Has anyone heard of a new GoWesty lift kit?
Page: 1, 2, 3, 4  Next
canasync
canasync is offline
PostPosted: Wed Feb 23, 2011 1:21 am    Post subject: Has anyone heard of a new GoWesty lift kit? Reply with quote
Just found this on the IG16 forum. Anyone heard of this?
GoWesty wrote:
We're getting very close to unveiling the amazing GoWesty 3" lift suspension kit! This kit not only raises the vehicle 1" more than our standard GoWesty lifting springs with Old Man Emu shocks—this new kit INCREASES suspension travel by one inch, front and rear.
The complete kit will include:
- Set of GoWesty 2” lift progressive suspension springs by H&R, Germany
- Set of front remote reservoir shocks with adjustable ride height and dampening, by FOX, USA
- Set of rear remote reservoir shocks with adjustable dampening, by FOX, USA
- Set of rear suspension arms, 1” longer, 1” higher spring perch, by Burley Motor Sports, USA
- All mounting hardware and instructions, and new rear brake metal lines
- Pair of upper ball joints, modified for greater travel
- GoWesty upper ball joint spacer and hardware kit
Projected price for the entire kit is $2999.99. Stay tuned!
1987 Syncro
3 knobs
PumpeDüse TDI (17mm Garret Turbo, bigger injectors, stage 4 malone tune, intercooled)
Cruise Control
Planar Coolant Heater
Remote Start/locks
Custom Lift
Custom Bumpers with receivers
Coast Mountain Hightop - Comming Soon
1985 2wd Vanagon Pre-runner in the making
soon to be powered by 2.5L Subaru
Custom Lift
syncrodoka
syncrodoka is online now
PostPosted: Wed Feb 23, 2011 6:23 am    Post subject: Reply with quote
They were talking about that kit 2 years ago but everybody that I know that asked about it was told that it isn't ready yet. Last time I talked to burley he said that they cancelled the trailing arm order with him really early. They may have old information or GW changed their mind and are pushing it out.
insyncro
Banned
insyncro is offline
PostPosted: Wed Feb 23, 2011 8:46 am    Post subject: Reply with quote
Eric Abercrombie's suspension is far superior to what was planned by GW and is available.
Wolfsburg4x4 is his handle.
Check out Eric's suspension and Subaru H6 3.0 conversion parts in this thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...ght=subaru
dylan
wolfsburg4x4
wolfsburg4x4 is offline
PostPosted: Wed Feb 23, 2011 9:58 am    Post subject: Reply with quote
Thanks Dylan but we'll have to see the GW setup to compare
There is a big difference between a "lift kit" and a suspension system. The GW setup sounds like more than just a lift kit for sure.
There is a syncro westy here in town which recently installed GW springs and it looks very tall in the back, I'm guessing around 21"
Installing the same spring on top of a 1" trailing arm spacer would put it sky high, closer to 22-23"
So GW better charge closer to $10000 for the setup to include race prepped 930cv's & axles and to cover the 100 million dollar liabilty insurance they should buy.
Progressive springs may be good for ride quality, but the initial soft rate may also mean initial body roll and at the ride height described above...
I'm visualizing a high top syncro on the two lane 395 highway during a high wind condition... ( I've been there in a syncro Adventurewagen with a normal ride height )...just saying
I don't recommend a ride height higher than around 20" for a street driven syncro, but additional suspension travel, well that's a good thing
insyncro
Banned
insyncro is offline
PostPosted: Wed Feb 23, 2011 10:08 am    Post subject: Reply with quote
By far superior, I mean, designed as a suspension system, Yes.
Adding taller springs, shims and extensions may work for some to make the van look more appealing,
but after seeing Eric's parts first hand and riding in his van, the "system" he is offering is my choice for custom suspension tuning.
Remember Eric....you explained it all to me and talked me out of needing reservoir shocks for my application.
The perch, the right spring rates and proper installation with alignment should satisfy most Syncro owners.
Now I just need to finish the bodywork on the Syncro getting this system.
Talk soon.
dylan
burleymotorsports
burleymotorsports is offline
PostPosted: Wed Feb 23, 2011 9:44 pm    Post subject: Reply with quote
Burley Motorsports did build several sets of 16'' rear arms for the Gowesty fox shock suspension kit. From what I'm reading here it sounds like it will be out soon. I look forward to seeing it.
Protect your investment !
Buy only genuine Burley Motorsports products
I will not see your PM.
Please email us directly through our website at http://www.burleymotorsports.net . Thank you.
Web: http://www.burleymotorsports.net
Facebook: http://www.facebook.com/burleymotorsports
Instagram: http://www.instagram.com/burleymotorsports
syncrodoka
PostPosted: Thu Feb 24, 2011 1:22 am    Post subject: Reply with quote
I found the exact ad. Unfortunately it is from July '09, unless they are pushing the project forward this is old info(possibly dead?).
http://www.gowesty.com/newsletter.php?newsletter_id=19
They had the system on Lucas's van at SDM '08 and there was a lot of interest in it.
BenT Syncro
BenT Syncro is offline
PostPosted: Thu Feb 24, 2011 3:05 am    Post subject: Reply with quote
Well, if they go forward with the project, someone ought to consider making wheel arches to cover wider wheels and tires that could be used to widen the track and improve stability as a result of the raised suspension.
BenT
syncrodoka
PostPosted: Thu Feb 24, 2011 3:09 am    Post subject: Reply with quote
BenT Syncro
PostPosted: Thu Feb 24, 2011 3:18 am    Post subject: Reply with quote
syncrodoka wrote:
Who's making those? I saw a Doka pic with Defender flares too. Although I doubt the fancyboi Syncro crowd will go for the Landrover lederhosen look. Wink
syncrodoka
PostPosted: Thu Feb 24, 2011 3:23 am    Post subject: Reply with quote
Custom jobby like most of the truck.
I have heard that there is a guy in the city that has overseas connections that can have flares made. Wink
BenT Syncro
PostPosted: Thu Feb 24, 2011 3:29 am    Post subject: Reply with quote
Have a couple of samples. Production stopped because of gov'ment meddling with funds. The novelty kind of wore off. Tied up enough to buy a few nice Tristars. Crying or Very sad
snowsyncro
snowsyncro is offline
PostPosted: Thu Feb 24, 2011 7:12 am    Post subject: Reply with quote
BenT Syncro wrote:
Aren't those Silverado flares? taigagreen would know...
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=40
RonC
BenT Syncro
PostPosted: Thu Feb 24, 2011 7:40 am    Post subject: Reply with quote
RonC
RonC,
The Doka I was referring to is lighter blue. I was talking about this guy:
GrindGarage
GrindGarage is offline
PostPosted: Thu Feb 24, 2011 7:42 am    Post subject: Reply with quote
nice stance those flares rock
-cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com
Wolfgang16
Wolfgang16 is offline
PostPosted: Thu Feb 24, 2011 8:48 am    Post subject: Reply with quote
I asked GoWesty about the 3" lift kit and they answered that it will take at least another 6 months. Rolling Eyes
Wolfgang
T3 syncro16 `89 TDI AFN, DPF, Papmahl intercooler, Seikel springs, 31x10.50R15 on T4 rims
syncro in Central Asia 2009
BlackDogVan
BlackDogVan is offline
PostPosted: Thu Feb 24, 2011 9:08 am    Post subject: Reply with quote
I'm pretty sure the dark blue doka's are from a chev truck IIRC from a thread a while back. Massaged.
Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Still addicted, looking for Doka...
burleymotorsports
PostPosted: Thu Mar 24, 2011 8:17 pm    Post subject: Reply with quote
Burley motorsports will have Trailmaster suspension kits on display at Syncrofest. These kits are front and rear springs with matching shocks, adjustable lift from stock to 1.5'' We will also be displaying our other adjustable suspension solutions at Syncrofest. Burley
VWhead
VWhead is offline
PostPosted: Thu Mar 24, 2011 9:18 pm    Post subject: Reply with quote
I know you have been hard at work Burl. Can't wait to see all your new goodies! Very Happy
81' Single Cab Syncro 1.8T GMW
88' 2wd Westy 1.8T GMW
www.gmwerks.com
canasync
canasync is offline
PostPosted: Thu Mar 24, 2011 10:42 pm    Post subject: Reply with quote
Interesting. From my talks with Trailmaster Germany I was assured that I would be the sole distributor for their line of suspension kits in North America.
Thanks for the heads up.
1987 Syncro
3 knobs
Cruise Control
Remote Start/locks
Custom Lift
Custom Lift
Page 1 of 4
