yet another predicament...
VWMan#30
VWMan#30 is offline
PostPosted: Mon Jan 24, 2011 5:08 pm    Post subject: yet another predicament... Reply with quote
i am thinking about dropping my 64 baja body on a late model pan. with irs and bj front end. what are some draw backs other than bj. i will keep the bj front. second....my tires will rub the long travel torsion tube how can i fix this? thanks for helpn
KrAzY-BaJa
KrAzY-BaJa is offline
PostPosted: Mon Jan 24, 2011 6:04 pm    Post subject: Reply with quote
youll be fine and get smaller tires (30s)
70% of what you buy is something to start with.
ForYotaWagen: A Ford/Toyota/Volkswagen http://www.thesamba.com/vw/forum/viewtopic.php?p=4871576&highlight=#4871576
VWMan#30
VWMan#30 is offline
PostPosted: Mon Jan 24, 2011 6:25 pm    Post subject: Reply with quote
30's are very close. i will be using stock arms. not heavy off roading just occasional mud holes. will it work?
tanner_122
tanner_122 is offline
PostPosted: Mon Jan 24, 2011 6:30 pm    Post subject: Reply with quote
My friend has 31"s u can see how close it is
91 jeep Cherokee "TANK"
VWMan#30
VWMan#30 is offline
PostPosted: Mon Jan 24, 2011 6:32 pm    Post subject: Reply with quote
so 30's? and my pop doesnt believe that swingaxle will lean out when lifted. he says it will be fine and not to worry about it. but i dont wanna wear out tires that fast
tanner_122
PostPosted: Mon Jan 24, 2011 6:35 pm    Post subject: Reply with quote
Haha show him this pic of mine then
And they don't eat the tires that fast
VWMan#30
VWMan#30 is offline
PostPosted: Mon Jan 24, 2011 6:36 pm    Post subject: Reply with quote
how fast do they wear out
Mal evolent
Mal evolent is offline
PostPosted: Mon Jan 24, 2011 6:43 pm    Post subject: Reply with quote
get shorter torsion bars and flat caps.
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
VWMan#30
VWMan#30 is offline
PostPosted: Mon Jan 24, 2011 6:44 pm    Post subject: Reply with quote
can i run torsion bars out of a older bug? and use caps from that bug? if not how long?
Phoxxanator
Phoxxanator is offline
PostPosted: Tue Jan 25, 2011 5:50 pm    Post subject: Reply with quote
Umm, my wheels definitely camber IN at the top. Is that bad? haha.
Tires have been on the bug since around '85, if that gives any indication how long they last. I'm more worried about the dry rot than the tread loss.
Lotrat
Lotrat is offline
PostPosted: Tue Jan 25, 2011 5:58 pm    Post subject: Reply with quote
Yes you can. You need the short bars, spring plates, and outer grommet.
Before:
After:
31s are too big for a stock rear end. They will rub all over the inside of the wheel wells. 30's won't rub if you keep the stock bump stop. Hibbards book show how you can beat the wheel wells to fit 31s if you are stuck on getting them.
jeff930
jeff930 is offline
PostPosted: Tue Jan 25, 2011 6:09 pm    Post subject: Reply with quote
If you're not running it hard will 31's still rub??
VWMan#30
VWMan#30 is offline
PostPosted: Tue Jan 25, 2011 6:21 pm    Post subject: Reply with quote
i am going to swap my swinger for an irs on my 64 pan. i will just cut the spring plate and drill holes for the trailing arms to bolt to.
tanner_122
PostPosted: Tue Jan 25, 2011 6:38 pm    Post subject: Reply with quote
nope u will be fine.. u have between 1/2" and 1/4"
Lotrat
Lotrat is offline
PostPosted: Tue Jan 25, 2011 6:47 pm    Post subject: Reply with quote
Define "not hard". Like on the streets? Maybe. At highway speeds, a large 31" tire could balloon and rub the torsion tube.
I have both 30s and 31s on rims ready to go. I also have short torsion tubes... I am going to run the 30's. I'd rather have the 1/2" extra suspension travel than the 1/2" of ground clearance.
jeff930
jeff930 is offline
PostPosted: Tue Jan 25, 2011 7:02 pm    Post subject: Reply with quote
Fire roads mostly. Think I have 31's now but they are gone smooth and I never got to see them new.
