ch356 Samba Member
Posted: Tue Jun 21, 2011 12:46 am Post subject: Early Aluminum engine case |
Guys,
I have an early aluminum VW case which came in a part box with a 356 I purchased. Am I correct in interpreting the Samba VIN page that this is a Mar 1950 engine? It also came with a crankshaft mounted fan which I thought unusual. Not sure if the fan goes with this engine or not. Note the nice case match stamp (#1). Any ideas what I have?
Whatsthatsmoke Samba Member
Posted: Tue Jun 21, 2011 1:03 am Post subject: |
VW bus engine, looks like it's hardly been used? |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3856 Location: Twin Cities, MN
Posted: Tue Jun 21, 2011 8:24 am Post subject: |
The casting information can be interpreted here:
29 = day
3 = month
10 = year (1st shift) 1950
0 = 1950, 1 = 1951, 2 = 1952, 3 = 1953, 4 = 1954, 5 = 1955, etc
It appears by the number to be a very early bus case (April 1950)
There should be a pair of numbers on the top near the front flange seam that match indicating the halves belong together.
The KD 299489 on the oil filler neck make me thing it was reconditioned at some point. What is the diameter of the cylinder openings? |
ch356 Samba Member
Posted: Tue Jun 21, 2011 9:12 am Post subject: |
nlorntson wrote: |
29 = day
3 = month
Thanks for the info. There is a case half matching number, although it's a little difficult to see in the photo. It's simply "1". |
Tonny_Larsen Samba Member
Posted: Tue Jun 21, 2011 12:58 pm Post subject: |
nlorntson wrote: |
29 = day
3 = month
I have a engine stamped 4 - 7 - 20.
4 = day
7 = month
20 = year
Is 2 for second shift and 0 for 1950 ? What means shift ?
-Tonny |
Posted: Tue Jun 21, 2011 5:11 pm Post subject: |
a "shift" is the 8 or so hour period of a 24 hour day that the case was casted. Many manufacturing, healthcare, etc. industries have 1, 2, or 3 "shifts" in a workday. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Wed Jun 22, 2011 4:28 pm Post subject: Re: Early Aluminum engine case |
ch356 wrote: |
Guys,
Pardon my ignorance, but what is the rusty fitting on the generator stand? Breather?
And please post a picture of the crank mounted fan. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71531 Location: Phoenix 602
ch356 Samba Member
Posted: Wed Jun 22, 2011 6:43 pm Post subject: |
EverettB wrote: |
The fitting is probably for the 356 full flow oil filter, correct?
I've seen a few original 356 cases with a hole there. |
356 two piece cases (prior to late '54) have the fitting there for the oil filter return line (sorry, they only had a bypass filter, not full flow). If VW didn't do this, then it looks like someone used this case for a 356 at one time.
Is this case a particularly rare item or ho hum? |
