CLK wheels
Page: Previous  1, 2, 3, 4, 5 ... 65, 66, 67  Next
j_dirge
j_dirge is offline
PostPosted: Mon Dec 27, 2010 1:36 pm    Post subject: Reply with quote
wallanoise wrote:
You all may not like to here this but those wheels just don't look that great. To me, they look cheap. What are the benefits to these wheels?
There was a time not too long ago when they came very cheap. Almost free.
Factoring in the low cost and strength to wieght ratio of the forged alum., they were possibly the best almost-bolt-on wheel available.
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Dimitrios
Dimitrios is offline
VisPacem : Thank you for your comments Smile
Forged wheels are superior compared to cast ones.Ligther, stronger and way more expensive in production.
Used Porsche 911 & VW 091 & 094 transaxles!!!
Christopher Schimke
Well Jim, I don't know what those are. Again, they are similar to the "CLK" wheel discussed here, but definitely different from the others. I looked up those ads you posted and they don't say what size or offset they are, just that they are 16". Are these the 16x7.5 ET35 wheels that you asked about earlier?
Here are all three lined up with the American version of the '98-'00 CLK320 wheels first, then the unknown ones you just asked about and finally the S Class W220 (assumed) wheels :
stevey88
stevey88 is offline
PostPosted: Mon Dec 27, 2010 2:00 pm    Post subject: Reply with quote
I sort of agree with you on the looks. I picked up a set of four 2002 CLK wheel and I think they look a little better. All four has curb rash and its $100 for all four. 16 X 7 ET 37, made by Ronal.
Steve
87 Westfalia full camper 4 speed
Dimitrios
PostPosted: Mon Dec 27, 2010 2:15 pm    Post subject: Reply with quote
Hmm, any chance to take a look on the backside to share the part # and other markings ?
TIA,
Jim
Christopher Schimke
PostPosted: Mon Dec 27, 2010 2:17 pm    Post subject: Reply with quote
Looks aside, besides the benefits already stated about strength, one of the main reasons the forged CLK320 wheels remains a good choice for the Vanagon has to do with the way it is machined. If you look at the later model CLK wheels pictured above, you will see that the thickness of the wheels where the lugs pass through is very thick (22-25mm) whereas the same area on the forged CLK320 wheels is a much thinner 5-6mm. This means that the later model CLK wheels (and all other Mercedes alloy wheels) will require the installation of longer wheel studs while the forged CLK320 wheels do not (as long as spacers are not used). Changing out the rear wheel studs isn't a bad job, but it's a real pain, and very expensive, to do the fronts on a Syncro.
So while the looks may not be to everyone's taste, it's the all around construction of the wheel that makes it a good choice, not just the fact that they are forged.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon Dec 27, 2010 2:20 pm    Post subject: Reply with quote
Perhaps a better forged option would be the factory Fuchs rims found on the Audi C4 Ur S4/S6 cars.
There was a dirt cheap set on the Seattle CL recently...kickin' myself for not following up
Casey--
'01 Weekender --> full camper
y u rune klassik?
Christopher Schimke
PostPosted: Mon Dec 27, 2010 2:22 pm    Post subject: Reply with quote
TIA,
Jim
Are you talking about the wheels that stevey88 posted?
If so, they are a 16x7 ET37 from a '01-'03 CLK320 part number 208 401 0702. See my post above for fitment issues on a Syncro.
Don't confuse them for the nearly identical looking 17x7.5 version from the '01 SLK.
Christopher Schimke
PostPosted: Mon Dec 27, 2010 2:30 pm    Post subject: Reply with quote
Those are a great wheel too, but they need to have their centerbores machined larger (for use on a 2wd or a Syncro without spacers) and they need spacers because of the high offset (45mm). Great wheels, but in terms of complexity/cost of installation, they just take more to get them installed compared to the forged CLK320 wheels. The Audi Fuchs are also 15" compared to 16" in case that matters to anyone considering them.
Zeitgeist 13
PostPosted: Mon Dec 27, 2010 2:40 pm    Post subject: Reply with quote
I thought those Fuchs also came in 16"?
I agree that Mercedes rims seem so much easier to fit, since the center bores aren't as problematic. I just wish MB had commissioned better looking forged rims. The CLKs remind me of the "fancy" steel rims found on some '70's era Beetles
Casey--
y u rune klassik?
Dimitrios
PostPosted: Mon Dec 27, 2010 3:31 pm    Post subject: Reply with quote
No, I mean the "correct" ones (the forged 7x16)...
I hate to bought an incorrect set...
Rgds,
Jim
Christopher Schimke
PostPosted: Mon Dec 27, 2010 3:47 pm    Post subject: Reply with quote
Rgds,
Jim
Ah, sorry, I misunderstood.
The part number for the forged CLK320 wheel is 208 401 0002. It's stamped near the lug holes on the back side of the wheel.
Dimitrios
PostPosted: Tue Dec 28, 2010 7:07 am    Post subject: Reply with quote
Thank you Loggy ! I will let you know the results Smile
spaeth
spaeth is offline
PostPosted: Tue Dec 28, 2010 9:13 am    Post subject: Reply with quote
Not that I want to talk more people into CLK wheels, but as Loogy stated it is the quality that sells these wheels. I had a set of Audi 5 spokes which I loved the looks of and a set of CLK wheels which I have never been fond of. After handling the wheels for a few days the CLKs won me over. They were way lighter, were going to be easier to fit and the machine work inside the rim is absolutely meticulous.
I will take a better built, stronger lighter wheel over a better looking wheel any day.
Craig
whynotvw
whynotvw is offline
PostPosted: Tue Dec 28, 2010 9:28 am    Post subject: Reply with quote
Craig
x2
fatboypaul
fatboypaul is offline
PostPosted: Tue Dec 28, 2010 7:17 pm    Post subject: Reply with quote
I need two of these CLK spares, anybody in the SF Bay area want to split a set of four with me?
Cheers, Paul.
Lotek
Lotek is offline
PostPosted: Tue Dec 28, 2010 7:42 pm    Post subject: Reply with quote
Cheers, Paul.
I could use one. I'm in LA, but get up that way from time to time.
Christopher Schimke
PostPosted: Fri Dec 31, 2010 5:31 pm    Post subject: Reply with quote
Alrighty then, I have been doing some research on Mercedes Forged wheels, and Dimitrios, it appears that the wheels that you posted a link to are forged after all. I don't know what car they are from, but they appear to have 14mm lug holes which would mean that the stock Vanagon steel wheel lug nuts would be appropriate for them. Those other CLKish looking wheels are also forged.
Neither of those two wheels were imported to the US. Here are a few other non-US, Vanagon-worthy, Mercedes wheels that are forged.
15x7 ET37
16x6 ET39
16x7 ET32
16x7 ET33
16x7 ET34
16x7 ET43
16x7.5 ET42
16x7.5 ET42
syncroid
syncroid is offline
PostPosted: Fri Jan 21, 2011 4:33 pm    Post subject: Re: MBZ 16" CLK Wheels Reply with quote
loogy wrote:
Leisuredoc wrote:
The rookie question! What modifications (spacers, hole enlargements, etc.) are required to mount MBZ 16" CLK wheels to a 2wd Vanagon?
Thx!
If you run 205 or some 215 tires, you can get away with no spacers. Some 215s and all 225s will require a 5-7mm spacer, at least on the front. If you don't run spacers on the rear, you can use the stock length wheel studs. Any thickness spacer on the rear will require longer wheel studs. You will need the correct small ball seat lug bolts and nuts and you will have to drill the lug holes larger. I recommend using a 37/64" drill bit to drill the lug holes, but people have gotten away with a 9/16" bit. With a 9/16" bit, if the holes are not drilled fairly straight, the wheel studs and lug bolts can hang up on the holes and you don't want that. 37/64" give you just hair more room.
Loogy, when drilling the lug holes, can that be done "free hand" or should it only be done on a drill press?
Christopher Schimke
PostPosted: Fri Jan 21, 2011 4:39 pm    Post subject: Reply with quote
While a drill press makes the job safer, easier and generally more accurate, doing it freehand can get the job done all the same. The biggest concern is to drill through the wheel as straight as possible and deburr the holes when you are done. The drill bit can tend to "catch" when drilling by hand, so go slowly and be careful.
Page 4 of 67
