DIY mud flap brackets?
airkooledchris
airkooledchris is offline
PostPosted: Mon Feb 02, 2009 12:29 pm    Post subject: DIY mud flap brackets? Reply with quote
Has anyone ever found a way to use generic mud flaps on a vanagon?
With so many inexpensive non-stock mudflaps out there, it seems there should be a way to just get some brackets for mounting them Vs the kind that you butcher into the side of the body of the van.
ddonnell
ddonnell is offline
PostPosted: Mon Feb 02, 2009 8:13 pm    Post subject: Reply with quote
Hate to be 'that' guy, but...
I just asked that question.....
http://www.thesamba.com/vw/forum/viewtopic.php?p=3581174#3581174
1990 Vanagon Carat-SOLD
1995 Dodge Ram 2500 4x4 V10
1966 Baja "The Beast"
instagram #bajabugproject
View user's profile Send private message Facebook Classifieds Feedback
airkooledchris
PostPosted: Tue Feb 03, 2009 10:01 am    Post subject: Reply with quote
unfortunately with a thread title like that it's going to be hard to get much additional feedback if the few that were curious enough to click didn't get you enough info to go off of.
climberjohn
climberjohn is offline
PostPosted: Sat Jan 29, 2011 11:35 am    Post subject: Reply with quote
Okay, another Thread from the Dead!
(Hee, hee, I just made that up. Pretty funny name for a revived thread, don't you think?
I just did this, so I wanted to past. It always irked me that four generic mudflaps from the FLAPS cost a mere for $20, but the "official" VW ones were $150 for a set of four! Ouch!
So, I installed the generic ones. They have a nice mountain on them, suitable for an occasional climbing base camp van like this one.
Front right detail
Rear right detail
The mudflaps came with black self drilling sheet metal screws. I used 3 on each one to secure to the fender lip.
I made a bracket for the rear mudflaps out of 3/4 inch wide aluminum stock from the local hardware store, about $4 for a 4 foot length. See photo for details. It's reasonably secure. It has a 90 degree bend in it, made with pliers and a vise.
Rear bracket detail
I mounted the fronts with a 3" x 1/4" machine screw, 3 lock nuts, and 2 fender washers. I drilled a 1/4 hole into the space of the jack mount. The fronts feel very secure.
Front mounting detail
- I added a bead of heavy duty silicone all around the flap to try and keep water away from the screws and holes.
- The bottom of the flaps hang about 7 inches from the ground.
- Stainless steel hardware used throughout.
- Best Tip: Use needle nose vise grip pliers or spring clamps to hold mudflap in the proper place while you mark the exact location with fine tip sharpie pen and maybe some tick marks with tape.
- Important: If you use too long a screw, it may rub on your front tire when you turn! This is BAD! Check this carefully before driving and shorten screw with a hacksaw if needed. (Ask me how I know this . . .)
Overall, a fun and easy project! Now I can save my $$$ for new springs . . .
Left side:
-CJ
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
buspor63
buspor63 is offline
PostPosted: Sat Jan 29, 2011 10:06 pm    Post subject: Reply with quote
I like it! Good work around for a too $$$$$ add on.
Imagine that, theres not an "h" in either Westfalia or Syncro?
MichaelRpdx
MichaelRpdx is offline
PostPosted: Sun Jan 30, 2011 12:06 am    Post subject: Reply with quote
But if it's revived is it still dead? It's not...not...gasp...Zombie thread?
Which raises the question: did you spend more on stainless nuts, bolts and washers than you did on the FLAPS flaps?
Michael in PDX
Sauntering around with Frances, a red 89 Westy
Timwhy
Timwhy is offline
PostPosted: Sun Jan 30, 2011 4:29 am    Post subject: Reply with quote
Those mountain flaps are the same ones that I used to repair my propane mudflap
that the PO had duct taped to keep from falling off. I applied my own VW sticker to it.
Heftsmerf don't read this post it mentions some STICKERS!
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
jamowmow
jamowmow is offline
PostPosted: Tue Oct 10, 2017 10:34 am    Post subject: Re: DIY mud flap brackets? Reply with quote
@climberjohn, great idea and thanks for the detailed walkthrough! This is next on my list.
83 Westy, the last of the Air-Cooled
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Tue Oct 10, 2017 8:22 pm    Post subject: Re: DIY mud flap brackets? Reply with quote
When I replaced the left-front mudflap that protects the Westfalia propane tank, I bought one of these decals to jazz it up.
My significant other vetoed the proposal so now Mudflap Girl is on my file cabinet ...
Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
IdahoDoug
IdahoDoug is offline
PostPosted: Tue Oct 10, 2017 10:38 pm    Post subject: Re: DIY mud flap brackets? Reply with quote
I don't need any mudflaps, but I had to check in to say that's a pretty good mudflap girl in several notable updates from the original seen all over the southern USA. My one complaint is that her arms look bigger than mine.
