jjjjjoey Samba Member
Joined: January 20, 2009 Posts: 152 Location: So. Cal.
Posted: Mon Dec 13, 2010 6:13 pm Post subject: What to use/do to clean engine? |
So I took my 1500cc out of my 67 while the body work gets done.
Now that its out and sitting in my garage what is the best way to clean it? And where should I be careful not to get water in?
[/img] _________________ ________
67 Ghia n00b |
DrakeB Samba Member
Joined: July 26, 2010 Posts: 245 Location: Here, obviously
Posted: Mon Dec 13, 2010 6:25 pm Post subject: |
I know somebody said in the Type 3 forum not to use vinegar as it will eat the case up and in the process create highly volatile hydrogen gas.[/list] _________________ Bondo? Bondo? We don't need no stinking Bondo!
How is it 'NOS' if it has been modified?
The Thread Killer. |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Mon Dec 13, 2010 6:52 pm Post subject: |
spray it down with simple green, or some other bio-degradable citrus cleaner. Let is sit for a while, and use some pressurized water to rinse it off.
don't stick the hose down the carb, and you should be fine. |
Posted: Mon Dec 13, 2010 8:12 pm Post subject: |
DrakeB wrote: |
I know somebody said in the Type 3 forum not to use vinegar as it will eat the case up and in the process create highly volatile hydrogen gas.[/list] |
No vinegar-check.
70 140 wrote: |
Will a waded up plastic bag seal those openings enough or should I try to plug it up with something more, like pieces of towel? _________________ ________
67 Ghia n00b
Z+9 Samba Member
Joined: November 20, 2006 Posts: 107 Location: Boise ID
Posted: Mon Dec 13, 2010 10:44 pm Post subject: |
I bought some Marine Clean, I used it to clean the pans... This thing is a miracle in a box. I have used it to clean up the BBQ, bathtubs, toilets, concrete, you name it. Just spray, let it sit for 10-15 min and scrub with a tooth brush. Dawn power dissolver works good too, Walmart, $2.99 _________________ 1956 Buick Century Coupe
1951 Ford F1
1974 VW Super Conv. |
analogmax Samba Member
Joined: September 27, 2006 Posts: 161 Location: Chandler, Arizona
Posted: Mon Dec 13, 2010 11:45 pm Post subject: |
I used some cleaner called purple power and then used heat paint for the final. The only thing I replaced was the push rod tubes.
Before:
After:
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
TC/TeamEvil Samba Member
Posted: Tue Dec 14, 2010 7:32 am Post subject: |
I have to agree, Purple Power is pretty amazing. I've had similar results with it. Spray it on, maybe do a little brushing with a stiff bristle brush (sometimes not) and hose it off. Once dry, all ready for paint and detail.
Engine bays, undercarriages, front ends, works just as well.
Luck,
T |
Posted: Tue Dec 14, 2010 10:14 am Post subject: |
I just used purple power and a brush then painted the case and other parts with heat paint. |
Jeckler Samba Member
Joined: September 27, 2005 Posts: 2718 Location: Mesa, AZ
Posted: Tue Dec 14, 2010 11:13 am Post subject: |
I used some generic Purple-Power-like stuff from Home Depot. I left the intake/exhausts open, but removed the rocker arms. The distributor and generator stand were still attached.
I knew I was starting it fairly soon after (6 months ), so just blew out the intake and exhaust with compressed air, then hosed them down with WD40. It runs fine.
_________________ Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote: |
I am the crabby old guy. |
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad. |
Posted: Tue Dec 14, 2010 4:50 pm Post subject: |
Nice looking engines.
Was the Purple Power diluted with water or did anyone use the full strength straight from the container way....? _________________ ________
67 Ghia n00b |
Posted: Tue Dec 14, 2010 5:08 pm Post subject: |
Full strength in an old plastic spray bottle. |
Jasonscool Samba Member
Joined: December 06, 2010 Posts: 69 Location: Nashville
Posted: Tue Dec 14, 2010 5:35 pm Post subject: |
I have used toilet bowl cleaner in the past. As long it doesnt sit in a puddle in it over night it works great. It will actually etch the metal but not too much. The etch will give your high temp paint a better surface to adhere to. My .02 |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5734 Location: Inwood WV
Posted: Tue Dec 14, 2010 6:17 pm Post subject: |
I used Purple power also. My engine was COATED in oil. We took it apart down to a short block, replaced all the seals, purple power, and pressure washed it. I powder coated the tin, and intake.
The Ghia went from the way I got it a in Jan of 09:
Then the way it looked after I cleaned it up a little:
To how it looks now:
I'm not 100% done yet, but WOW. What an improvement. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Tue Dec 14, 2010 6:31 pm Post subject: |
By the way the case was painted on my engine. I removed the paint. It was pealing and looked awful. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Tue Dec 14, 2010 10:40 pm Post subject: |
djkeev wrote: |
Jeckler wrote: |
Now this photo looks like a realistic view of an engine cleaned with a product. That is why I questioned if the flawless one was blasted or painted.
Looks like it worked good, you say Purple Power LIKE. What was it exactly?
dave |
Geez Dave, you gonna shine a light in my eyes during this interrogation too? Don't I get a cup of coffee or something?
If the link works, it was this stuff. If the link doesn't work, it was ZEP Industrial Purple cleaner and degreaser. I diluted it, partly so it would last longer, and partly because I wanted my skin to last longer as well. I think it was 3 or 4 to 1.
This is what it looks like now, if anyone's wondering.
bill may wrote: |
Posted: Wed Dec 15, 2010 6:48 am Post subject: |
Jeckler, no interrogation, we all have Home Depots, if this stuff works so great I want to know what it was so I can copy you. Purple Power LIKE doesn't sell product, ZEP Industrial Purple Cleaner does.
Your engine looks great! I don't like perfect looking engines, not real, too shiny and clean. Too clean makes me think of a used car lot where they glossy clear coated EVERYTHING under the hood, always makes me think, what are they hiding with all of that shine? The engine cases never looked that perfect silver when new. Also, If a car is 50 years old, I haven't any problem with it looking like it is a 50 year old well kept engine.
For me, yours has just the right amount of clean and shine. Maybe put the stickers back on the fan shroud and air cleaner but outside of that, excellent.
Ghia
Vanagon
Beetle
noexit Samba Member
Joined: September 18, 2006 Posts: 329 Location: Tacoma, WA
Posted: Wed Dec 15, 2010 7:50 pm Post subject: |
djkeev wrote: |
dave |
He did say in his original post that he painted it with heat paint... |
