Which rocker arm style to use
Page: Previous  1, 2
Sigurd
Sigurd is offline
PostPosted: Fri Feb 11, 2011 12:55 am    Post subject: Reply with quote
Mine are about 1.3; equating to 0.520" lift. I had the blocks milled down. They are mighty, mighty close now. The side play was not an issue; you just have to play with the shims. The up/down is taxing on this style of rocker. I'll be using something else next time.
deadkombi
deadkombi is offline
PostPosted: Thu Feb 17, 2011 5:47 pm    Post subject: Reply with quote
These scat rockers are doing my head in. How much did you have to mill off the rocker blocks? I took .080 off mine yesterday and bolted them up last night. The wipe pattern is still above centre. It is closer than it was, but still not where I want it. I also needed to clearance the rocker pedistal a tiny bit .
The ratio has been fairly true with 1.28.
Sigurd
Sigurd is offline
PostPosted: Thu Feb 17, 2011 5:56 pm    Post subject: Reply with quote
It was close to 0.100", but it's been awhile and I can't remember.
Page: Previous  1, 2
Page 2 of 2
