Best way to clean a motor?
quartermilecamel
quartermilecamel is offline
PostPosted: Fri Aug 05, 2011 11:06 am    Post subject: Best way to clean a motor? Reply with quote
If I had a chevy v8 in my bus I would just cover carb and dizzy and pressure wash the motor. My concern here is dirt/grinding dust getting in behind the crank pulley. My motors really dirty on top and bottom. Is it still safe to pressure wash it or is that a no no?
Waiting for santa to drop off funky green. I can wish can't I????
Emeritusx
Emeritusx is offline
PostPosted: Fri Aug 05, 2011 11:10 am    Post subject: Reply with quote
I have power washed mine, but I keep it running... Also I never directly shoot at certain areas, like behind the pulley, at the carb/dist, etc.. That purple crap from local stores works good.. I like a 4 to 1 mix water to purple... Stuff is kinda amazing... A little kerosene will cut thru the real nasty stuff...
82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠
RPGreg2600
RPGreg2600 is offline
PostPosted: Fri Aug 05, 2011 11:37 am    Post subject: Reply with quote
You could stuff a rag behind the pulley just to keep stuff from running behind there.
sub-hatchtim
sub-hatchtim is offline
PostPosted: Fri Aug 05, 2011 11:55 am    Post subject: Reply with quote
heavy duty oven cleaner works wonders along with purple power previously mentioned
if you use oven cleaner you have to be careful it will etch aluminum and take off paint
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
quartermilecamel
PostPosted: Fri Aug 05, 2011 1:05 pm    Post subject: Reply with quote
....you mean the purple driveway cleaner
justcruzin
justcruzin is offline
PostPosted: Fri Aug 05, 2011 4:30 pm    Post subject: Reply with quote
This is how I did mine! ( hubby is in this pic, but I did the first part of the cleaning, he just wanted to do better! LOL)
Very Happy
Yah, it was my bug, but we would do the bus the same way! Very Happy
Kim
Sacramento, CA
1964 Split Window Bus
1966 Beetle Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=472933
1969 Delivery Van= http://www.thesamba.com/vw/forum/viewtopic.php?t=566282
1970 Westy Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=479538
1971 Squareback Build Thread = http://www.thesamba.com/vw/forum/viewtopic.php?p=6652459#6652459
1970 Single Cab, Samson = http://www.thesamba.com/vw/forum/viewtopic.php?p=8022609#8022609
gatorwyatt
gatorwyatt is offline
PostPosted: Fri Aug 05, 2011 4:49 pm    Post subject: Reply with quote
Mineral spirits in an air pressurized canister...a little on the expensive side but works great and doesn't leave residue that purple stuff does nor does it etch...all my tins are powder coated so that might not work for your situation...not sure if you have show paint or anything other than stock.
www.blastserv.com
wanted:
Nothing!
Emeritusx
PostPosted: Fri Aug 05, 2011 5:08 pm    Post subject: Reply with quote
I use purple power, but that stuff looks good too..
quartermilecamel
PostPosted: Fri Aug 05, 2011 10:44 pm    Post subject: Reply with quote
Yes I do have show paint. 1. you step on over to my bus. 2. you ask me to show you where the paint is. 3. I point out........theres some over there, just past the rust.
Im just wanting to clean up all the shit off of it. Years of build up/metal grinding dust from overhead engine hatch installation.
Clara Premium Member
Clara is offline
PostPosted: Sat Aug 06, 2011 7:28 am    Post subject: Re: Best way to clean a motor? Reply with quote
I avoid hitting the paper tubes distributor or carb.
I like to spray simple green on the greasy areas. I find the purple stuff can leave streaks in the paint.
You may choose to wash under the motor first.
I do aim at the area between crank pulley and case.
It is fine to leave it running. If it stalls out, you probably will need to remove the cap and wipe it with a dry clean rag before restarting it. When leaving, check brakes for function they may be wet.
hell, take the seats out and wash the whole bus:
jack points:
cargo floor:
doglegs:
quartermilecamel
PostPosted: Sat Aug 06, 2011 11:41 am    Post subject: Reply with quote
Very Happy
Ok, now I just have to call cheating there Laughing
justcruzin
PostPosted: Sat Aug 06, 2011 12:55 pm    Post subject: Reply with quote
Very Happy
Very Happy Razz
Kim
Sacramento, CA
quartermilecamel
PostPosted: Sat Aug 06, 2011 3:36 pm    Post subject: Reply with quote
I think Im going to unplug the plug wires and ziplock the dizzy and carbs. Im also guessing by reason of crackage that its not a good idea to spray the heads and cylinders from the bottom.......especially while running. I dont have any simple green. just gonna use the old spray degreaser I guess.
Emeritusx
PostPosted: Sat Aug 06, 2011 5:41 pm    Post subject: Reply with quote
thats why I leave it running... like adding water to a hot car - needs to be running or it will crack... no different then hitting a big puddle will driving...
I've done all my air cooled this way, never cracked one yet...
quartermilecamel
PostPosted: Mon Aug 08, 2011 1:23 am    Post subject: Reply with quote
Used the simple green and a garden hose. Didnt quite get it so I went to the car wash/still used simple green. Worked much better. Will have to go back for a spotless clean.
