mackyboy1893 Samba Member
Joined: August 28, 2011 Posts: 67 Location: Cleveland, Ohio
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3509 Location: Charleston, SC
Posted: Fri Sep 02, 2011 8:19 am Post subject: |
NO! _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20833 Location: Just a tiny bit west of Yosemite Valley
Use "search" function and use BERGMAN as search criteria.
Dale _________________ “Fear The Government That Wants To Take Your Guns"
spectre6000 Samba Member
Joined: April 19, 2009 Posts: 2014 Location: Broomfield, CO
Posted: Fri Sep 02, 2011 8:24 am Post subject: |
Based purely on the photos, I don't know they're worth that price. For starters, having an EMPI logo so proudly displayed on the air filters combined with my personal experiences with anything that had an EMPI logo on it does not instill much confidence. The Porsche-style shrouds have some pretty significant and inconsistent gaps around the exhaust ports there on the front. Additionally, it's been empirically proven that the Porsche-style shrouds do not cool anywhere near as well as stock shrouds and lack any thermostat system. The linkage doesn't look like it's been set up terribly well (the rods are at some pretty extreme angles when they should be totally vertical). Serpentine belts put a bit too much pressure on the alternator and crank bearings. This is based purely on photos and not on experience, so take it for what it's worth. They may be just fine for all I know. I wouldn't both with them, but that's me. _________________ Jason Hopper
-'58 German Market Deluxe Beetle (in progress)
-'84 M1009 CUCV
-'81 K10
"Buy the best, cry once." -Gene Berg
"A cheap man will always buy the cheapest thing available, and then buys another one hoping for a better result, and then spends the rest of his life in misery complaining about it. A thrifty man will buy a good part once and never think about it again." -RockCrusher
"Don't feed the Shitty Parts Monster!" -Me |
Posted: Fri Sep 02, 2011 8:29 am Post subject: |
Ok different subject, but does anyone have idea what those wheels are in that pic of the bug in that link? They are sexy as hell. Must have them. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Fri Sep 02, 2011 9:34 am Post subject: |
I tore into a burgerman 2387 a few months ago, what a mess,the heads were small valve heads with the seats seating on the back side of the biger instaled 40xsomethin valves.hemicut heads,replaced with cb cnc miniwedgeports. The crank looked nice,but had a lot of maching swarf/slivers/bendovers that should of been removed(fully counterweighted welded vw crank)and a few rod oil holes were bairly open to the orignal oil holes, so I had to do some portwork to the crank along with deburring&getting all the slivers/bendovers off it.then sent it to DPR for balancing,witch it needed.Cooler bypass blocked off,so all oil had to go through the 1 smaller gally,I added a bypass hole.I drilled the case for extra gally at the hyd lifters for better oil flow.Pistons were drilled in the dome for balancing,witch is dead wrong for balancing pistons.added light weight pins,1.1 rockers replaced with 1.4 for a total of .518 lift. totaly reworked the shroud system so it will work.
so for a good price if you dont mind tearing it appart and fixing it, not bad.oops forgot ,the brass used brass gear was cracked all the way through,the dist drive shaftgear was missing almost 3 teeth from rust,but looked new.pushrods tips not in straight,pushrod tubes had spacers on them and were squished as far as they could be squished and the seals were crying for relief as they were trying to escape.thats all I can recall at the monent.a real piece of work. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Fri Sep 02, 2011 12:45 pm Post subject: |
Contact (or PM) Paul (RockCrusher) at RC Enterprises in Parkesburg, PA, he'll take care of you.
BTW, those are Rader wheels, commonly available everywhere (at VW places). _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
67Beetle2017 Samba Member
Joined: August 01, 2006 Posts: 399 Location: Pasadena CA
Posted: Fri Sep 02, 2011 2:32 pm Post subject: |
I only had experience with two Bergmann engines.
One was an 1835 built for a buddies T-3 We picked it up in San Marcos at the Bergmann facility. We installed that in a 67 sqbk with header and 42DCNF's. We put well over 50K of trouble free miles on that engine. It was a daily driver for 6 years. (1982-8
The second engine as a 2387. It was a full circle crank with hydraulic lifters. It was installed in a 70 Ghia with dual 45 dellortos. the only issue with that engine was it had to be diassembled for a noisy lifter. Bergmann fixed that and after that the vehilcle was daily drivenfor at least 4 years that I know. (1990-94)
I am not affiliated with Bergmann. Just relaying a couple of "real" experienced with his product.
I have heard the horror stories about these engines and do feel that your money would be better spent with a company that supports Samba and has an excellent customer review. |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Fri Sep 02, 2011 2:42 pm Post subject: |
You see.....there's the rub, 67beetle.
Bergmann was a great engine builder with a solid reputation and then sold the business and the name to the guy in Oklahoma, and that's where things went way wrong. I have no doubt that the 2 engines you referenced were super builds and I'm glad for that. The same engines today would most likely turn into a nightmare. Now I say this while trying to live by the philosophy of NEVER badmouthing the competition. That is how strongly I feel about the rep of that guy that I would break my own ethical guideline. You have never seen me badmouth any other vendor since I joined this site and there are a few that come close to Bergmann's poor quality.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2163 Location: Salt Lake City
Posted: Fri Sep 02, 2011 3:55 pm Post subject: |
What would you guys suggested for an engine company then? I want something that will bolt up to the stock tranny if possible. I need this to be as simple as possible. |
Posted: Fri Sep 02, 2011 4:08 pm Post subject: |
REPOST
DarthWeber wrote: |
BTW, those are Rader wheels, commonly available everywhere (at VW places). |
Mitey62 wrote: |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri Sep 02, 2011 4:10 pm Post subject: |
Brothers, carcraft, steve tims, mofoco, CPR, RC enterprises , etc, etc, the list is long. Budget we ill be your main constraint.
Ahh yes PA. Rc would likely,be your best initial choice. _________________ 2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Fri Sep 02, 2011 4:12 pm Post subject: |
DarthWeber wrote: |
REPOST
DarthWeber wrote: |
Yeah, thanks, missed that. Thanks for the wheels.
Oh!! Awesome name!  |
bugnut68 Samba Member
Joined: June 10, 2003 Posts: 4180 Location: Eugene, OR
Posted: Fri Sep 02, 2011 4:14 pm Post subject: |
RC |
It's my understanding that Bernie still runs the show, just in Oklahoma now, or so I thought from what I picked up in the (largely atrocious) feedback thread. |
Posted: Fri Sep 02, 2011 4:37 pm Post subject: |
bugnut68 wrote: |
Not my understanding of the move. I could be wrong but I don't think so. Why would such a competent builder just drive off a quality cliff?
SRP1 Samba Member
Posted: Fri Sep 02, 2011 5:10 pm Post subject: |
bugnut68 wrote: |
RC |
RC Bernie still run's the show, and own's the business.
As for the change in quality...  |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1883 Location: S>E>Alabama
Posted: Fri Sep 02, 2011 5:22 pm Post subject: bergmann |
I own a 2387 BB. that was saved from the trash bin, I purchased it outright as a turnkey in 2008, from Mr Bergmann who answers the phone and sells all of the jive and bullshit himself, from the Shawnee Okl. shop.I had heard he was a good guy in the past, definetly not my expierence with him.Claimed it was dyno run and tuned, we had to completly rejet it just to get it to start and run, then further carb work. Stay away, many good builders to choose from here on the Samba. _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
Posted: Fri Sep 02, 2011 5:44 pm Post subject: |
SRP1 wrote: |
bugnut68 wrote: |
RC |
Then I stand corrected.....my humble apologies.......
aircooled356 Samba Member
Joined: October 27, 2006 Posts: 500 Location: Yosemite, CA
Posted: Fri Sep 02, 2011 5:51 pm Post subject: |
Stay away from the fast yellow ones.
They don't last very long.  |
