Water leak under the dash
PDX_Guy
PDX_Guy is offline
PostPosted: Sat Mar 12, 2011 9:39 pm    Post subject: Water leak under the dash Reply with quote
Greetings everyone,
I recently bought a 86 syncro. It is my first vw and I have been loving it. There are a few issues I have been working on but in general it has been great. Today I noticed water dripping down at the corners from under the dash. I haven't gotten the Bentley manual yet but i suspect it might be coming in from the dash and/or headlights. Is this an issue others have dealt with? Any advice is greatly appreciated
insyncro
Banned
insyncro is offline
PostPosted: Sat Mar 12, 2011 9:42 pm    Post subject: Reply with quote
Check the upper corners of the windshield rubber seal for gaps.
Honuak
Honuak is offline
PostPosted: Sun Mar 13, 2011 12:00 am    Post subject: Common Problem Reply with quote
Me thinks your van suffers from the common windshield leak. Im betting it is leaking at both lower corners like mine was. As far as I know the culprit is old windshield seal. There are a few threads here that discuss the problem...
SAMBA!
r.e.wing_fc3s
r.e.wing_fc3s is offline
PostPosted: Sun Mar 13, 2011 9:23 am    Post subject: Reply with quote
also check the windshield washer seal. thats were mine was leaking. a little bit of der reinzosil anthracite
syncrodoka
syncrodoka is offline
PostPosted: Sun Mar 13, 2011 9:28 am    Post subject: Reply with quote
rust
Corwyn Premium Member
Corwyn is offline
PostPosted: Sun Mar 13, 2011 9:51 am    Post subject: Reply with quote
syncrodoka wrote:
rust
That's just mean! Boo hoo!
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
ZimZam
ZimZam is offline
PostPosted: Sun Mar 13, 2011 9:59 am    Post subject: Reply with quote
Like other members have suggested it's rust. You'll need to remove the WS, and replace the seal.
'85 Cabriolet (Margo)
'87 Westy (Heidi)
'75 Porsche 911S Targa
"Nobody trusts anyone, or why did they put tilt on a pinball machine.”
- Steve McQueen
"It's just metal, when rusted and dented , anything you will do will be better. Stop being afraid. What they (VW) did many year ago is not better then what you will do now." -Ben
Honuak
Honuak is offline
PostPosted: Sun Mar 13, 2011 7:40 pm    Post subject: May not be that bad... Reply with quote
Depending on how long its been leaking the R#@* may not be that bad. Mine had just the smallest start of the R word starting right at the corners. When you get the seal off you will see that theres a spot where the sheet metal comes together forming a fat spot of metal, I think that along with an old seal is what causes the leak. A leak is bad enough but it happens to be right above the fuse panel...
SAMBA!
K58
K58 is offline
PostPosted: Sun Mar 13, 2011 10:07 pm    Post subject: Reply with quote
Also, if your windshield is missing the chrome trim that could be the reason.
I found out the hard way
PDX_Guy
PDX_Guy is offline
PostPosted: Sun Mar 13, 2011 10:13 pm    Post subject: Reply with quote
Thanks everyone. I checked the seal and the outer rubber of the seal looks good but the hard plastic middle peice has a bunch of tiny cracks. Are those enough to make it leak? It only seems to leak if I am driving but not if it is parked outside. The van does have a few rust issues, but around the windshield looks good so hopefully this will not be another area. And yeah Honuak, it seems to be leaking in by the fuse panel.
86 Westy Syncro
syncrodoka
PostPosted: Sun Mar 13, 2011 10:18 pm    Post subject: Reply with quote
That is just cosmetic, the slot that it sits in is blind an it wouldn't cause a leak.
Honuak
Honuak is offline
PostPosted: Sun Mar 13, 2011 10:46 pm    Post subject: Looks are decieving Reply with quote
Mine looked fine too...the seal seemed ok and there was no visiable rust. If yours is the same its even more reason to take care of it now before you can see the rust. The seal must shrink slightly over time allowing water to get through. Your much better off fixing it sooner rather than later.
stclair411
stclair411 is offline
PostPosted: Mon Mar 14, 2011 4:37 am    Post subject: Reply with quote
I have the same issue, and yes it is worse when I am driving in rain. I have some obvious rust spots around the windshield, both lower corners. My van is not over run with rust, but does have a few spots. Right now, I have all new window rubber in my "pile" of parts. I'm working on getting cash together, and then plan to take it to TransporterWerks in NC to get a repair. If I were you, I'd pull the windshield, and if there is a bit of rust, get it repaired. Try to control it now, before it gets much worse.
1987 Syncro Westy "June"
climberjohn
climberjohn is offline
PostPosted: Mon Mar 14, 2011 6:04 am    Post subject: Reply with quote
Here's a recent thread that may help you:
Windshield replacement options
http://www.thesamba.com/vw/forum/viewtopic.php?t=451423
Quick fix: As suggested by Tencentlife, smear in some RTV.
Long term fix: remove windshield, repair rust as needed, replace with new seal. (I still need to do this . . .)
-CJ
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
GBA 88West LA
GBA 88West LA is offline
PostPosted: Mon Mar 14, 2011 6:47 am    Post subject: Reply with quote
also while your there the antenna sometimes lets h20 in
88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin
SWbySWesty
SWbySWesty is offline
PostPosted: Mon Mar 14, 2011 8:49 am    Post subject: Reply with quote
x2 on the antenna seal. That was my issue. I put silicone on any holes in my windshield rubber and still had water. Replaced the antenna since it was broken and it didn't leak anymore.
1986 Westy - Billie Jean
A Westy with a Jeep heart (Pura Vida)
www.theadventurebrigade.blogspot.com - Latest update: Johnson Valley - Nov 22, 2011
kshbaja
kshbaja is offline
PostPosted: Mon Mar 14, 2011 9:01 am    Post subject: Reply with quote
You won't know until you pop the windshield. It is possible for water to get to the floor boards without a rusted-through hole in the sill. The small voids inside the old seal fill up with water and it drops down through the gap between the two pieces of metal that are spot welded together.
With that said, chances are you will have some rust. I recently had this same issue and I ended up having rust, but it was what I would call moderately pitted. There were no holes. Before I pulled the windshield there was no visible rust or bubbling at the seal. Clean it up thoroughly, fill with some fiberglass filler and repaint. Use a new seal.
You may also want to take a close look at your other windows for signs of developing rust/leaks. If you are going to have someone install the glass for you, you will likely get a break on the cost to do them all at once. In retrospect, window seal replacement is one of those things I wish I did on day 1. If the rust gets out of hand in these areas it can be very difficult to address.
1986 Westfalia
GMByers
GMByers is offline
PostPosted: Mon Mar 14, 2011 11:34 am    Post subject: Reply with quote
Since you say the water dripping down in the corners I doubt it is your antenna.
My vote is to replace your windshield seal.
And then there were two...downsized to 83 Doka &
74 Thing.
K58
K58 is offline
PostPosted: Mon Mar 14, 2011 4:24 pm    Post subject: Reply with quote
It could be the antenna or even the windshield washers if there not seated properly.
When I got my Van the antenna and washers were loose and were letting in water. It all collects in the same place on the floor so it's hard to tell where it's coming from.
madspaniard
madspaniard is offline
PostPosted: Mon Mar 14, 2011 4:30 pm    Post subject: Reply with quote
in my case, it was the antenna too but it was only leaking on the driver's side
