Non-standard, Heavy Duty Ignition Switches?
msinabottle
msinabottle is offline
PostPosted: Thu May 12, 2011 12:51 pm    Post subject: Non-standard, Heavy Duty Ignition Switches? Reply with quote
I DO NOT WORK FOR WAYTEK!
But I got this link--apparently they're selling heavy-duty ignition switches. Has anyone adapted them for a Vanagon? While the stock one is easy to replace, how about one we DON'T need to replace every three or so years?
http://tinyurl.com/6jut2fy
Thoughts?
Here's the text:
Waytek Adds More Ignition Switches
Heavy Duty Three Three Position Two Position Four Position
Position Ignition Switch Ignition Switch Ignition Switch Ignition Switch
Stock No. Stock No. Stock No. Stock No.
44176 44177 44175 an 44178 44179
Marine Ignition Switches
• Durable PVC key boot for increased weather-resistance
• Corrosion-resistant nickel silver screw terminals have high electrical conductivity
• Screw terminals give more reliable connection that is less likely to loosen due to vibration
• 6-36V DC; 15A Ign, 20A Start
Stock No. 44184
Off-Run-Start
Stock No. 44185
Off-Run-Start with push to choke
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
photogdave
photogdave is offline
PostPosted: Thu May 12, 2011 1:02 pm    Post subject: Reply with quote
I replaced my ignition switch twice in the first two years ownership. After the second replacement someone gave me a great tip - take all the extra keys off the ring! I keep my ignition and Club key on a separate ring and I haven't had a problem with the switch in six years.
89 Syncro GL Westfalia 2.1 WBX/WBXaustSS
My Westy Movies:
photogdave On Vimeo
photogdave On YouTube
sub-hatchtim
sub-hatchtim is offline
PostPosted: Thu May 12, 2011 1:04 pm    Post subject: Reply with quote
you should do that with all vw ign weight kills them
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
r39o
Samba Polizei
r39o is offline
PostPosted: Thu May 12, 2011 1:58 pm    Post subject: Reply with quote
Word
I have only the ignition key and house key on my VW keys. Working fine for decades.....
FYI: *IF* you put some other switch then you still have to unlock the steering column, unless you defeat the lock pin.
All a bunch nonsense for not keeping a light set of keys.
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu May 12, 2011 2:04 pm    Post subject: Reply with quote
That lead weigh key chain is not good? Embarassed
vanjoe
vanjoe is offline
PostPosted: Thu May 12, 2011 9:41 pm    Post subject: Reply with quote
There really isn't a need for an aftermarket ignition switch. Here is the solution. I ordered one and already installed it. It takes 10 minutes top.
http://www.thesamba.com/vw/classifieds/detail.php?id=1066289
1990 VW Vanagon tin top weekender Carat
1998 Mercedes S420
"Why is there never time to do it right the first time, but there is always time to do it twice?"
"Back to the basics!"
Volksaholic
Volksaholic is offline
PostPosted: Fri May 13, 2011 5:41 am    Post subject: Reply with quote
I assume this heavy duty solution is to solve the electrical failure, not the mechanical failure from having too many keys dangling... is that right? If that's the case, I'm with Vanjoe... why come up with a more expensive, complicated, and potentially butt-ugly solution to a problem that can be resolved by letting a relay take the electrical load? I think a lot of folks are more likely to create more problems just trying to get the electrical right than what they would solve by having the heavy duty contacts.
If the problem is too many keys, just keep a helium filled mylar frog balloon tied to the keys to help counteract the weight. Pretty simple, effective, and inexpensive solution, unless you don't like frogs. Wink
Paul
1988 Wolfsburg Edition, 2001 Subaru EJ251
dhaavers
dhaavers is offline
PostPosted: Fri May 13, 2011 8:14 pm    Post subject: Reply with quote
^^^ Laughing Laughing Laughing
"The WonderVan"
IdahoDoug
IdahoDoug is offline
PostPosted: Fri May 13, 2011 8:48 pm    Post subject: Reply with quote
Except that some states - including Nevada - are initiating mylar frog testing and helium will violate the particulate standard. So you could be in for a fine as this was not original VW equipment*
*Just joking here - not intended to single anyone out.
