brent239 Samba Member
Joined: September 15, 2004 Posts: 145 Location: Utah...
Posted: Sat Nov 06, 2010 12:12 pm Post subject: AAZ into a 88 Weekender, conversion thread |
So We're replacing a 2.5 suby with an almost new aaz. It is behind an automatic. We're figuring out the rpm situation, first to be solved with 16" wheels.
We have on our hands now, a 50* kit out of I believe a 83 diesel van, a Kennedy adapter plate aaz to an automatic vanagon, and the flexplate to bolt to the diesel also from Kennedy.
I'm starting this today, 1st problem, left side motor mount hits the turbo, so Ive seen the solution here, any other not $300 solutions?
http://cgi.ebay.com/ebaymotors/VW-Vanagon-diesel-c..._500wt_956
Any other problems Im gonna run into?? any good threads I can look at? Pics to follow. pretty excited about this, after this is done, the 2.5 is going in my 88 westy behind an automatic, and we'll have a couple sweet vans  |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10484 Location: Orbiting San Diego
Posted: Sat Nov 06, 2010 1:27 pm Post subject: Re: AAZ into a 88 Weekender, conversion thread |
Most AAZ conversions do not have this interference. Only the early models of the AAZ use the turbos with internal wastegate actuator that hit the mount. Sorry. Where did you get the AAZ?
Mark
| brent239 wrote: |
Posted: Sat Nov 06, 2010 2:48 pm Post subject: |
| supposedly its from germany, but yeah it has the actuator internally, the mounts been ordered though |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10143 Location: Where?
Posted: Sat Nov 06, 2010 8:18 pm Post subject: |
K14 will be an extreme interference. A couple IMO easy solutions include either swapping on a later T2 or a K03 with matching manifold or modivying the mount. Easiest way to modify the mount, IMO is to chop off the end of it and add an appropriately sized/bent/drilled flat to the bottom of it bolted to the mounting bracket with reinforcement on the inside. Total project cost, $50 + time 1 hour.
Add a spacer under the front carrier bar mounting point to return the engine geometry to stock. |
danno Samba Member
Joined: November 07, 2005 Posts: 184 Location: Comox BC
Posted: Sat Nov 06, 2010 8:24 pm Post subject: |
Was there something wrong with the 2.5 behind the auto just asking because I was thinking of going this route. _________________ Dan
Comox BC
86 Wolfsburg Weekender
92 Golf 4dr
93 Beta Synt Trials Bike. |
canasync Samba Member
Posted: Sat Nov 06, 2010 8:42 pm Post subject: |
Hey Danno,
Let me know if you would like a 2.5 Suby swap. I have one for sale in Langley, BC. It is currently in my syncro and can be seen running. PM me if you are interested. |
vweggie Samba Member
Joined: May 01, 2007 Posts: 219 Location: End of the road, Vancouver Island
CHARLIE-DONT-SURF Samba Member
Joined: November 16, 2007 Posts: 335 Location: Cow County, UK
Posted: Fri Nov 12, 2010 4:44 am Post subject: |
| what torque convertor are you using to go with the diesel engine ? |
Posted: Mon Dec 06, 2010 12:48 pm Post subject: |
Diesel bolted up today , Its a stock vanagon torque converter. we just mounted up a set of 215/70/16, theyre on a suby 2.2 right now, way too big for that but gonna be sweet on the diesel. rear brakes mounted up too.
not gonna answer the 2.5 question, but its mounted up in my westy now, Tom finished up the repair of the harness last night and should be here real soon.
Soo back to the diesel, the bars had factory holes in the 87 and almost fit perfect. little bending fits good now, only problem we ran into was the injection pump sits above the lid , we have a modded lid already but whyyyyyyyy??????? sorry for the bad pic, have to get back to work. I'll flip it later
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19104 Location: Retired South Florida
Posted: Mon Dec 06, 2010 12:55 pm Post subject: |
| I don't believe the vanagon diesel ever came with an automatic. On the 82 and 83 diesel vanagon delivered in the US, the nose of the manual transmission sat high. Looking at a side view of the engine and transmission, the engine appeared to be drooping like a dirty diaper. Someone posted some drawings of the differences. If the pump should clear the vanagon cover, then the engine is mounted to high probably because of the automatic front mount. Thanks for the update. |
avdem Samba Member
Joined: January 22, 2009 Posts: 70 Location: Western Norway
Posted: Mon Dec 06, 2010 1:32 pm Post subject: |
There are a few vanagon jx diesels with automat in Europe. So it is possible to do this using original parts. Mostly used in vans specially made for the german postal service. And what is known as Berlinertaxis. I do think that even the Norwegian postal service had a few of them.
About as rare as hen teeths.... |
Posted: Mon Dec 06, 2010 2:47 pm Post subject: |
| I do not believe there were any stock vanagon diesel automatics in any of the markets. I would welcome you to prove me wrong on that tho. Please post links or pictures. On a similar note, despite my disbelief I recently found out there was a counter-clockwise rotating water pump manufactured for the inline 4's in some markets so I'm open to correction, but would need more info to alter my belief about the non-existance of stock automatic diesel vanagons. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7301 Location: Honolulu,Hawaii and France
Posted: Mon Dec 06, 2010 2:49 pm Post subject: |
Interesting!!I never heard of automatic diesel vanagons,even on small production
For the clearance under the lid about the injection pump,remove that ugly plate,modify the accelerator lever for the cable,and cheat one teeth back against the cylinder head on the timing belt (all timed together off course )and that fits without any modification of the lid.
Otherwise a little cut with a router and a plate on top will allow you some clearance without sacrificing comfort under the mattress if you have one for sleeping.
Bye! |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Mon Dec 06, 2010 3:55 pm Post subject: |
my end throttle assembly is barely higher than the lid. If I put things like flats of water/pop, etc... back there I have to put them on the right side otherwise my throttle revs high. When I took it to Giles at High Performance Diesel he suggested a cut out and someone else in here built a rectancle and lifted the lid a few inches. I don't think that's necessary but I guess it depends on the installation. I have no problems as long as I don't stand on the engine hatch  _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
Posted: Mon Dec 06, 2010 4:37 pm Post subject: |
there's never been a factory diesel automatic, only a few people to wander in that direction. if this auto dont work out, a freeway flyer's going in
we have a raised lid on hand, I like alika's ingenuity! but I'd really hate to mess the timing up.
why would you need a counter clockwise water pump?? we didnt change the direction of the motor? Everybody always overthinks things here, its funny , Me included at one point in time.
so why would the samba flip my picture when the orientation is correct in my computer |
GratefulGerman Samba Member
Joined: November 17, 2009 Posts: 21 Location: Germany
Posted: Tue Dec 07, 2010 8:54 am Post subject: |
There“ve been a few automatic diesel T3 as test-cars. They did run in west-berlin short before the reunion of germany and are known as the legendary
berlin-taxi.
never went in regular production |
Posted: Tue Dec 07, 2010 10:10 am Post subject: |
| Thanks for the link. Good to know. I wish they had sold them on the open market. |
avdem Samba Member
Posted: Tue Dec 07, 2010 2:48 pm Post subject: |
From a norwegian forum. Try google translate.
This guy is selling an original diesel autobox with starter.
Says it is coming from a norwegian postal van. As he states "probably even more rare than the berliner taxi"
http://www.vwbus.no/forum/viewtopic.php?f=7&t=...el#p158252 |
tclark Samba Member
Posted: Sat Dec 11, 2010 9:18 am Post subject: |
Question for the Euros on this thread...
Any of you guys know if there was special gearing used in this berlin taxi auto diesel or how they got the revs down ? _________________ 89 Westy with TDI AHU 1.9 manual lots of mods
85 GL 1.9, auto (for sold) |
Posted: Tue Jan 04, 2011 1:56 pm Post subject: |
Update!
almost got it fired up today! The starter is not powerful enough . I have a Hi-torque starter here that doesnt work . another one that doesnt fit! so Im back to an 2.1 starter. doesnt have enough juice. even with a 20a battery charger hooked up. Im gonna add new ground wires at the battery and one more at the starter. What starter is stock on a td?
How about the glow plugs? I had a very complicated relay from an outside source and hooked it all up IAW his directions and it will not work. I'll just add a relay with a pushbutton. its gonna be way simpler. _________________ 88 westy suby 2.5 |
