SCZ9-1-1 Samba Member
Joined: May 20, 2003 Posts: 716 Location: Santa Cruz, CA
Posted: Thu Oct 29, 2009 7:30 pm Post subject: Last Year for Swing Axles in Ghias |
| Type II guy here wondering if you stylin Ghia folks could answer or know when the last year Ghias had a swing axle before going to IRS? I think I have a Ghia transaxle in my bus. The number stamped on the side starts with "AO" which might indicate a Ghia transaxle. |
Karmann_65 Samba Member
Joined: April 17, 2009 Posts: 537 Location: Lancashire, UK
Posted: Thu Oct 29, 2009 8:02 pm Post subject: |
An "AO" gearbox is indeed from a Ghia. "AO" is from a 1970 car.
This is mine....
Maybe someone else can chip in with when they changed from swing axle but I think this was one of the last. |
rustfree1967bug Samba Member
Joined: November 16, 2006 Posts: 3446 Location: minnesota
Posted: Thu Oct 29, 2009 8:23 pm Post subject: |
1968 should have been the last year just like beetles. _________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
IDA's...well... they talk dirty -MURZI |
Posted: Thu Oct 29, 2009 8:55 pm Post subject: |
This is a list for Beetle gearbox codes "unless otherwise stated". I'd love to know if it's wrong. I removed this box presonally from a '70 Ghia for the better 4th gear ratio. Seems to indicate that '70 was the change over year for Ghias. ??
AA 1200 4.375 From Chassis No 0 981 810
AB 1300 4.375 Up to 8/70
AC 1500 4.125 also some 1300 from 8/70
AD 1200 4.375 Limited Slip Differential
AE 1300 4.375 Limited Slip Differential
AF 1500 4.125 L.S. Differential >8/70; also some 1300 8/70>
AG 1200 4.375 Type 147 Fridolin
AH 1500/1600 4.125 IRS from 8/68 - 8/72
AK 1500/1600 3.875 Type 181
AL 1500-1600 3.875 Type 181 with LSD
AM 1300 4.375 Saloon and Cabrio from 8/70
AN 1600 3.875 Karmann Ghia with IRS from 8/70
AO 1600 4.125 Karmann Ghia from 8/70
AP 1300 4.375 LSD from 8/70
AQ 1600 4.125 LSD 8/70 - 8/72
AR 1600 3.875 Karmann Ghia with LSD from 8/70
AS 1600(GT) 3.875 From 3/72
AT 1600 3.875 1303s and Cabrio from 3/72
AU 1600 3.875 1303s and Cabrio from 3/72 with LSD
BA 1300/1500 4.375 Semi Automatic form 8/68 - 8/70
BC 1300/1500 4.375 Semi Automatic form 8/68 - 8/70 with LSD
BE 1600 4.125 Semi Automatic form 8/68 - 8/70
BF 1600 4.125 Semi Automatic form 8/68 - 8/70 with LSD
BG 1300 4.125 Karmann Ghia Semi Automatic from 8/70
BH 1300 4.125 K. Ghian Semi Automatic with LSD
BJ 1300 4.375 Semi Automatic from 8/70
BK 1300 4.375 Semi Automatic from 8/70 with LSD
DA 1500/1600 4.125 Type 3 Swing-axle up to 8/68
DB 1500/1600 4.125 Type 3 Swing-axle up to 8/68 with LSD
DC 1500/1600 4.125 Type 3 IRS from 8/68
DD 1500/1600 4.125 Type 3 IRS from 8/68 with IRS |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Fri Oct 30, 2009 6:27 am Post subject: |
| rustfree1967bug wrote: |
| 1968 should have been the last year just like beetles. |
No. 1968 was the first year for the Autostick, which was on the IRS. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Fri Oct 30, 2009 6:36 am Post subject: |
| Gary wrote: |
No. 1968 was the first year for the Autostick, which was on the IRS. |
In the USA 68 was the last year for swingaxle, except as Gary noted the auto stick's in 68 are IRS.
The swingaxle was used for many years past 68 in other world markets in Beetles and some of the Ghia.
Since his 70 is in UK that might explain why his is a swingaxle. |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Fri Oct 30, 2009 9:46 am Post subject: |
| Karmann_65 wrote: |
| This is a list for Beetle gearbox codes "unless otherwise stated". I'd love to know if it's wrong. I removed this box presonally from a '70 Ghia for the better 4th gear ratio. Seems to indicate that '70 was the change over year for Ghias. ?? |
No, model year 68 and later autostick beetles and ghias were IRS and model year 69 and later manual transmission beetles and ghias. See:
| Quote: |
| AH 1500/1600 4.125 IRS from 8/68 - 8/72 |
August 1968 is the beginning of model year 1969 for U.S. spec beetles and ghias. This denotes manual transmission beetles and ghias using the 4.125 ring and pinion.
| Quote: |
| AN 1600 3.875 Karmann Ghia with IRS from 8/70 |
August 1970 is the beginning of model year 1971 for U.S. This denotes the beginning of the 3.875 ring and pinion in IRS ghias. (U.S. IRS Beetles got the 3.875 ring and pinion later, beginning in the 1973 model year, hence the 8/72 end for the AH 4.125 IRS above.) _________________ 1966 Karmann-Ghia convertible |
Posted: Fri Oct 30, 2009 9:51 am Post subject: |
Aug 67- July 68 (68 year production) Ghias in the USA manual trans were swingaxle. Only 68 auto stick were IRS. I have owned 3 68's manual trans USA spec that were all swingaxle.
What I was saying/thinking is that some Euro or other non USA Ghia's may have been swingaxle. I know Beetles were. |
Posted: Fri Oct 30, 2009 10:19 am Post subject: |
| keifernet wrote: |
True. The U.S. was the first to get IRS beetles and ghias largely in response to Ralph Nader's "Small On Safety" attack on VWs and Corvairs. _________________ 1966 Karmann-Ghia convertible |
Posted: Fri Oct 30, 2009 5:31 pm Post subject: |
| thanks everyone. I think mine is a 68' from a ghia that someone put into my bus. It goes faster and I did have a tip of one of the shifting forks come out with the oil some years ago and it was bronze and I was told that the forks changed from steel to bronze in 68'. |
Posted: Fri Oct 30, 2009 7:33 pm Post subject: |
| Quote: |
What do you mean NO? 1968 was the last year for swing axle in beetles and ghias. 1969 went irs. [/code] _________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
_Pascal_ Samba Member
Posted: Mon Jan 24, 2011 2:28 am Post subject: |
Hm things are not completely clear to me after reading this topic.
Should an american spec ghia convertible from 1969 with manual gearbox be IRS or swingaxle? |
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14237 Location: Southampton U.K.
AlteWagen Troll
Posted: Tue Jan 25, 2011 12:24 pm Post subject: |
| Is your AO trans irs or swing? I had what I thought was an AO case and it ended up being a A0 (zero). |
Friedpotatoes Addicted4life
Joined: April 04, 2003 Posts: 1215 Location: Fresno California
Posted: Wed Jan 26, 2011 11:48 pm Post subject: |
where does one go to find a list of gear box codes ? my 64 ghia has a code of 28 right above the part number 113301103? _________________ 56- Wolfsburg Single Cab
57- Oval Window Bug (Agave Green) |
