaners sit on a uh table i guess, while your style hangs from the 2 hole bracket to the right of the engine _________________ 65 21 window
57 T1 ragtop
58 ghia vert
68 fastback
73 Thing
74 Thing
54 chevy 210
63 mercury meteor wagon |
Posted: Mon Nov 08, 2010 8:17 am Post subject: |
Paper air cleaner will do in a pinch, but stock works much better.
You should be able to piece a 1964-67 setup together for much less than $100. _________________ In Stereo, Where Available! |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15521 Location: Casa de Oro, California
Posted: Mon Nov 08, 2010 8:20 am Post subject: |
| Not bad at all. Be safe and dive in. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3454 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Nov 08, 2010 9:27 am Post subject: |
| Eric&Barb wrote: |
Metal fuel line, and new German cloth covered flexable fuel line. |
Or get the correctly sized fuel line that will not fail in a year with the US fuel blends. |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Mon Nov 08, 2010 9:40 am Post subject: |
| ToolBox wrote: |
| Eric&Barb wrote: |
so the german hose will fail in a year with US fuel? What do you use? _________________ 1957 Beetle
1966 Bus |
Posted: Mon Nov 08, 2010 1:42 pm Post subject: |
Hey guys, thanks for the advice, I will try a paper filter for now and keep an eye out for a stock oil bath. I know eric from nor cal relics through a Land Rover group I belong to, I'll have to poke around is pile of parts.
Anyway, another question. I just pulled the motor to replace the rear main seal and any others I can easily replace. I noticed that the bell housing on the transmission has ben ground out larger than stock. What would be a reason for doing it? Only thing I can think of is to fit a later model engine if they have a bigger flywheel?
Here is the engine number, anyone know what engine that would be? I'll try doing a search.
orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1518 Location: South Hadley Mass
Posted: Mon Nov 08, 2010 2:03 pm Post subject: |
6v to 12v grind to fit the bigger flywheel? _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation.
RIP Big Jack - thewalrus |
Adam Samba Member
Joined: November 08, 2009 Posts: 624 Location: Petaluma, Ca
Posted: Mon Nov 08, 2010 4:59 pm Post subject: |
| Was this the one in Petaluma? |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72032 Location: Phoenix 602
shawn407 Samba Member
Joined: March 10, 2008 Posts: 131 Location: Brandon,FL
Posted: Mon Nov 08, 2010 6:53 pm Post subject: |
| The trans was definately ground out because it was originally a 6 volt setup. It's very common and you have nothing to worry about. I see this all the time at work. |
Clara  Samba Member
Posted: Mon Nov 08, 2010 7:17 pm Post subject: Re: Just picked up a 66 bus |
| RPGreg2600 wrote: |
That shit'll buff out!
Sweet bus  _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Mon Nov 08, 2010 7:24 pm Post subject: |
| Adam wrote: |
yes _________________ Jahnai Pearson - VW Restoration Technician
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
79 Dasher Wagon
82 Quantum Coupe
96 Golf GL |
