GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Fri Nov 05, 2010 3:24 pm Post subject: |
| tencentlife wrote: |
| Just get a big dog and let him live in your van. A better security system has never been devised. Ask the cops, they'll tell you the same: if you don't want your car stolen, you need active security, i.e. something that will rip a thieve's friggin arm off if he's stupid enough to stick it in the car. |
We used to have a 120 pound lab/ridgeback mix that would curl up on the floor in front of the drivers seat whenever we left him in the van. My favorite was to leave the keys in the ignition and my wallet on the dashboard. He would not have taken kindly to an arm coming through the window.. RIP Gus! _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
slowcoach Samba Member
Joined: December 28, 2010 Posts: 21 Location: West Yorkshire, UK
Posted: Tue Feb 08, 2011 5:11 am Post subject: |
climber john-
lovely idea i think! im looking to do something like this too. is there a plastic vent cover you mention that goes over the hole in the pillar here and hides the switch? i certainly dont have one on my 84, but would certainly make this mod better...
good stuff
john. _________________ EJ20 Subaru Trakka 1984 |
rockfish Samba Member
Joined: February 13, 2007 Posts: 740 Location: Palo Alto, Calif.
Posted: Tue Feb 08, 2011 10:23 am Post subject: |
There is a vent/louver cover - it is black and has some felt to seal with the door. I took a few minutes to look at the GW and VC websites to see if I could find the part and photo. No luck.
It's got to be out there somewhere.... _________________ 89 Westy
GW 2.5 5-speed trans
"It's what you learn after you know it all that counts."
- John Wooden |
Flash Kaleo Samba Member
Posted: Sun Jan 27, 2013 2:25 pm Post subject: Battery Kill Switch |
Seems like an easier solution would be to just install a battery kill switch. There are some that have a key that is removable.
This won't prevent a break in, but will keep someone from driving away in your van...
Flash _________________ 1986 Wolfsburg Weekender |
r39o Samba Polizei
Posted: Sun Jan 27, 2013 2:53 pm Post subject: |
Where you propose to mount that monster battery kill switch?
Bosch makes one too, which may be easier to mount.
0 341 001 001 or 006 maybe other Bosch numbers.
_________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12424 Location: Santa Cruz, CA
Posted: Sun Jan 27, 2013 3:16 pm Post subject: Re: Battery Kill Switch |
| Flash Kaleo wrote: |
Problem being that the clock, radio presets, radio settings and radio clock will always be wrong.
If you have a learning type of conversion the ECU will always be reset to the factory map and anything learned will be lost- altitude correction, driving style etc.
If someone really wants to steal a car nothing will stop them only slow them down. Bypass a battery kill switch? Easy, jump the 2 legs or unbolt one leg and rebolt it to the other leg or bypass the entire thing.
A tow bar or trailer makes quick work of it as well. |
AdrianC Samba Member
Joined: January 13, 2012 Posts: 526 Location: Wherever the road's gone
Posted: Sun Jan 27, 2013 4:04 pm Post subject: |
| climberjohn wrote: |
| My approach: Rather than mess with the fuel pump power supply, I added a switch to the fuel pump ground. |
That's not exactly the most secure of kill-switch solutions. If the bleep thief is just a wander-by, then it'll probably deter them - yes. But the damage to your van will already be done. You're still walking for assistance.
If, otoh, the thief has a bit of time and inclination on his side, that set up is just about the easiest to actually get round. He hotwires the ignition lock. All the dash lights come on - but... no buzz of fuel pump, and no start. A quick look at where the pump sits - and, oho, what's going on here at the earth terminal? Two seconds to swap the earth lead back and... bingo. Security bypassed. Start. Drive off. Even if you remove the old lead, it still only needs the new wire cutting and shorting off manually. Easy to bodge. _________________ Adrian
Zookeeper of a miscellany of motoring silliness, from 0.75bhp to 9ft tall.
Living life on the road in an '88 2.1DJ Westfalia Club Joker Hightop.
www.WhereverTheRoadGoes.com |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17348 Location: Brookeville, MD
r39o Samba Polizei
Posted: Sun Jan 27, 2013 4:26 pm Post subject: |
As stated elsewhere, you are keeping honest people honest.
What you are doing is slowing a thief down.
If they really, really want something, they WILL get it.
I have even seen cars that were chained to the shop floor vanish..... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
87RedWesty Samba Member
Posted: Wed Sep 04, 2013 3:18 pm Post subject: Kill switch in plain sight |
| Say I want to install a kill switch for the fuel pump but want to hide it in plain sight. I sat in the driver's seat and looked around. How about the dash light dimmer switch right under the headlight on/off switch? Since I installed LED dash lights, it doesn't seem to do much. Would it be possible to convert it into a kill switch? If so, how? (I'm not a master electrician but I can follow directions.) |
WestiCoast Samba Member
Joined: June 25, 2012 Posts: 194 Location: Oceanside Ca
Posted: Wed Sep 04, 2013 4:55 pm Post subject: |
| This is a cool setup. It uses a read switch that get activated with a magnet and a double pole double throw relay. Its extra cool if you have the steel dash like my 84 has. Because you can have a magnet or two on the dash, but the van won’t start unless the magnet is in the right position. Very cheap too. All this stuff can be found at your local radio shack. |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1509 Location: Deep South of the Great White North
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3680 Location: Dartmouth, Mass.
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
randywebb Samba Member
Posted: Thu Sep 05, 2013 1:07 pm Post subject: |
I have been using the built-in anti-theft prevention designed by VW's engineers... the ignition switch that fails. _________________ 1986 2.1L Westy 2wd Auto Trans. |
maco70 Samba Member
Joined: March 16, 2011 Posts: 502 Location: Montréal, Québec
Posted: Thu Sep 05, 2013 1:32 pm Post subject: |
On my side, i also have a switch on the ground of the fuel pump and i always put a bar in the steering wheel.
As some says, a crazy thieft could always take it, but he will have a some trouble. _________________ Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior) |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15412 Location: Syracuse, NY
Posted: Thu Sep 05, 2013 1:33 pm Post subject: |
wouldn't a switch to ground the Tach signal suffice to create a non-start scenario? that pulls off the Pulse side of the coil?
I'm asking because I don't know but for the 85+ vans the wire is right in the instrument cluster already.
then again with a switch on the dash, it's really no different than just adding another switch inline on the Ign key circuit.
on mom's van when we got it there was a kill switch that interupted the fuel pump power feed. it spliced in at the firewall and was located under the back seat in a hidden location. presumably for trailhead or longer term security than a grocery store concern. _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
kamzcab86 Samba Moderator
Posted: Thu Sep 05, 2013 1:46 pm Post subject: |
| danfromsyr wrote: |
| it's really no different than just adding another switch inline on the Ign key circuit. |
The 2nd owners of my van did just that: Kill switch wired into the ignition switch. When I took the switch out to diagnose a near no-start problem, I couldn't help but notice that they had used some wimpy wires in order to connect to the tiny switch terminals (instead of finding tiny connectors to accommodate the larger wires needed)... surprising the van didn't have a dash fire earlier in its life (the switch got fried at Home Depot a couple years ago, hence the near no-start).
One of these days I'll get around to adding a kill switch to the fuel pump circuit, with the switch hidden instead of being right there on the dash. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Thu Sep 05, 2013 2:03 pm Post subject: |
I think that it would be great to wire up a hidden/secret kill switch, but take it one step further and wire in a relay that is connected to a hidden horn so that if the starter solenoid is powered up without the kill switch being tripped, the horn blows. In other words, the kill switch would have to be in it's deactivated position to both start the car and stop the horn from going off while turning over the starter. That way the hidden horn blows each time the thief tries to turn over the engine. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
