n1ftyneil Samba Member
Joined: January 10, 2011 Posts: 76 Location: Foothill Ranch, CA
Posted: Sun Jan 30, 2011 9:33 am Post subject: My 69 Fasty education and build |
As noted in a couple of other posts, I bought a 69 fastback sight unseen off ebay without even knowing what one was, because my wife adored it and it reminded me of an old Aston. I'm now reading hours per day and reading reading reading. Here Ill document the labor of love.
After having it for a day it died and left me at the side of the road 3 times, so the investigation began.
By Yesterday the following had been completed:
New Voltage regulator: My first issue with the car, no charging. Easy fix
Rewiring of the fuel pump: PO had done a horrific hack-job and it was hanging with a loose connection under the car.
Electrical: Blinker went on with the lights, lights went off with the blinker. Stuff got rewired and cleaned up. Seems to work well now, though there is a phantom wire I have to post a picture of. Its under the bonnet by spare tire and has 2 rubber contact plugs.
Full tune-up: Nyscoe did this as I wanted it running first, then my valve/points etc learning can begin
Ignition: It was burning points within 15 minutes at idle. Coil was bad and has been replaced, idles like a champ now.
Brakes: Front right caliper was as good as seized. A call to a good friend at Stoptech was my savior here. Their parent company is Centric and they have a disturbingly large back catalogue of oem parts back to the beginning of time. A day later I had new front loaded calipers, discs and hoses and he's having the Stoptech gang make me some slotted discs for fun. They will be here in about 2 weeks. The braking is incredibly reassuring now.
SO Saturday was my first drive and Russ, Tram etc etc yes, you were all correct, stock is AWESOME. I LOVED it, it cracked me up the whole time. It has a Hurst style shifter and the gear box is brilliant. The shifting is tighter an more satisfying than a lot of modern cars. Took it down to Cars and Coffee on Sat Morning in Irvine and it received a lot of love then went house hunting with my wife in it the remainder of the day. I have no horn, that is not good.
Let the fun times roll...
[/list] |
Posted: Sun Jan 30, 2011 9:36 am Post subject: |
Now it's Sunday am and the car is up on stands int he garage for the suspension to be raised. I've watched the videos etc an am confident unless anything is well seized.
Its rubbing and bumping BADLY, from reading I'm guessing it's a 3 spline drop in the front compounded by the fact that it has the 8 spokes with the wrong offset making it even worse.
I'll bring it up 1 spline and see how it looks.
Pics and stuf later on.. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23394 Location: Kimball, Mi
Posted: Sun Jan 30, 2011 9:53 am Post subject: |
Just keep in mind that after you raise it up, that you'll have to reset the toe in. If you don't, you'll eat the tires off the front of it due to too much toe in/ toe out.
I use an angle finder (available at HF or sears, or other good hardware stores) to make sure both sides come up equally. You'll have to decide whether you're doing an inner spline raise (easier) or an outer spline raise (at the trailing arm). If going with an inner raise, get a longer 10mm bolt (about 3" long), and thread it into the bar (after you remove the clip on the opposite side), as this will make it easier to reset the bar back into the splines (it won't drop out). Take your time, and don't get in a hurry.  _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Jan 30, 2011 10:06 am Post subject: |
Thanks Bob,
Noted. I'm off to get the 30mm socket, so I'll pick up the bolt too. I'm still confused on the choice between inner and outer, but I waas assuming I'd do inner. I feel like it would be best to know what was done to lower it though an undo that instead of potentially just compensating for it by doing the opposite.
I also have not fully understood the "tuning moves" yet, but I've also not studied the set-up on the car. I think it will become clearer as I do. |
Posted: Sun Jan 30, 2011 10:34 am Post subject: |
Yeah, the inner spline adjustment is the easiest. The turning moves are pretty simple, especially IF you have an angle finder. In your case, since you're raising the car, you'll want to rotate the lower trailing arm down the number of splines you want to raise the car up (opposite of lowering).
Look at the outer part of the lower trailing arm to torsion bar connection. If you see visible rust on the ends of the splines, or it's still painted up without looking like it's been disturbed, then it will tell you whether it's had an inner adjustment or an outer adjustment. Most times the trailing arm is rusted to the torsion bar. This is common, and sometimes you need a puller to release the trailing arm from the torsion bar (the connection is rusted solid). My first time trying to lower a front end, I found this, so I put that part back together, and just did an inner adjustment. The next one I did, it came apart like it was supposed to. When we did my son's car, we had to do both, as the PO didn't get both sides even. That's where the angle finder came in handy, to get both sides to match. For fine tuning moves, thats where you move the inner one way, and the outer the opposite way. Sometimes you have to move the inner 2 splines, and the outer either 1 or 3 splines to get the fine adjustment you want. This can be time consuming, but you'll get exactly what you're looking for (matching both sides) eventually.  _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
supaninja Samba Member
Posted: Sun Jan 30, 2011 10:42 am Post subject: |
Thx both. Seems like a great forum. You guys seem to have great thoughts a descriptions. Most of the modern cars forums are full of knobends that think they are geniuses because they paid to get a Borla exhaust. This place is a wealth of info. |
Posted: Sun Jan 30, 2011 10:43 am Post subject: |
supaninja wrote: |
My guess is those phantom wires are for the horn. I'm glad your sticking with it. |
Yeah, I forgot about that, Supa's right, they're for the horn. It's possible that the PO had a problem with it, and just removed the wires to it to keep it from sounding off (if the horn is still attached to the bumper or bumper bracket). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4045 Location: Deep In My Own Psyche
Posted: Sun Jan 30, 2011 3:57 pm Post subject: |
yes that is where the bolt to hold the torsion in goes
it also has a bent peice of metal that holds it
i looked in the classifieds but dont really know what its calld
someone else will!
also
if you are without that
take a look at ALL the bolts on the beam
Esp the ones that hold the bottom of the bottom ball joints in
Crazy what bolts go missing over time _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
Posted: Sun Jan 30, 2011 4:00 pm Post subject: |
Thanks Shark,
I actaully edited my post and made it a seperate thread - didnt know if anytone would continue to read this one. Then I realized I shouls have left it here. So it's below. |
Posted: Sun Jan 30, 2011 4:30 pm Post subject: |
Sorry.. made a new thread, should not have. I have established my car is missing the upper torsion bar bolts and little retainer thingy. I'l have to find some.
What I'd like to know is a) is this unsafe? b) could I continue with the raising suspension steps and but a big M10 in there to hammer out the other side and move the splines?
Thanks!
[/quote] |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18046 Location: Eugene, OR
Posted: Sun Jan 30, 2011 5:00 pm Post subject: |
I was able to wigglepullwigglepull on the torsion arm to get the opposite/inner spline loose. You could try a Longer Correct bolt on the opposite side w/wrench or a heavy punch w/hammer? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sun Jan 30, 2011 5:08 pm Post subject: |
Mike Fisher wrote: |
I was able to wigglepullwigglepull on the torsion arm to get the opposite/inner spline loose. You could try a Longer Correct bolt on the opposite side w/wrench or a heavy punch w/hammer? |
From reading on here, a longer bolt and hammer should work fine. At this point I'm just more concerned with those upper bolts not being there. 1st from a safety standpoint and secondly not wanting to break anything on the car. |
Posted: Sun Jan 30, 2011 6:26 pm Post subject: |
n1ftyneil wrote: |
Most of the peeps on here are competent mechanics, you have to be to own a acvw, that or be super rich and have all the work done by someone else.
On other car forums I've noticed most of the peeps have never turned a wrench or even changed their own oil, lololl. also they are completely helpless without a step by step diy article. There are a bunch of very talented individuals here. For example, look at Bert3's build thread, pretty much built a fasty from NOS parts and zinc plated every single nut and bolt. _________________ http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/ |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Sun Jan 30, 2011 6:42 pm Post subject: |
supaninja wrote: |
n1ftyneil wrote: |
On other car forums I've noticed most of the peeps have never turned a wrench or even changed their own oil, lololl. also they are completely helpless without a step by step diy article. There are a bunch of very talented individuals here. For example, look at Bert3's build thread, pretty much built a fasty from NOS parts and zinc plated every single nut and bolt. |
and there are truly experts on here -- Russ n Tram for example were trained by the book and worked at the dealerships back in the day. A lot of us sound smarter just by parroting their knowledge.
welcome to the family  _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
Posted: Sun Jan 30, 2011 7:43 pm Post subject: |
JSMskater wrote: |
supaninja wrote: |
n1ftyneil wrote: |
welcome to the family  |
You can continue with what you're doing, but I wouldn't drive it without that bolt and clip. The clip is more of a safety feature in case you ever break the torsion bar. The bolt just holds the other end of the bar, to keep it locked in place. Just something to think about. Mike probably has the clips and even the bolts IF you ask him. By the way, those are lower torsion bar bolts and keepers, not uppers.
I try to help out where I can, when I can. I don't have Russ's or Tram's experience, but I have my own, and I got it from tearing these cars apart and then putting them back together. I learned the hard way, by actually doing it (and the pics are in my signature to prove it). I've also been working on my own cars for over 30 years, and type 3s for the last 21 of those years.
I don't discount either Russ's or Tram's help either, as I can learn from both, and still do to this day. Like I said, I don't know it all, and I'm still learning too.  _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Jan 31, 2011 6:17 pm Post subject: |
Took a wee jaunt up to ISP today and grabbed the bolts with retainer plates for the torsion arms, amongst some other goodies. I managed to stock up on a lot of little missing trim bits all in the $1-2 range that will help tidy up the interior.
On left hand turns I'm smelling gas big time. Guess is the breather tube in the passanger wheel arch. They are apparently regular crackers. Picked it up too for $5
I'll proabbly be parroting a bunch of you before too long...  |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35919 Location: Conejo Valley, CA
Posted: Tue Feb 01, 2011 10:33 am Post subject: |
Typically that is an overflow tube, not a breather. Even replacements fail in a couple of years or less. Jim Adney had developed a kit that is much more robust than the rubber OEM part. That part is crucial! When it fails, it lets water and dirt kicked up from the wheel to get into the fuel tank. It then travels down to the fuel pump, and rusts and clogs it, especially if the car sits for long periods of time. This failed overflow pipe is probably the cause for most of the pump replacements as we restore these cars. |
Posted: Tue Feb 01, 2011 12:15 pm Post subject: |
KTPhil wrote: |
GREAT to know. Thanks a lot. I just called it the wrong name, that's the rubber tube that I got. I plan on putting it on tonight. I'll check into the better solution though. Cheers mate. |
