bim55 Samba Member
Joined: February 11, 2005 Posts: 438 Location: Dennis Port, MA
Posted: Sat Jun 13, 2009 6:20 am Post subject: |
SteveManx2, , I have the same combination of short stroke with 140 heads and altenator and Holley 4bl. Not the largest displacement Corvair, but a smooth and cooler running engine, or so I've been told.
I'm not sure but the GS guy probably has the right idea for a reliable 250hp that can drive all day long. _________________ Boston Bob E.
www.bimelliott.com www.deserterownersgroup.org |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6768 Location: Northern California
Posted: Sat Jun 13, 2009 7:49 am Post subject: |
bim55 wrote: |
I'm not sure but the GS guy probably has the right idea for a reliable 250hp that can drive all day long. |
When Subaru makes an air cooled boxer engine , I'll be first in line to put it in my swb Manx. |
DasVolksRodder Samba Member
Joined: March 30, 2009 Posts: 46 Location: West Virginia
Posted: Thu Aug 27, 2009 8:33 pm Post subject: |
i'm putting a edelbrock 4bbl equipped 140 series in my girl's 70 cabriolet and it is cammed for reverse rotation. even had the pulley and backwards stamped fan on the alternator to correct airflow and keep from tossing belts. came out of a rail buggy. IECO 4bbl kit and finned aluminum valve covers look nice, gonna freshen it up and hope to find more go-fast goodies under all the layers of paint and dirt. one thing someone forgot to do, was sell a crank with the timing marks on the other side of TDC for us VW guys!!!  _________________ 1970 VW Bug cabriolet w/Corvair power
1980 Mazda Rx7 10th anniversary edition
1983 Maxda Rx7 GSL
19xx unknown vw fiberglass roadster |
Soviet1942 Samba Member
Joined: October 04, 2009 Posts: 397 Location: Miami, FL
Posted: Sat Feb 19, 2011 2:07 pm Post subject: |
Where can you find those Porsche fan shrouds for the corvair? _________________ 1970 Adventurewagen Hightop "Penelope"
-Soon to have Focke Wulf 190 theme- |
kustoms Samba Member
Posted: Thu Mar 10, 2011 2:48 am Post subject: |
For a second I thought those were links to the Porsche fan for the corvair motor _________________ 1970 Adventurewagen Hightop "Penelope"
Posted: Thu Mar 10, 2011 8:42 am Post subject: |
That's correct, the link to the ebay auction I posted has Starr Cooke's contact details. He is the individual who has the Porsche 911 shrouds for the Corvair engine as well as a lot of other Corvair performance stuff. Again, Starr Cooke in El Cajon, California has the shrouds. Its near San Diego. |
Posted: Thu Mar 10, 2011 11:45 am Post subject: |
BL3Manx wrote: |
Ahh okay thanks. I saw pistons and was like
edit: found it. Thanks so much. _________________ 1970 Adventurewagen Hightop "Penelope"
1966Corsa Samba Member
Posted: Sat Mar 26, 2011 10:21 am Post subject: |
manxbuggy wrote: |
The Weber version might fit, I think the 4BRL setup would require some fiberglass cutouts.
Here is my Corvair powered Manx with stock carbs and low profile filters:
The stock Corvair fan belt changes direction (around the alternater and an idler pulley) to rotate the top mounted fan from the rear pulley. I think the Porsche style fan would solve the problem some Corvair engines have with fan belts not staying on their pulleys as intended. Plus it looks great!
I'll take the triple weber version please.
Rob |
Corvair fan belts should stay on just fine with proper belt and tension. Corvair fan belt throwing is fault of owners over tightening the belt. I have owned both stock and hopped up SCCA vairs. I have a built 140 with a hot cam and four primary carbs that revs up to 6,000 daily. Belt stays on. Trick is adjust it loose, should be able to turn alternator pulley with one finger when cold. USE a proper belt too! Clarks Corvair parts has em. |
Posted: Sat Mar 26, 2011 10:26 am Post subject: |
DasVolksRodder wrote: |
i'm putting a edelbrock 4bbl equipped 140 series in my girl's 70 cabriolet and it is cammed for reverse rotation. even had the pulley and backwards stamped fan on the alternator to correct airflow and keep from tossing belts. came out of a rail buggy. IECO 4bbl kit and finned aluminum valve covers look nice, gonna freshen it up and hope to find more go-fast goodies under all the layers of paint and dirt. one thing someone forgot to do, was sell a crank with the timing marks on the other side of TDC for us VW guys!!!  |
You will be much happier with a more stock four carb set up on the 140. The 4bbl set up eliminates carb sync but is starved for warm air. Rough running till they REALLY get warmed up.
Posted: Sat Mar 26, 2011 12:17 pm Post subject: |
1966Corsa wrote: |
Corvair fan belts should stay on just fine with proper belt |
Do you have the the secondary carbs with added idle circuits or the stock design. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sun Mar 27, 2011 9:52 am Post subject: |
Properly setup Webers will give you better performance throughout the entire powerband, better fuel economy and be just as dependable as a new Edelbrock carb. Not to mention they look SOOOO SWEET! _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
