baja heat
poomwah
poomwah is offline
PostPosted: Wed Feb 02, 2011 10:34 pm    Post subject: baja heat Reply with quote
anyone running a baja with heat extractors? If so, what is the rest of your exhaust like?
I'd like to build another baja, but I don't want to give up heat, and I don't want to run a gas powered heater
thesatelliteguy
thesatelliteguy is offline
PostPosted: Wed Feb 02, 2011 10:38 pm    Post subject: Reply with quote
the search button is at the top of the page
Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878
thesatelliteguy
PostPosted: Wed Feb 02, 2011 10:53 pm    Post subject: Reply with quote
Sorry...that came off rude. Here's what i have been running the last 4 years. Its a quiet pack from empi that has been cut and the muffler rotated for better clearence (it also got ripped off on one of those drunkin nights), In this pic it dosent have the heat exchangers on it, thats because i replaced them with simple J tubes since i dont need heat in the summer.
Last edited by thesatelliteguy on Wed Feb 02, 2011 10:54 pm; edited 1 time in total
poomwah
poomwah is offline
I know but I'm using my phone for internet access and it makes searching a bit more complicated
locutisj
locutisj is offline
PostPosted: Fri Feb 04, 2011 1:07 pm    Post subject: Reply with quote
I'm runn'n an EMPI quiet pack with cheesy exchangers I bought from JC. Stay away from these (exchangers) unless you're on a tight budget (like I was) as they don't have the heat sinks inside that hold heat which equates to more heat to the cabin. I also added a 3" body lift which changes the heater hose from a fairly straight shot to a bit of an S. I think that's eating at my air pressure to the cabin area. I plan to add the add-on electric fan kit that's out there one of these days.
Here's what I have:
[/img]
neanders
neanders is offline
PostPosted: Fri Feb 04, 2011 8:58 pm    Post subject: Reply with quote
Yep.
They work pretty well until the temp gets into the teens...
It's mine now and I want a BAJA!!!
derwood38
derwood38 is offline
PostPosted: Fri Feb 04, 2011 11:09 pm    Post subject: Reply with quote
I have been thinking about trying the oil cooler in the cab. Going to try it this weekend.
