pogolo Samba Member
Joined: March 20, 2003 Posts: 76 Location: Austin, TX
Posted: Sun Feb 27, 2011 11:23 am Post subject: Rocker Shifts - Push Rod at an Angle |
Heard a loud tapping when starting up my '76 2.0L FI bus with hydraulic lifters. I've had a lifter collapse before, so removed the valve cover on the loud side. I found that one of the exhaust valve push rods had slipped to the side and the top part of the rocker was striking the edge of the valve spring: the rocker had shifted to the right and was not centered. There's a hole in the push rod tube where the push rod was wearing against it at an angle.
I removed the lifter and it appears to be fine. This has happened twice to me over the last 2-3 years.
Only thing I can think is that due to not changing the oil for several months (I know, I know), the lifter got jammed with crud and did not pump up, allowing the push rod to shift. Any other ideas?
Thank you Samba. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4659 Location: Oklahoma City, OK
Posted: Sun Feb 27, 2011 11:53 am Post subject: |
Is the spring betwen the two rockers still there? Is it crunched or broken? |
towd Samba Member
Posted: Sun Feb 27, 2011 11:59 am Post subject: |
that rocker can not slide unless something is missing from the Rocker shaft ..
compare that rocker assmebly to the others. you'll find something is missing .. |
pogolo Samba Member
Posted: Sun Feb 27, 2011 12:53 pm Post subject: |
Yes. The spring is still there and has tension. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52792 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Feb 27, 2011 12:56 pm Post subject: |
Hydro rocker shafts don't use springs, they should have solid spacers and thin wavy spring washers, who converted it to hydros? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
pogolo Samba Member
Posted: Sun Feb 27, 2011 1:14 pm Post subject: |
Really?! Hm. Springs all round. That's how the bus came.
Anyone with pics of the solid spacers? |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8576 Location: Las Vegas
Posted: Sun Feb 27, 2011 1:45 pm Post subject: |
_________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
pogolo Samba Member
Posted: Sun Feb 27, 2011 2:51 pm Post subject: |
Ok. Wow. So should I replace the entire rocker assembly, or just the spacer?
Thanks much for the picture. Very enlightening. |
Posted: Sun Feb 27, 2011 2:56 pm Post subject: |
Are you sure yours are hydraulic? _________________ Eric
pogolo Samba Member
Posted: Sun Feb 27, 2011 3:22 pm Post subject: |
Definitely has hydraulic lifters.
So the question is - do I need to replace the entire rocker assembly, or can I just source these solid spacers and slip them on what I have?
Thanks. |
pogolo Samba Member
Posted: Tue Mar 01, 2011 7:30 am Post subject: |
Thanks for the help everyone. I've since put everything back together and the bus is running fine.
I asked at my local shop/junkyard, Austin VeeDub. It appears that the solid rocker spacers in EZ Gruv's picture are an after-market item. I was also shown a bug catalog illustrating that it's a fairly common modification on performance bug engines, but not so much for the Type IVs.
At any rate, from what I've seen (a stock '78 hydraulic lifter engine we looked at had springs) and been told, solid rocker spacers are NOT a factory-installed item - hydraulic lifters came with spring spacers as standard.
Could be wrong and definitely open to debate! There always seems to be a lot of surprising year-to-year variation with the buses. Just hoping this helps someone out down the road. |
Posted: Tue Mar 01, 2011 7:43 am Post subject: |
Time to start looking for a new shop, those guys obviously shouldn't be anywhere near a type 4. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mattcuddy Samba Member
Joined: October 22, 2003 Posts: 2036 Location: Philly, PA
Posted: Tue Mar 01, 2011 7:47 am Post subject: |
pogolo wrote: |
At any rate, from what I've seen (a stock '78 hydraulic lifter engine we looked at had springs) and been told, solid rocker spacers are NOT a factory-installed item. |
Nope, its factory.
Posted: Tue Mar 01, 2011 7:58 am Post subject: |
busdaddy wrote: |
Time to start looking for a new shop, those guys obviously shouldn't be anywhere near a type 4. |
Bingo, Checkmate, and Yahtzee! Those guys are clowns, RUN away! _________________ Eric
Posted: Tue Mar 01, 2011 8:55 am Post subject: |
Well lets split some hairs, what you refer to as "solid" VW rocker spacers really where not "solid", VW still used spring washers, better than just having the single spring but really not solid. This kit makes a set of solid rocker spacers.
Posted: Tue Mar 01, 2011 9:43 am Post subject: |
pogolo wrote: |
At any rate, from what I've seen (a stock '78 hydraulic lifter engine we looked at had springs) and been told, solid rocker spacers are NOT a factory-installed item - hydraulic lifters came with spring spacers as standard. |
VW went to the solid spacers with the hydraulic valves exactly to prevent the problem you are seeing from occurring. With solid lifters the rockers has a moment to recenter each time the lifter ran over the base circle of the cam and there was momentarily a little lash. With hydraulics there is always some compressive force on the valve train even when the lifter is on the base circle, so the rocker can be pushed to the side over a number of revolutions. |
RocketRod Samba Member
Joined: July 19, 2007 Posts: 641 Location: Colorado Springs, CO
Posted: Tue Mar 01, 2011 9:59 am Post subject: |
So to butt in on this conversation......is the hyd lifter rocker shaft smaller than a regular shaft? Reason I ask is I got a set from a known used parts seller and the spring washers do not fit on the shaft. 8 spring washers, 8 solid washers & 4 spacers. _________________ Why Yes it is a Magic bus!
Common Sense isn't so common. |
Posted: Tue Mar 01, 2011 10:32 am Post subject: |
T4 shafts were all the same diameter. |
Posted: Tue Mar 01, 2011 10:44 am Post subject: |
Thanks, so the wavy washers must be too small.....now where to find some. _________________ Why Yes it is a Magic bus!
pogolo Samba Member
Posted: Wed Mar 02, 2011 11:02 am Post subject: |
Anyone with a link to a place where I can buy solid rocker spacers?
Thanks. |
