Roadhawg Samba Member
Posted: Tue Aug 23, 2011 7:08 am Post subject: |
So we took the leap and started this on our Bus.
The red comes of pretty easy....it's all rubbery and gross, dunno what they used to paint it!! The white is really tough though.
But there is loads of filler under the red and white. It seems the bus was prepped pretty well but then just painted with really bad paint
The original top is kind of like a creamy white...There is blue underneath that but only a very thin layer....So think the bus was originally blue/white....But it was a Kombi and I thought those were mostly single color. _________________ 1966 11 window
Rusty as hell.
www.fahrvergnugen.co.za
JoHazardburg, South Africa |
Islero Samba Member
Posted: Thu Aug 25, 2011 12:52 pm Post subject: |
Realy awesome job and description of the process!
ratherb-buggin Samba Member
Joined: January 30, 2005 Posts: 994 Location: Shawnee, KS
Posted: Thu Aug 25, 2011 1:00 pm Post subject: |
Wow! Sweet! And agreed with Islero on the description of the process. I might have to try that trick since I thought I was going to have to do a total repaint! I didn't know you had the same issue, till I went back a few pages.
Vintageyacht Samba Member
Joined: August 03, 2008 Posts: 68 Location: Lake Tahoe, CA
Posted: Tue Aug 30, 2011 12:41 am Post subject: |
Nice! _________________ M-Plate content: Model Type 2 (T2) mod. 225(1) :
- Microbus
- 7 seater (arrangement 2-2-3)
- Sliding door right
- Sliding roof
- LHD
Model year 1971
Paint color
Color upper part : L90D - Pastel White
Color lower part : L53D - Niagara Blue
Interior color (doorpanels and seats) 40 - Black Leatherette
Destination USA, Houston/San Antonio
Last edited by Vintageyacht on Thu Sep 08, 2011 1:27 am; edited 2 times in total |
Posted: Tue Aug 30, 2011 4:44 am Post subject: |
Our bus seems to be blue on the bottom and creamy white on top....But under the cream/white is also blue.
Where 2 toned busses painted the entire bottom color first and then the top?
What color would you say this is under the white:
Rusty as hell.
6voltbus Samba Member
Joined: January 24, 2011 Posts: 20 Location: Nottingham, UK
Posted: Sun Sep 04, 2011 3:11 pm Post subject: |
I was in my garage a few weeks back looking for something to do. I started to pick away some of the blue paint on my bus at the top of the screen post - I'd chipped some blue off last year and found the original L345 grey under it. So after a couple of hours I'd stripped the screen post and decided to carry on after reading this thread. After many hours work using Nitomors paint stripper, I've just finished the front end. I'm happy with how it turned out - just got the rest of it to do now.
[img]
[/img]
[img][/img]
[img][/img]
[img][/img] |
stale air Samba Member
Joined: August 23, 2007 Posts: 5724 Location: Senoia Ga, formerly NorCal
Posted: Sun Sep 04, 2011 8:22 pm Post subject: |
Lookin good!!  _________________ WANTED: Henry Veale Santa Rosa plate frames
moogie32 Samba Member
Joined: April 06, 2005 Posts: 665 Location: Connecticut
Posted: Wed Sep 07, 2011 4:07 am Post subject: |
Looks fantastic, 6voltbus! Can't wait to see more. How did you blend your paint in? _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Doch leider musst du von uns gehn |
Posted: Wed Sep 07, 2011 4:14 pm Post subject: |
| Thanks for the compliments guys. I bought a tin of L345 grey but either my old paint had faded or the new paint was too dark as it didn't match too well. I took a small amount of paint then started adjusting it with white and yellow untill I was happy with the colour match. I only wanted to paint the areas that had been bare metaled so I used a small airbrushing gun to spray it. I tried to just overlap the old paint with light coats of paint to avoid leaving a line - it took 2 or 3 attempts before I was happy with it. After it had dried I carefully polished the paint back to blend it in. It did take a while as I'm not a pro painter but getting the colour right is important if you're just doing a small area on a large panel. The smaller stone chips I did with a small brush then polished them later. It isn't a show quality job as the paint is 53 years old and going thin in a few places. I just wanted a tidy looking VW with as much original paint as possible. |
Posted: Wed Sep 07, 2011 7:30 pm Post subject: |
| Islero wrote: |
Realy awesome job and description of the process! |
Thanks, Islero!
| ratherb-buggin wrote: |
Just find a paint match to what's on your bus now and not what the formulation was originally - reds are notorious for fading - I don't know how easy matching it will be - good luck and let us see your results, ratherb! _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Posted: Fri Sep 09, 2011 9:06 am Post subject: |
Man this is depressing. All you guys have this awesome OG paint under the new stuff. I'm finding more bondo that paint  _________________ 1966 11 window
Rusty as hell.
Posted: Fri Sep 09, 2011 3:39 pm Post subject: |
| I had some bondo on the nose of mine and I think there is some on the rear corners too. Hope the sides aren't too bad. Just glad every stone chip wasn't rubbed back to bare metal or there would be very little paint left. Hope you find some good paint Roadhawg. |
Posted: Mon Sep 12, 2011 7:42 pm Post subject: |
| Roadhawg wrote: |
Man this is depressing. All you guys have this awesome OG paint under the new stuff. I'm finding more bondo that paint  |
Don't despair Roadhawg - there were areas of my ghia (especially the back) that had a lot of dent repair - keep on moving and you're bound to find areas less affected. My rear decklid had a lot of bondo covering the whole section under the license plate and I was lucky enough to find another original decklid in the pacific blue which I swapped with what I had. Just keep in mind that your VW probably wouldn't have been repainted if it didn't have to be.... _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Posted: Tue Sep 13, 2011 2:08 am Post subject: |
Ya I guess we just gotta keep going... I mean it's not like we can go back now!
The other upper rear corner is actually realy nice with hardly any filler or sanding spots, so that brought hope. I'm just putting off going past the seam where the corner meets the bus side....coz that's a big daunting panel man!!!  _________________ 1966 11 window
Rusty as hell.
Posted: Tue Sep 13, 2011 7:13 am Post subject: |
| moogie32 wrote: |
| Islero wrote: |
Thanks, Islero!
Just find a paint match to what's on your bus now and not what the formulation was originally - reds are notorious for fading - I don't know how easy matching it will be - good luck and let us see your results, ratherb! |
Thanks Moogie! That's the plan! Just need to finish getting my 68 Euro Bay back on the road and then it's full speed on the 61! I need to have it looking nice by next May. I'll keep posting as progress ensues!
Last edited by ratherb-buggin on Wed Oct 19, 2011 9:30 pm; edited 1 time in total |
kanniff Samba Member
Joined: October 12, 2009 Posts: 811 Location: West Coast
Posted: Mon Sep 19, 2011 1:35 pm Post subject: |
I have had relatively good results with these plastic razor blades.
Spray on grafiti remover from Home depot ( yellow can) and use the razor blades to remove 90% of the paint- The rest I have been using a scotch gaurd (green).
http://www.amazon.com/Hardline-Products-Scraperite-Orange-Plastic/dp/B0022ZI0JY
My paint has relatively good fading underneath- What has been your guys' process to removing any swirls/buffing/waxing.
Are we still just color sanding with a high grit- then buffing with wax?
Hummer Samba Member
Posted: Tue Sep 27, 2011 11:46 am Post subject: |
Get this... PO's brother SPRAY PRIMERED my whole beautiful '74 Westy because he planned on painting it flat black and putting a big skull and crossbones on the side.
Here's how it sits today...(It's the white one)
I know it was Rustoleum Spray Primer and called Rustoleum. They recommended their product called "Power Stripper", but I'm thinking I may want to try something a little safer first. With it just being primer maybe acetone will work.
Would you guys recommend the graffiti remover? Looks like there were 100 different ways to use it in this thread. A lot of the primer is slowly chipping off revealing the nice orange underneath, so I'm thinking it will come off pretty easy with the right product. [/img] |
Hummer Samba Member
Posted: Thu Sep 29, 2011 6:05 am Post subject: |
| So the Klean Strip graffiti remover is discontinued. Anyone tried the Goof-Off brand graffiti remover? |
DodgyDawson Samba Member
Posted: Sat Oct 08, 2011 10:43 pm Post subject: |
Bought the 15 Window Delux, as I knew there was OG paint underneath it.
Started a trial with a offcut that we cut out from a damaged section and found 4 layers of paint using a plasic scraper, razor blade and Nitromors paint stripper.
The Mouse grey is V good underneath but It is going to take me a while, I estimate 200 hours+ (I have all winter). I agree, great bonding time with the bus and the results always speak for themselves on OG buses.
Posted: Sun Oct 09, 2011 2:30 pm Post subject: |
| DodgyDawson wrote: |
The Mouse grey is V good underneath but It is going to take me a while, I estimate 200 hours+ (I have all winter). I agree, great bonding time with the bus and the results always speak for themselves on OG buses. |
Be carefull using a razor blade as the Nitromors softens the original paint and it's very easy to cut into it. I've been using plastic scrapers - the ones you get for applying filler. You can still cut into the original paint with these if you leave it too long so only do small areas at a time. I'd estimate a bit longer than 200 hours - I've spent nearly that doing the front end, dog legs, door shuts and surrounds and passenger door. Still, like you I've got all winter and I'm happy with what I've done so far. Good luck. |
