Radiator Fan Won't Shut Off
ddye
ddye is offline
PostPosted: Wed Jun 15, 2011 5:53 pm    Post subject: Radiator Fan Won't Shut Off Reply with quote
Oddness has occurred. Any ideas why the radiator fan won't turn off? I replaced the switch behind the headlight about 2 months ago and the temperature sensor that plugs into the radiator at the same time. It was working fine and then today when i started the van the fan came on....it was cold. Now every time I turn the key the fan comes on.
Curious
1988 Westy
2.1 Boston Bob Rebuild
"Nelly"
danfromsyr
danfromsyr is offline
PostPosted: Wed Jun 15, 2011 6:06 pm    Post subject: Reply with quote
is your AC left on?
this will happen if the switch is left bumped on on some years,.
Abscate wrote:
ddye
ddye is offline
PostPosted: Wed Jun 15, 2011 6:09 pm    Post subject: Reply with quote
danfromsyr wrote:
is your AC left on?
That was it. The wife drove yesterday and didn't get it all the way off.
Thanks!
Very Happy
1988 Westy
"Nelly"
debbiej
debbiej is offline
PostPosted: Wed Jun 15, 2011 10:12 pm    Post subject: Reply with quote
better than won't turn on
peasant
peasant is offline
PostPosted: Thu Jun 16, 2011 7:41 am    Post subject: Reply with quote
True, I felt so much better and so did my van when I replaced parts to get it working properly.
89 wolfsberg weekender carat
89 Westfalia
Memphalia
Memphalia is offline
PostPosted: Fri Dec 30, 2011 12:59 pm    Post subject: Reply with quote
Ok so I was driving home today and the radiator fan kicked on high and ran on high the rest of the way home and when I turned off the ignition, the fan remained on. I checked the AC to make sure that it is off an it is. Any ideas?
1989 Westfalia (Wolfram Gray)(Mona)
2004 Toyota 4Runner SR5 4x4
2005 Volvo V70
SCM
SCM is offline
PostPosted: Fri Dec 30, 2011 1:41 pm    Post subject: Reply with quote
It's normal for them to stay on for a few minutes after turning off the vehicle when it's hot.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
Memphalia
PostPosted: Fri Dec 30, 2011 2:42 pm    Post subject: Reply with quote
Yes, I am aware of this, but it will not shut off. I had to disconnect the battery to turn it off and 2 hours later when I reconnected the fan came back on. Possibly relay or fan switch? HELP
2005 Volvo V70
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Dec 30, 2011 2:59 pm    Post subject: Reply with quote
Pull fuse #1, on left end of fuses. Does this stop the fan running?
What year?
Mark
Memphalia
PostPosted: Fri Dec 30, 2011 4:10 pm    Post subject: Reply with quote
Yep, pulled the fuse and still running. I also unplugged the radiator fan switch and still running.
2005 Volvo V70
crazyvwvanman
PostPosted: Fri Dec 30, 2011 4:51 pm    Post subject: Reply with quote
Ok, pull the relay from relay socket #5. Count from top left of main relay panel. That is the medium speed fan relay for the A/C. If that stops it, there is a problem in the back, in the A/C wiring or A/C relays back there.
If it doesn't stop it, could be the highest speed relay hidden up above the main relay panel, or it could be a weird wiring problem from the back A/C as a wire from the A/C connects to the control line for the high speed relay.
Mark
Memphalia
PostPosted: Fri Dec 30, 2011 8:26 pm    Post subject: Reply with quote
THere is no relay in the 5 spot, and i have been driving daily for 2 years like this (with everything working properly). The fan is stuck on high mode. How can I identify the highest speed relay hidden up above the main relay panel and test it? Where is it available for replacement? I ordered this
http://www.van-cafe.com/home/van/smartlist_1436/relay.html
Is this what should be in the 5 spot?
Oh, by the way it is an 89 Westy Full camper
2005 Volvo V70
crazyvwvanman
PostPosted: Fri Dec 30, 2011 9:34 pm    Post subject: Reply with quote
All 89 vans should have the relay in position 5 unless they are Syncros without A/C. That relay you linked to is not the right one for position 5, as far as I know.
In any case the missing position 5 relay isn't causing this problem. The high speed relay is up inside the dash area at the left end. It is hard to see without removing something. Look at Bentley page 87.5 and the drawing on the upper right shows the relay behind the left dash vent. That is the highest speed rad fan relay, 3rd stage.
(on left of same page shows relay panel with arrow to position 5 for 2nd speed fan relay)
I can't find the right relays on VanCafe site so here is another source.
This is the highest speed 3rd stage fan relay-
http://www.autohausaz.com/search/product.aspx?sid=...an%20Relay
This one will work in a pinch for 3rd stage-
http://www.autohausaz.com/search/product.aspx?sid=...3604@Relay
This (upper) one is what I would expect in position 5-
http://www.autohausaz.com/search/product.aspx?sid=t0h4evvhuh0ojx45zqn0e345&partnumber=141951253B
It sounds like your 3rd stage fan relay stuck in the on position. If so, I wonder why it was coming on at all this time of year, unless the low speed isn't working and that is a common failure that should be checked after you get past this constant fan problem.
Mark
Memphalia
PostPosted: Fri Dec 30, 2011 10:35 pm    Post subject: Reply with quote
Thank you sir, I have ordered and will try!
2005 Volvo V70
koolmoe
koolmoe is offline
PostPosted: Mon May 05, 2014 12:35 pm    Post subject: Reply with quote
Just FYI and a bump. My fan had been running as soon as I started the Bus for about a week and kept meaning to search here to figure out why...and did today, and first result was this thread...and went out and checked and indeed the AC knob was half-way 'on'...
(which is odd cause my AC hasn't been charged in years and I never use it - probably one of the kids messing around)...
So thanks for the thread and replies. Turning off knob stopped the fan startup. Phew! Love the easy fixes, so rarely the result on this old gal...
KM
Current: 1990 Westy GL (Savannah. Good to be back!)
from '95 til 2008: 1995 Pathfinder (frame rusted out, charitable parts donation)
from '91-'95: 1982 Westy Diesel (Smokey. Traded in for far too little!)
from '87-'91: 1980 VW Rabbit (my econoPorsche - passed on)
danfromsyr
PostPosted: Mon May 05, 2014 12:45 pm    Post subject: Reply with quote
WOW, blast from the past.
and to note that this can be a benefit as well.
those whose AC works this way can turn the Rad fan ON to help after a long hard or hot hill/mtn/traffic
just make sure you turn it back OFF once things are evened out.
*note I've heard at least 1 story of a burned out rad fan or AC clutch from prolonged power demand. food for thought.
Abscate wrote:
Pastelweis
Pastelweis is offline
PostPosted: Sun Sep 25, 2016 5:47 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
@memphalia I have the exact same problem, did you find a solve in the end?
rustbuckets
rustbuckets is offline
PostPosted: Thu Nov 21, 2019 8:21 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
Just came across this post and hoping someone will see this. I am having the same problem that a previous poster described with their radiator fan staying on even after the van is turned off. However, when I pull the fuse for the fan it turns off. Would anyone happen to know what that would mean the problem is?
MarkWard
MarkWard is offline
PostPosted: Thu Nov 21, 2019 9:16 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
First step would be to unplug the radiator fan temp switch and see if the fan shuts off. You need to remove the upper grill. If you haven’t done this, you need to learn. Report back.
damagd
damagd is offline
PostPosted: Sun Jun 21, 2020 7:56 am    Post subject: Re: Radiator Fan Won't Shut Off Reply with quote
I am having the same problem. 1990 automatic. I was climbing a steep grade outside Buffalo, Wyoming and the fan came on at high speed as usual when the temp went up, however it stayed on even after I turned the van off. Had to disconnect the battery. I tried pulling fuse #1, relay #5 (the grey one labeled 53), and the plug on the radiator behind the lower grill. Nothing made it stop. I drove about 20 miles like this and now I fear it may have burned up my alternator as voltage kept dropping. What should I try next?
