Tired of sanding! How much is enough? Help...
Page: 1, 2, 3, 4  Next
aircooled356
aircooled356 is offline
PostPosted: Wed Mar 30, 2011 11:46 am    Post subject: Tired of sanding! How much is enough? Help... Reply with quote
Well, I decided to cut and replace all of the cancer on my 57' Baja late last year. Found more than I thought....seems like that is always the case. Also found a couple of bullet holes thru the B pillar and a shit load of bondo. Shocked This was my first attempt at serious bodywork but I've enjoyed it alot except for the tedious task of getting it perfectly straight. So, I am at the point of skim coating the low spots with bondo and knocking it down progressively with 60,120 and 220 grit. I'm at the 220 stage now but I've got some mild wave action going on but it must only be a few thou difference. I'm using a paint stick for a sanding board which is working well. Does it have to be perfect before primer or is that what final blocking is for? This is my first real attempt at bodywork and paint (did sand and paint a 32' school bus back in the day but I'm looking for a more professional result). I thought this little body would be a snap but......man I'm sick of the sanding and dust all over my nice garage! Hopefully someone will tell me that the blocking will go more quickly. Rolling Eyes
spook
spook is offline
PostPosted: Wed Mar 30, 2011 11:52 am    Post subject: Reply with quote
sand till straight
www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here.
View user's profile Send private message Visit poster's website Facebook Twitter Classifieds Feedback
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Mar 30, 2011 12:01 pm    Post subject: Reply with quote
Rattle can some red oxide primer on some spots and you can see if it's perfect. 320 grit is as high as I go before epoxy primer.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
aircooled356
PostPosted: Wed Mar 30, 2011 2:42 pm    Post subject: Reply with quote
Bummer. I guess I'll keep sanding away at it. Can I primer over 220 or should I go to 320?
spook
spook is offline
PostPosted: Wed Mar 30, 2011 5:28 pm    Post subject: Reply with quote
320
SBS US #10
dawerks
dawerks is offline
PostPosted: Wed Mar 30, 2011 7:46 pm    Post subject: Reply with quote
Sucks huh? Smile
You can wet sand once your high build is on so that gets rid of all the mess. And if you spray with water, that's how it will look when it's painted.
(I'm in the same boat dude, it's not fun at all, and my helper is not that good haha).
"There is only one sin; disconnection from self."
TonysGarage
Banned
TonysGarage is offline
PostPosted: Wed Mar 30, 2011 8:30 pm    Post subject: Reply with quote
unfortunately, once you think you're done with the sanding---you're gonna have to go once more.
but--let me caution you--and i'm surprised nobody has said anything yet--i wouldn't be surprised if many of the waves are caused by sanding with a paint stick. if your block isnt dead on flat--you will be creating small waves instead of removing them---with all that work its a shame not to spend a few bucks and get a block.
just to give you an idea---about 4 years ago i had a customer who was doing his own bodywork swing by and ask for some advice cause he could not get the wave out--he said he spend maybe 8 hours sanding but it never helped--i glanced at his block and noticed it wasn't flat---he was wasting TONS of time!--within 15 minutes i had it all straightened out with a proper block.
I dont take shortcuts, i put care and pride into all i do--for a fair price of course
dawerks
dawerks is offline
PostPosted: Wed Mar 30, 2011 9:56 pm    Post subject: Reply with quote
On blocks, when is it a good time to chuck them? I have durablocs but I noticed one of my favorite ones has the edge a little bit rounded off. Does that mean it's a toss??
aircooled356
PostPosted: Thu Mar 31, 2011 9:04 am    Post subject: Reply with quote
Well, as this is my first real attempt at doing it right, I have wasted many hours for sure but I'm learning alot in the process. Gotta put in the time I guess. If it was easy everyone would be doing it. Wink I did buy a block (2 3/4"x12" foam type) but it is more flexible than the stick. Maybe I should give it another try. Thanks for all of the advice.
beetlenut
beetlenut is offline
PostPosted: Thu Mar 31, 2011 10:22 am    Post subject: Reply with quote
I bought this 3M one and have been very happy with the results so far!
scrapyards are for quitters
Wetstuff wrote:
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again.
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Thu Mar 31, 2011 11:21 am    Post subject: Reply with quote
Is way to big of a block for the curves
Hopefully you are sanding only the flat spots with this !
Experience always triumphs over hearsay and You get to select which theory to believe
JerryMCarter1
PostPosted: Thu Mar 31, 2011 11:23 am    Post subject: Reply with quote
On second thought-- is there any way you can work with someone and have them mentor you for the first few jobs ?
The tricks of the trade are not well explained unless one is in person - watching and then suggesting
aircooled356
PostPosted: Thu Mar 31, 2011 11:56 am    Post subject: Reply with quote
Yes, I've only used it on the doors so far. Not many flat areas on these cars! As far as mentoring, the closest shop is nearly an hour away. I'll figure this out sooner or later......most likely later.
eshan2
eshan2 is offline
PostPosted: Thu Mar 31, 2011 1:30 pm    Post subject: Reply with quote
Work in an X pattern this will help alot along with a proper block.I posted this in another thread the other day they are what I have and are very good.A little pricey but worth it.
http://www.tcpglobal.com/autobodydepot/afssanders.aspx
Now you know why this work is so expensive to hire out.nothing is really "cheap"
I love the smell of nitro in the morning.
1963 Beetle currently under reconstruction.
Ernest.
Foxx
Uncle Meat
Foxx is offline
PostPosted: Fri Apr 01, 2011 8:30 am    Post subject: Re: Tired of sanding! How much is enough? Help... Reply with quote
aircooled356 wrote:
::snip:: .man I'm sick of the sanding and dust all over my nice garage! Hopefully someone will tell me that the blocking will go more quickly. Rolling Eyes
pay someone to do it or stop now and let it look like poop.
bodywork is not like replacing brakes or doing a motor,
it is done when you are happy with it,..ain't happy? then you ain't done.
ain't done but tired,..paint will look like shit for half measures.
Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot.
JerryMCarter1
PostPosted: Fri Apr 01, 2011 9:00 am    Post subject: Reply with quote
You so not need to find a shop == they will just tell you whatever they need to say to get you to spend money there
You need someone that has done it before to help you out -- for free !
Just try to do that -- just ask -- like on Craig’s list or here in the Samba -- take time to ask around
Mike Fisher
PostPosted: Fri Apr 01, 2011 9:49 am    Post subject: Reply with quote
If you had it All in red oxide primer you could See all the bad spots that need more work and drive it while you work on it.
aircooled356
PostPosted: Sat Apr 02, 2011 7:29 pm    Post subject: Re: Tired of sanding! How much is enough? Help... Reply with quote
Exactly. That's why I'm asking how far to go. Consensus is get it straight before primer. I will not give up or take it to someone after all of this hard work. I can feel the areas needing work so I will press on. I'm on a mission...and when I'm satisfied with it I will move on to the next step. Wink
JerryMCarter1
PostPosted: Sat Apr 02, 2011 9:20 pm    Post subject: Reply with quote
Yosemite
ya got the right stuff !
Foxx
Uncle Meat
Foxx is offline
PostPosted: Sun Apr 03, 2011 5:31 am    Post subject: Re: Tired of sanding! How much is enough? Help... Reply with quote
Bravo!
Frank
OG JHC
59 panel
Page 1 of 4
