cotts Samba Member
Posted: Sun Mar 20, 2011 10:48 pm Post subject: De-turboing my 2276 |
Hey guys,
I live in Australia and am a massive Volkswagen fan. I am not extremely technically minded when it comes to motors. I know enough and usually let shops do the hard stuff.
My setup:
- 2276 Cb performance 45drla fed turbo setup.
- Cam -Bug pack 4065-10.(268 degrees)
- Compression 8.8 to 1
- Heads are 044s port and polished with semi-hemi cuts
- Bug pack 82 mm forged counter weighted crank.
- Runs an MSD 6AL
Made 122hp at the wheels on 8 psi.
PROBLEM
No one in Australia knows how to tune this car like i want it. I have had a 2276 N/A that ran pretty similar power wise.
Question
What would this motor be like if i took the turbo system off and got a new exhaust.? obviously i would get the DRLAs tuned etc
Any feedback would be great
cheers guys
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Mon Mar 21, 2011 7:40 am Post subject: |
Only 122? Man, you should be making a lot more. Compression is sorta high for a turbo engine, have you verfied that to be correct? _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2163 Location: Salt Lake City
Posted: Mon Mar 21, 2011 8:39 am Post subject: |
This is what you do. Pull the engine and ship it to me, I'll pull my non turbo engine and send it your way. Problem solved. _________________ Pics of my 1970 Satin Black Type 1 build |
Posted: Mon Mar 21, 2011 10:40 am Post subject: |
Sure you want to deal with the shipping charges to the AU? _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Dauz Samba Member
Posted: Mon Mar 21, 2011 11:33 am Post subject: |
miniman82 wrote: |
Only 122? Man, you should be making a lot more. Compression is sorta high for a turbo engine, have you verfied that to be correct? |
Yea, something's up. I have a 1915 Turbo that's producing 155whp with lower compression. |
67Beetle2017 Samba Member
Joined: August 01, 2006 Posts: 399 Location: Pasadena CA
Posted: Mon Mar 21, 2011 11:47 am Post subject: |
I used and still refer to the "Turbomania" book written by Bob Tomlinson to tune any of the Dellorto turbo engines I built back in the late 80's to present.
This book is very clearly written and has many jetting examples that should steer you in the right direction.
Unless you have very good fuel or only using up to 7psi of boost, 8.8:1 seems a little high. Nevertheless that should not prevent you from tuning your engine combo.
Before you remove your turbo, try tuning first.
Make sure your fuel pump and regulator are up to the job.
NOTE: I looked at the CB performance site and saw that the book is currently out of stock.
Is this a single blowthrough or draw through system? |
Rohrheim Samba Member
Posted: Mon Mar 21, 2011 2:09 pm Post subject: |
I just bought Turbomania off Ebay for $18.37 shipped. Do a search. Seller has 2 left. |
The Phil Samba Member
Posted: Mon Mar 21, 2011 8:48 pm Post subject: |
122 is damned low for having 8 psi on that engine. one of my friends has got a 2235 i believe it is, duel carb, not sure of the size, but hes got to be around the 185-200 HP mark in his buggy. also, it's not turbo'd. you might want to have that checked out. _________________ "In case I don't see you, good afternoon , good evening, and goodnight."
My '66 Baja Build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=456365
Free from the evils of facebook Dec 2012. No other Social Media. |
cotts Samba Member
Posted: Mon Mar 21, 2011 10:09 pm Post subject: |
thanks for the reply guys!
The compression is 8.8. the engine was built by wayne johnson and featured in hot vws. It should be a beast of a motor but so far it would only run low 14s in my 865kg super bug.
I run it on 98octane fuel always.
With no turbo and the right tune how would this go? i cant image there would be much difference. Would the CAM be the only thing holding it back from being a decent street motor?
can give more specs and photos if needed.
Cotts |
Posted: Mon Mar 21, 2011 10:14 pm Post subject: |
Umm, well it wouldnt be just the cam to make up the difference. in order for a cam to make a difference you'll need better lifters, better rockers. headers that allow for it breath better. its a whole chain of things. even at worst that engine should still be pulling at least 135-140 hp. its a big ass engine. like i said before for my friend, its a 2235 with around 200. but then again its also like a $3500 engine. you should be pulling sub 11's if you can shift that quickly and good enough. maybe higher 10's. _________________ "In case I don't see you, good afternoon , good evening, and goodnight."
cotts Samba Member
Posted: Mon Mar 21, 2011 11:22 pm Post subject: |
complete stats:
2276cc
crank-bug pack 82mm forged,counter weighted
robs- pauter, stroker vs,shot peeled, new bolts
cima pistons 94mm
rings- total seal
cam- bug pack 4065-10(.364' lift, 269 degree duration)
Heads- vw 044 port and polished, semi him cut
valve size and make - 40mm x 35.5mm, manley
comp 8.8:1
MSD 6al ignition
blow-trough turbo by CB performance
Duel 45 DRLA's
exhaust CB performance (no muffler)
Boost 8 psi may spike to 10. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Mar 22, 2011 2:09 am Post subject: |
I just ordered a copy from Airheads for 24.90 shipped. They have 2 left. I just couldnt justify paying 30 bucks shipping Fedex for a 20 dollar book from a couple other places. _________________ 2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1797 Location: Boise, Idaho
Posted: Tue Mar 22, 2011 8:40 am Post subject: |
That cam has tons of duration for a street turbo engine. That is FK10 type duration numbers. |
Hotrodvw Samba Member
Posted: Tue Mar 22, 2011 8:49 am Post subject: |
Too much duration for a turbo motor IMO...it's just bleeding off boost....cam isn't giving much lift either. You shouldn't need 98oct fuel with 8.8:1 c/r either....too much octane wil kill power too! _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Fall23 Samba Member
Posted: Tue Mar 22, 2011 1:32 pm Post subject: |
Have you checked for any boost levels? Leaks? |
Dauz Samba Member
Posted: Tue Mar 22, 2011 1:56 pm Post subject: |
Fall23 wrote: |
Do you have a boost gauge? |
cotts Samba Member
Posted: Thu Mar 24, 2011 12:59 am Post subject: |
Hey guys!
Engine has been checked and doesn't leak boost. Have a boost gauge and it reads around 8 maybe 10psi of boost max.
I have never been told that to much octane can be a bad thing.
The guy i purchased it off told me that when he went to 15psi he used 110 octane in the states at the drags.
Wouldn't have though that cam is to big. Inst it similar to a engle 110 or something. Considering the capacity i thought the cam was relatively small perfect for turbos. But i don't know a whole lot about the issue.
C |
Posted: Thu Mar 24, 2011 9:11 am Post subject: |
We assumed you posted the duration numbers at .050" lift, not advertised duration. |
MinamiKotaro Samba Member
Joined: July 18, 2008 Posts: 1039 Location: Somewhere in TN
Posted: Thu Mar 24, 2011 3:17 pm Post subject: |
What is your AFR under boost and what are you running for timing? _________________ 1967 VW Beetle
2276cc
MegaSquirt-extra v3.57
Check out my ongoing story. |
