guatebus Samba Member
Joined: May 12, 2003 Posts: 398 Location: Oakland, CA
Posted: Wed Jan 05, 2011 9:23 am Post subject: |
If you're willing to pony up cash for a new puller, I'd check out Samstag Sales: www.samstagsales.com/kukko.htm#ballbearing
You need a 70-2 extractor for $117 plus some 70-722 arms and spacers for $143. You might want to ask about the spacers because the site says the 70-722 spacers will work for 6306 bearings but doesn't mention 6305 bearings. _________________ '64 standard microbus
'69 deluxe microbus |
WideFive SBS Hit Squad
Joined: August 20, 2002 Posts: 1147 Location: Litchfield, Ohio
Posted: Thu Feb 17, 2011 12:37 pm Post subject: |
Got this set off eBay last week for $205shipped...
SKF bearing puller TMBP7 _________________ Aaron D. Badertscher
Click here for ALL my links. |
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Thu Feb 17, 2011 1:44 pm Post subject: |
I 'm not 100% sure but I think the replacement arms are no longer made so if you break one you will have to source a used one. there was one of those kits on eBay a year ago with the arm missing that I would have needed so I called skf and thats what they told me. but that one looks complete. _________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
| dawerks wrote: |
| Perfection only comes with delusion. |
http://www.oacdp.org/ |
Posted: Thu Feb 17, 2011 1:47 pm Post subject: |
Correct... SKF no longer makes this model. They have offer a different type puller now, don't have that prt# offhand, but last I checked they were $700. _________________ Aaron D. Badertscher
Snoop Bob Samba Member
Posted: Thu Feb 17, 2011 8:55 pm Post subject: |
Great score. _________________
| BarryL wrote: |
| Put your lips onto the little tit with the hole in it inside and make a good seal. You can suck and blow but with a little resistance. It gets better after it's wet. |
| EverettB wrote: |
| I would be interested in knowing the sizes of the various shafts. |
RedRockBug Samba Member
Joined: October 01, 2010 Posts: 10 Location: Sedona, Arizona USA
Posted: Mon May 02, 2011 6:42 pm Post subject: |
Samstag Sales was out of the "ST 242-Body +A". So, I've ordered the Kukko 70-2 Extractor with the Kukko 70-722 Arms instead. I hope it is durable enough. The total cost of the order was just under $284.
http://www.samstagsales.com/kukko.htm#ballbearing
Another 6306 extractor (i.e. KF TMMD 100 Deep groove ball bearing puller kit) was seen at reliabilitydirectstore.com. It looks much more durable but at a higher price of $753.30.
http://www.reliabilitydirectstore.com/SKF-TMMD-100...%20100.htm
-Edited to add the following:
I noticed that Automotive Specialty Tools Inc (i.e. etoolcart.com) has similar / identical tools like the "ST 242-Body +A" of samstagsales.com. The site refers to the individual parts as "SIR-242-Body" and "SIR-242-A 8 Fingered Collet".
I have no prior experience with any of the vendors mentioned. Hopefully, the samstagsales order will work out. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9833 Location: Exit 7, New Jersey
Posted: Tue May 03, 2011 10:55 pm Post subject: |
When I got my puller from Samstag, the box was labeled Sir Tools, so it sounds like the identical puller to me.
I mentioned it earlier, but if you get this kit, be sure to immediately screw the various parts together. The first set I got had mismatched threaded fittings, it was the right thread pitch, but the fit was WAY too tight, so that you couldn't get the extension sleeve on. Also, when trying to set it up for use without the extension, you could only screw one of the collets on about two turns, not enough to use it properly.
It took MONTHS to get a proper set back after returning it.
The guys at Samstag were fine, it just took forever to get the replacement. _________________ Founder and Chairman Emeritus, ECMSAS
| BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
| Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3505 Location: Anderson SC
Posted: Wed May 04, 2011 6:05 am Post subject: |
| WideFive wrote: |
SKF bearing puller TMBP7 |
Aaron, great score, but let me know next time you are bidding on one of these and I won't bid against you....I had my e-bay sniper at 201.99 max.
sorry _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Wed May 04, 2011 7:34 am Post subject: |
Ha, ha, I was wondering if you had seen that auction or not. Knew you were looking for one too. I liked eBay a lot more in the old days when you could see the full ID of who was bidding. I would have backed off then  _________________ Aaron D. Badertscher
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15526 Location: Casa de Oro, California
Posted: Wed May 11, 2011 2:43 pm Post subject: |
I found these as the inner uppers in a virgin transaxle. Do I have to bust out the ball spacer or does it just pop out to be able to use the puller tool?
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10808 Location: the past
Posted: Wed May 11, 2011 2:51 pm Post subject: |
| you should be able to gently pry out that bearing cage in one piece. that will leave the ball bearings to float around in the bearing races. depending on what style puller you will be using, you may need to manually position the ball bearings in the puller for it to work properly. |
BarryL  Samba Member
Posted: Sun Jun 05, 2011 7:40 am Post subject: |
I found a drawback to this style puller in a rare instance of a stuck bearing. The spreader for the arms would crush as there wasn't enough axle sticking out.
Putting an appropriate size socket before the axle for the ring to slide onto and using nuts to support the mandrel as it now couldn't penetrate the socket to center on the axle. I had to use a couple clamps to bring in the arms and keep them there.
SwissCatalog Samba Member
Joined: March 22, 2012 Posts: 1 Location: United States
Posted: Thu Mar 22, 2012 1:50 pm Post subject: Simatool |
A bit late but I figured I would link anyways:
http://www.swisscatalog.com/SIMATOOL-bearing-maintenance-tools_c6.htm
Basically an online store that allows you to look at the 2 different bearing puller kits and one mounting kit. Also has videos of these pullers in action!
The kits arent cheap but they are extremely nice. |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1293 Location: Surprise, AZ
Posted: Mon Aug 10, 2015 2:09 pm Post subject: |
Here's "web special" for Kukko 70-2 and 70-722 for 6035/6036 bearing pullers: http://www.samstagsales.com/kukko.htm - $279 + shipping for both.
And here's the data sheet for them, showing the puller arms 70-722 work for those bearings: http://www.kukko.com/v_mediando_images/Bedienungsanleitungen/70-A_bedienungsanleitung.pdf
Cheers.
Edit: Now a new "web special." _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
| EverettB wrote: |
| ...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold)
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1796 Location: Cleveland, Ohio
Posted: Tue Aug 11, 2015 7:24 am Post subject: |
Dayum! Nice write-up, Bruce! _________________ '64 standard microbus
'64cal lookdub 1200 Deluxe
Posted: Mon Feb 29, 2016 1:47 am Post subject: Re: SwingAxle & Reduction Box Bearing Pullers:Info/Sources |
Finally found a 6306 puller, a Krebsfer 241. Hopefully I won't need to use it anytime soon.
Kiwi1966 Samba Member
Joined: August 18, 2009 Posts: 168 Location: Ohoka New Zealand
Posted: Tue Mar 01, 2016 2:22 am Post subject: Re: SwingAxle & Reduction Box Bearing Pullers:Info/Sources |
Wow --thats a serious looking puller--I like it  |
Posted: Tue Mar 01, 2016 10:09 am Post subject: |
| guatebus wrote: |
Dayum! Nice write-up, Bruce! |
Wow, I agree. Shades of Hazetguy.
(Right click, Save, backup to server for future reference) _________________ Founder and Chairman Emeritus, ECMSAS
supertobs Samba Member
Joined: December 17, 2020 Posts: 12 Location: Germany
Posted: Mon Aug 01, 2022 1:27 am Post subject: Re: SwingAxle & Reduction Box Bearing Pullers:Info/Sources |
Hello,
I have all these Rillex and about 20 of what you call Baum tool (picture to follow).
I have no swing axle at hand.
Would you be so kind help me identifying model numbers and purpose?
Is 6304 also the bearing size?
I think I have 4 6304 and one smaller.
At least one 6305. One 533 366 (not VW?)
Is my setting correct, need the ring be pushed to the end? Some picture of use I see without them
Thanks
Tobias
( i am too stupid to upload a picture ...) |
