vw_nick Samba Member
Joined: August 21, 2005 Posts: 391 Location: Nashville, TN
Posted: Fri Sep 03, 2010 9:03 pm Post subject: |
from what I remember, the upper stub axle is held to the gear with a bolt & washer (bolt through the gear into hole drilled and tapped into the axle... it was one of the questionable parts of the setup but seemed to do fine. _________________ Nick |
tamir Samba Member
Posted: Tue Sep 28, 2010 1:32 pm Post subject: How can I setup Disk brake kit on the reduction box? |
I have noticed that a few guys where able to install a Disk Brake on the Reduction box. So far all the suppliers I have called do not carry a Kit for it and they did not hear about anyone wanting to do that....
Any help or direction will be appreciated.
thanks,
T. |
joescoolcustoms Samba Member
Posted: Tue Sep 28, 2010 1:54 pm Post subject: Re: How can I setup Disk brake kit on the reduction box? |
tamir wrote: |
thanks,
T. |
I have read that a Type 3 drum rear brake system will fit on a small nut RGB. Might check to see if there is a disc kit made for the T 3 that may work on the small nut RGB. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Tue Sep 28, 2010 5:06 pm Post subject: Re: How can I setup Disk brake kit on the reduction box? |
joescoolcustoms wrote: |
tamir wrote: |
thanks,
T. |
I have read that a Type 3 drum rear brake system will fit on a small nut RGB. Might check to see if there is a disc kit made for the T 3 that may work on the small nut RGB. |
That is some great info to know...I am hoping that someone else might key in with more knowledge of this swap. |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Wed Sep 29, 2010 5:20 am Post subject: |
If we're talking small nut reduction stuff, it's all the same as regular bug rear brakes. It's got the same 4 bolt flange and stub axle. The problem is a disk brake caliper and bracket hits the reduction box. You'll need to build a caliper mount, but it can definitely be done. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
tamir Samba Member
Posted: Wed Sep 29, 2010 8:13 am Post subject: calliper mount plate for reduction gear box |
I do not have the means to design and cut such a plate.
does anyone out there can help with that process (for fee)?
thanks,
T. |
Posted: Wed Sep 29, 2010 8:20 am Post subject: Re: calliper mount plate for reduction gear box |
tamir wrote: |
thanks,
T. |
I bought a set of brackets to adapt disc's to a thing front spindle from kubelmann. He may make a set for you.
http://www.thesamba.com/vw/classifieds/detail.php?id=986381 _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
tamir Samba Member
Posted: Wed Sep 29, 2010 8:55 am Post subject: |
Thanks, I just emailed kubelmann for help. |
Kix Samba Member
Joined: July 27, 2008 Posts: 23 Location: Southern Burbs of Denver
Posted: Wed Sep 29, 2010 11:26 am Post subject: |
Dude, this is hot sweetness.
I am looking to swap the bus tranny with redux out of my 65 bajaghia, too bad I cant find anyone to do something like this.
Oh well, IRS here we come. |
Posted: Wed Sep 29, 2010 11:59 am Post subject: |
does anyone know if the 914 rear rotor hub spline is the same size to fit the type 3 axle. |
Posted: Tue Nov 30, 2010 5:05 am Post subject: |
the setup survived another weekend at the nearby OHV park... though we did notice loose swing plate bolts on one side after we got it back up on the trailer. Here's a very short video from when he got it up onto a section of rock garden for a photo op. Wish I thought to record it from the beginning... maybe next time.
oh, not sure if I mentioned this before but this is large nut RGB, which is why he made hubs out of the old brake drums....
earthquake Samba Member
Joined: January 10, 2008 Posts: 4001 Location: SANDY VALLEY, NEVADA
Posted: Tue Dec 21, 2010 10:03 am Post subject: |
There's a monster baja on e-bay right now with dual RGB's and IRS, it looks like a real hack job.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Tue Dec 21, 2010 10:26 am Post subject: |
earthquake wrote: |
Casey |
Can you state how it is listed? I searched but could not find it. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Dec 21, 2010 3:40 pm Post subject: |
Holy Rat Snot Buttman!!! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
rubsterob Samba Member
Joined: December 31, 2009 Posts: 755 Location: Boise Idaho
Posted: Tue Dec 21, 2010 7:43 pm Post subject: |
haha that thing looks pretty bad ass. only because its still a vw and not a bronco with a bug body _________________ First car orange '72 class 11 lookalike |
dspikes Samba Member
Joined: September 25, 2010 Posts: 13 Location: bastrop la
Posted: Fri Dec 19, 2014 6:58 pm Post subject: Rgbs How much hp they take? |
I know this is old post how did rgbs hold up? How much hp can they take? |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Fri Dec 19, 2014 8:46 pm Post subject: rgb |
Your right it's an old post but it is freakin excellent. I want to do that now, only on my 003  |
Posted: Sun Dec 21, 2014 5:54 am Post subject: Auto and rgbs |
I have built a buggy using the 003 3 speed it worked great. I am gathering up parts to build one with subaru at transmission would not have to flip r/p using rgbs with 1.26 ratio & 3.9r/p total final drive 4.91 rear. Any reason it would not work?automatic should help on wheel hop? I am building complete frame with possibilty of awd. Thanks for any advice |
Posted: Sun Dec 21, 2014 11:01 am Post subject: Re: Auto and rgbs |
dspikes wrote: |
Using RGB's at the wheel does require a reverse set up on the transmission do to only having two gears in the RGB that reverses rotation. So, yes on the Subaru Transmission, you can leave it stock.
As far as wheel hop, it is not the transmission that produces the wheel hop, it is the suspension design. In stock designed form, the RGB suspension wheel hops rather easily. John Johnson produced the No Hop set up to modify the rear suspension pivot points changing the design instant center and eliminated the wheel hop. If you will be making a suspension to use the RGB, you can design out the wheel hop. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
