Mrcole's Build Page - My First Project
Page: 1, 2, 3, 4, 5, 6  Next
mrcole
mrcole is offline
PostPosted: Sun Jan 16, 2011 6:43 pm    Post subject: Mrcole's Build Page - My First Project Reply with quote
I just purchased my first sand rail and I thought I would jump into introductions with a build page. I'm an electrical engineer working for a lithium power systems company ( Li-ion batteries for HEVs, PHEVs, EVs, Grid Energy Storage, etc) here in the heart of Indiana. I've been interested in sand rails for the past few years - just never took the plunge and bought one until now. I would say my knowledge on them is novice at best. I've spent a lot of time lurking in the forums and reading up online and with a few books. I've tinkered on a few before and can generally find my way around the parts.
I ended up buying a 1915CC with dual Dellorto carbs 44IDF, swing axle trans with (at least I was told) 3.88 close ratio gearing (low miles and rebuilt engine and trans that is street legal. The guy I bought it off of had a lot of the receipts and paperwork to back of his claims of what he had invested into it. I still feel like it was pretty beat up once I ended up getting it home (more on that later). When I got home and was about ready to back it off the trailer, bam, the clutch cable split open and started spraying hydraulic fluid everywhere when I depressed the clutch...great. I noticed the kingpin was in far worse shape than I had initially thought and ended up having to purchase a new one because the estimate to have it rebuilt was only a few $$ under the new price.
Anyways, I have it sitting in the garage and have begun to tear some things down. My plan is to tear it down completely for engine detailing, sandblasting frame, powder coating, etc. What do you guys think of my purchase - is it a diamond in the rough or junk? I ended up paying about $2400 for it (some trades were involved with that).
So far I've cleaned up a lot of the welds, welded on a new shifter box, have some new parts on the way, got my new kingpin in today and started making notes on what to do/fix next.
Does anyone know what type of frame I have? I heard someone who was looking at my rail murmur "venture frame"?
I'm not sure how "new" the kingpin front end is I bought. Looks like it was pulled or rebuilt and then dipped in this cruddy black paint. I'll have to end up sanding/cleaning it to repaint it eventually. The spindle area is very stiff. I can't even turn it with my hand. Is this normal on new kingpins (needs broke in)? There are two spots on the beam with little rubber bumper things over them; these weren't on my last kingpin - any idea on what they are used for?
It came with the snubber legs (place where you normally put on some bump-stops) already removed - is this normal? And now, pics!
As it sat before I bought it:
Now in my garage!
New shifter box welded in:
New kingin front end picked up:
So what do you guys think? Thanks!
ts39136
ts39136 is offline
PostPosted: Sun Jan 16, 2011 7:25 pm    Post subject: Reply with quote
Looks like a fun project, I like the silver paint.
What size rear tires are those? Are they TSL's?
Welcome.
My Build Page
mrcole
mrcole is offline
PostPosted: Mon Jan 17, 2011 5:00 pm    Post subject: Reply with quote
Thanks for the welcome. They are super swampers, 32x9 from what I can see. While looking for sand rails, I usually ran into tires that were much wider than this.
Jowlz
The Anti-Purist
Jowlz is offline
PostPosted: Mon Jan 17, 2011 5:27 pm    Post subject: Reply with quote
I'm also digging the swampers in that size.. What size (width) are the rear rims?
The paint on the beam looks like transportation coating. You will want to clean it off and repaint. The spindles should loosen up with use. Are the fittings on the beam you referred to the adjusters in the center of the beam?
I'm really amazed that it had plates on it when you got it. The spindle mount front rims and tires are both not DOT approved....
All in all it looks like a great project. You didn't do too badly on price. It will look great all painted and cleaned up!
The honey-do list put my project on hold.......
mrcole
mrcole is offline
PostPosted: Mon Jan 17, 2011 6:53 pm    Post subject: Reply with quote
From eyeing the rims (compared to the tire width) they look to be about 7 inches wide.
Yes, I'm talking about the adjusters...but what exactly do they adjust (probably a dumb question)?
As far as street legal, I was concerned as well with the spindles among a few other things, but I guess it came from a small Indiana town where everyone knows everyone, including the law enforcement type so my theory is it got approved this way or was changed later down the road.
I picked up an engine stand yoke for VW engines off ebay and grabbed a 1000lb engine stand from harbor freight so I think I'm set to pull the engine. I want to have things off and welds cleaned up in about two weeks to get it all off to the sandblaster/powder coater.
I bought some larger racing seats with headrests as the rail came with the uncomfortable (well, at least I think they are) fiber glass bucket seats. A problem though...I set the seat inside the rail and plopped down just to realize my head hits the top crossbar section. It looks like my only options here are to use the fiberglass bucket seats or have the top of the rail cut off and reworked. Has any ever ran into this issue before?
tanner_122
tanner_122 is offline
PostPosted: Mon Jan 17, 2011 7:34 pm    Post subject: Reply with quote
The adjusters will raise ur ride height
And I hate fiber glass seats so uncomfortable... Saw a thread having the same seating prob as u if I find it I'll post it
91 jeep Cherokee "TANK"
mrcole
mrcole is offline
PostPosted: Mon Jan 17, 2011 8:31 pm    Post subject: Reply with quote
Thanks,
I was looking at trying to lower them but there just isn't any room to do that. I was actually thinking of raising where the bucket seats are as it seems one well placed rock/tree/mound/etc on the underside would feel like a horse kick in the a$$.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Mon Jan 17, 2011 8:40 pm    Post subject: Reply with quote
It is a Hi-Jumper/Prowler's Sand Sprite II.
The nylon tubing use in hyd. clutch system does not like sun. Will crack and break.
Have fun with it.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
mrcole
mrcole is offline
PostPosted: Mon Jan 17, 2011 9:12 pm    Post subject: Reply with quote
Have fun with it.
Thanks! I was having a hard time figuring out what type it was.
Yes, the tubing split just as I was trying to back it off the trailer and I was by myself so that made it interesting trying to get it into the garage.
Is there anything specific I should know about this frame, anything unique other than hating people over 6' who like comfy seats? Smile
Jowlz
The Anti-Purist
Jowlz is offline
PostPosted: Tue Jan 18, 2011 1:49 pm    Post subject: Reply with quote
The spindle mounts are ok for sand use. Being up north like I am there is probably more dirt/mud/rocks than sand. I replaced the spindle mounts on my rail with standard rims. I still used tractor tires and am fairly happy with that set up. On my blue rail I have no front brakes, only a steering brake set up. Let's just say it gets interesting with no front brakes. My father in law used front brakes on his rail. It is much much better stopping than my rail. I can't imagine running on the road without front brakes.
One other thought is that the PO registered it, so he could pull it out to off-road areas with a tow bar.....
jsturtlebuggy
PostPosted: Tue Jan 18, 2011 4:38 pm    Post subject: Reply with quote
I had the same Hi-Jumper frame for use in the sand. And yes the cage is low. Being mine was for sand use only I mounted the fiberglass buckets so bottom of them was below frame rails. It was quite the feeling when you went over a razor back and felt the sand under your bum.
I have seen some who bent pieces of tubing to fit under the seats with it welded in place, and attach aluminum panels for floorpan/skidplate.
They did build a taller cage chassis.
Joseph
Elrod Motorsports
supervert
supervert is offline
PostPosted: Tue Jan 18, 2011 6:47 pm    Post subject: Reply with quote
mrcole, not to be nosey, where are you located at in Indiana? I live/work in the Bloomington/Ellettsville area (approx 50 miles south of Indy). I know a few people who can probably help with your questions as well. Your project looks good, keep plugging away at it, my build took me about 1-1/2 years. Good luck!
mrcole
mrcole is offline
PostPosted: Tue Jan 18, 2011 9:41 pm    Post subject: Reply with quote
I live in Indianapolis on the westside, right by Avon. I also frequent Buggyworks in Martinsville - I bet you've been there before! Anyone I can be pointed to for information would be great, especially if they are near by. I'll be more than happy to provide the brews if anyone feels like they want to join in with the wrenching Smile
I have already started some work to add some support to the seat area. The seats already sit below the frame rails and here in Indiana I'll run into mud/rock before I hit sand. I just want to put my mind at ease about it. I am still contemplating making the head-room rails taller, but that may come at a stage-2 design as I am hoping to have things ready around April for a Silver Lake dunes trip to Michigan.
supervert
PostPosted: Thu Jan 20, 2011 10:12 pm    Post subject: Reply with quote
Well, greetings from a fellow Hoosier! I definitely know Colby and the guys at Buggyworks. They know what they're talking about and are good guys, they just look kind of funny! Laughing If you want to see pix of my car, ask Colby to show you the screensaver of the black and blue convertible baja, it's mine. Anyway, I know a couple of local guys that could prob help with any questions you might have, ask away, we're here to help!
Jeff Rihm, aka "supervert"
GreeneHoosier
GreeneHoosier is offline
PostPosted: Fri Jan 21, 2011 5:27 am    Post subject: Reply with quote
More Hoosiers!!
Cool, we seem to be a bit rare on here.
Good to see some more VW based off-roaders in the area.
Love the rail, I need another one. You will enjoy it.
1974 Super Beetle
40 Years VW enthusiast!
quadrazer
quadrazer is offline
PostPosted: Sun Jan 23, 2011 10:29 am    Post subject: Reply with quote
Well, if you don't make April, or even if you do, you're welcome to go up with a group of us the end of July. I'm planning on going to Silver Lake for a week then, but the big buggy gathering is on the 30th of July.
Your chassis windshield rake and low profile looks similar to a Berrien Venture, but I don't think it is one. Maily due to the rear engine hoop design. Here is a picture of the Venture:
http://www.berrienbuggy.com/id30.htm
At any rate, welcome to the forum. Lots of good people here that I'm sure you will find very helpful. Looking forward to seeing your progress. By the way, I'm next door in Ohio. Cool
I DID wash my hands....the rest is 'built-in' dirt!
My build: http://www.thesamba.com/vw/forum/viewtopic.php?t=409845
carlos_magnum
carlos_magnum is offline
PostPosted: Thu Jan 27, 2011 12:08 am    Post subject: Reply with quote
Nice first project. Welcome aboard.
mrcole
mrcole is offline
PostPosted: Sat Feb 12, 2011 2:07 pm    Post subject: Reply with quote
So the black crud on the new kingpin I bought is proving more than difficult to remove. Are there any issues with just taking it to a sandblaster to have the whole thing sandblasted? I know there are openings where the adjusters are and exposed bushings - will these be ok if covered?
Thanks.
Putting together my engine stand now to drop the engine. Using a 1000lb harbor freight engine stand with a vw adapter I'll bolt on. Pics to come.
58Dub
58Dub is offline
PostPosted: Sat Feb 12, 2011 2:20 pm    Post subject: Reply with quote
are you asking about sandblasting the beam? Yes you can do it...but I would disassemble it so it can the cleaned properly....that sand/media gets everywhere
58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project
riceman
riceman is offline
PostPosted: Sun Feb 13, 2011 6:28 am    Post subject: Im a newbie also. Reply with quote
Mr Cole, I'm a newbie also, next door in Ohio. Went to Silver lake last year with a buddy that has been asking me for 10 yrs.... Came home bought a rail.. Here is a pic of my first rail project (hopefully the link from Facebook works). I bought it last August and have done quite abit of work to it. The buggy has a fresh 1600 DP that runs great, with a bus three rib. The first thing I replaced was the shifter. I put a new nylon bushing in the back of the shifter boxas wel and installed a scat short throw shifer. What a difference over the stock one. Next was a rack and pinion, again another worthy improvement over the stock box, but mine was worn very bad. I am in the midst of installing an aluminum front beam with spindle mounts and fox shocks. The pic is white board used to mock up the Aluminum panels that we are currently fabricating. Again this will primarily be a sand toy. My question for some of you veterans is in regard to the bus engines. I buy most of my parts from Larrys off road in Dayton, Ohio and Appletree Automotive in MI near the dunes. I have noticed that there are not many parts mentioned on line or in their catalogs for bus engines. I know my stocker will be reliable, but if I wanted to go to one of the larger c.c. Bus or Porche engines, is there a huge difference in it compared to the 1600? Will it bolt up, Do the engine parts interchange as far as headers, sand seal pulleys, tins, intakes, etc? Sorry for writing the book. I was a little worried to get on here with my limited knowledge, but after 6 months of reading and researching I am still not clear, so I thought I would ask the experts.
[/img]http://www.facebook.com/photo.php?fbid=185987044774883&set=a.154189494621305.29893.100000907671717&ref=nf[img][/img]
Page 1 of 6
