5 cylinder TDI blahblahbl... wait a second... audi trans?!!!
Page: 1, 2, 3, 4  Next
BlackDogVan
BlackDogVan is offline
PostPosted: Thu Mar 03, 2011 11:27 am    Post subject: 5 cylinder TDI blahblahbl... wait a second... audi trans?!!! Reply with quote
Flipped Audi trans with the bellhousing rewelded, hard to even see the joint.
So this is a audi bolt pattern but whats to stop this from working with a 1.8T or TDI convert with a Passat longitudal mount 5speed trans?
Is the starter direction a game killer? Axle flanges?
Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Still addicted, looking for Doka...
insyncro
Banned
insyncro is offline
PostPosted: Thu Mar 03, 2011 11:48 am    Post subject: Reply with quote
Very interesting.
Christopher Schimke
PostPosted: Thu Mar 03, 2011 11:54 am    Post subject: Reply with quote
I actually considered doing exactly that with my 1.8T project, but I didn't like how high it raised the inner CV joints in comparison to the outers. Probably not an issue on a lowered, or maybe even stock, height van, but on a higher van, I think that the CV angle would be less than ideal. Cool to see it done though. Where did you find that?
svxcarat
svxcarat is offline
very cool
MarkWard
MarkWard is offline
PostPosted: Thu Mar 03, 2011 12:04 pm    Post subject: Reply with quote
What Audi is that transmission from? I wonder how well the shift rod seal will hold up. In a stock configuration, the shift lever would be above the level of the hypoid. I can not see the welds, but it would require a very skilled person to do with a fixture that could hold it centered. You would have to fight warping and it would need to be precisely centered to work. Otherwise impressive.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Mar 03, 2011 12:14 pm    Post subject: Re: 5 cylinder TDI blahblahbl... wait a second... audi trans Reply with quote
Re: "game killers". Upright engine? Possible clearance loss due to exhaust routing?
I"ll probably figure it out right after hitting "submit" Wink but how does starter direction affect things? Doesn't that TDI spin CCW? Which engine is it? 2.5?
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
BlackDogVan
PostPosted: Thu Mar 03, 2011 12:22 pm    Post subject: Reply with quote
@ Chris - http://www.brick-yard.co.uk/forum/charge-cooler-and-new-gearbox_topic62757.html
Good point about the CV angles.
@ Vanagon nut - I meant the physical starter location. Ours hang over the trans, that audi has it beside the engine block & i'm not sure with the longitudial passat installs.
I'm guessing whomever welded the exhaust didn't to the bellhousing Wink
MarkWard
MarkWard is offline
PostPosted: Thu Mar 03, 2011 12:27 pm    Post subject: Reply with quote
Audi's used an engine side starter, opposite of the Vanagon. I can just make out the starter I think in the one picture. I think fitting the starter with the turbo would be tight, but it must fit. As long as an "engine side" starter and matching flywheel are used, it should fine. The engine will always turn in the same direction regardless of the transmission.
Vanagon Nut
PostPosted: Thu Mar 03, 2011 12:28 pm    Post subject: Reply with quote
Right. I just saw it and was composing a reply. Thanks!
So starter positioned as per pic would require longer wires from battery and alternator etc. What other possible issues would result from starter being positioned there?
Neil.
(VW Gas I4)
VE7TBN
danfromsyr
danfromsyr is offline
PostPosted: Thu Mar 03, 2011 12:45 pm    Post subject: Reply with quote
I can't say I'm favoring the exhaust or engine carrier welding
and I'd like a better image of where the Alum bellhousing was welded..
the Audi CVs were larger than the stock vanagon so it wouldn't be too tough to adapt to a Porsche 930 CV to handle the angles..
this is only for a 2wd modification,
I would be concerned with how the internals woud get oiled and how long it'll last..
the starter is in a "stock" locaiton it doesn't even know the trans was rotated
I have a Formula Vee engine adapter for an inline 4cyl that's made to be on a flipped beetle trans.. not that that adds anything to this conversation though..
Abscate wrote:
r39o
Samba Polizei
r39o is offline
PostPosted: Thu Mar 03, 2011 1:05 pm    Post subject: Reply with quote
*VERY* concerned.....x2
SyncroGhia
SyncroGhia is offline
PostPosted: Thu Mar 03, 2011 1:14 pm    Post subject: Reply with quote
It's an Audi 012/01A gearbox.
I'll be interested to know if anything has been done about the oiling inside the gearbox.
If not, the diff bearings won't be getting any oil and will run dry and die very quickly.
Nice idea but it looks a bit half thought out. Fingers crossed that the input shaft has been lined up carefully before the bellhousing was welded back on too.
MG
T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
Vanagon Nut
PostPosted: Thu Mar 03, 2011 1:22 pm    Post subject: Reply with quote
x2, though I consider myself a hack at that stuff.
And the size of tube used for carrier may be too small.
Neil.
(VW Gas I4)
VE7TBN
D Clymer
D Clymer is offline
PostPosted: Thu Mar 03, 2011 1:23 pm    Post subject: Reply with quote
I think the internal oiling would be fine, but I agree with Mark's concern about the shifter seal. That's a fairly light duty seal and I don't think it's really designed to have the oil capacity against the back of it.
I'm guessing that is a 2wd version of the 01E transmission that Audi used on their higher output cars starting in 1990. There is the 01A which is for lower powered cars and then the 01E which was used on the URS4 etc. The Porsche 968 used a version of this transmission on our side of the pond.
Interesting idea, and pretty cleanly done. I'm impressed with the installation.
David
Sir Sam
Sir Sam is offline
PostPosted: Thu Mar 03, 2011 2:30 pm    Post subject: Reply with quote
I'm also wondering about oiling, unless the tranny was filled completely to the top I would be worried about how it would oil everything.
Seal the "top" side of the tranny and add a breather/reservoir somewhere and fill it to the top........
'91 Carat Westy
87' Syncro + '87 Westy conversion coming soon
BlackDogVan
PostPosted: Thu Mar 03, 2011 2:34 pm    Post subject: Reply with quote
All this does is re-awaken my north american Eurovan AAB IDI to 5cylinder mTDI dream. Identical in theory to my AAZ-mtdi. Just need the head & a few other bits from the UK.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Thu Mar 03, 2011 2:40 pm    Post subject: Reply with quote
Does the AAB have piston squirters built into the block?
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
BlackDogVan
PostPosted: Thu Mar 03, 2011 2:48 pm    Post subject: Reply with quote
Yes.
Some AAB porn...http://www.vwdiesel.net/forum/index.php?topic=25252.0
Zeitgeist 13
PostPosted: Thu Mar 03, 2011 4:14 pm    Post subject: Reply with quote
The lemur likee ^
Casey--
'89 Bluestar ALH
NEAT, no ICE.
AndyBees
AndyBees is offline
PostPosted: Thu Mar 03, 2011 8:02 pm    Post subject: Mounting tube Reply with quote
The engine mounting tube looks like one I saw for sale here in the Samba with a package deal...........Quantum 5-cylinder diesel, South Africa Bell housing, mounting bars, etc..... looked very similar if not the same!
Years ago, my uncle and his brother-in-law fabricated an engine adapter to mate a 4-in-line Rabbit engine to a '69 beetle tranny for his rail buggy...... it was a rough looking adapter. However, it worked well! I do not recall how they centered it!
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
Page 1 of 4
