replacement westie propane tank, where from
rubbachicken
rubbachicken is offline
PostPosted: Thu Sep 15, 2011 4:00 pm    Post subject: replacement westie propane tank, where from Reply with quote
i'm now about to {i hope} to buy a vanagon westie, the propane cylinder has rusted out, i've looked through the classifieds and cannot see one forsale
where might i be able to find one
thanks
PDXWesty
PDXWesty is offline
PostPosted: Thu Sep 15, 2011 4:03 pm    Post subject: Reply with quote
Both GoWesty and BusDepot sell them. I'm sure Van-cafe does too.
http://www.gowesty.com/ec_view_details.php?id=2447&category_id=&category_parent_id=
http://www.van-cafe.com/home/van/page_1235_208/new_propane_tank.html
http://busdepot.com/details.jsp?partnumber=253070601D
89 Westy 2.1 Auto
rubbachicken
PostPosted: Thu Sep 15, 2011 4:05 pm    Post subject: Reply with quote
thanks, i've not heard of either vendor before
PDXWesty
PDXWesty is offline
PostPosted: Thu Sep 15, 2011 4:15 pm    Post subject: Reply with quote
People have restored them with good success, but I can't find the posts right now. The power of the search is not strong with me today...
89 Westy 2.1 Auto
DAIZEE
DAIZEE is offline
PostPosted: Fri Sep 16, 2011 5:05 am    Post subject: Reply with quote
Frank Condelli (?spelling) is importing bigger ones. He's in the Ottawa, Ontario area.
'09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
SCM
SCM is offline
PostPosted: Fri Sep 16, 2011 8:11 am    Post subject: Reply with quote
You'll have them on speed dial once you get your Westy home.
FWIW, I replaced my propane tank with a unit from GoWesty. The install went pretty smoothly although I had a bit of a struggle re-flaring one of the propane lines. It had previously been spliced and that caused a clearance issue with the flaring tool. All told it took a couple hours to get it hooked up.
However, for some reason I can no longer go to my local U-haul propane dispensary. The nozzle they use (which works on my Weber grill and the old propane tank) doesn't fit the new tank.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
Ahwahnee
Ahwahnee is offline
PostPosted: Fri Sep 16, 2011 10:22 am    Post subject: Reply with quote
Yes, they will figure prominently in your monthly VISA statement.
Me too. There are some who restore these which may save some bucks but I saw the chance for a new tank as a life-of-the-van purchase.
...However, for some reason I can no longer go to my local U-haul propane dispensary. The nozzle they use (which works on my Weber grill and the old propane tank) doesn't fit the new tank.
That is odd. The fitting on my GoWesty tank is the same as the original fitting. I have had attendants search for the correct adaptor among their collection of brass and declare they didn't have one -- until I point out that they needed no adaptor at all, the hose with no adaptor fitted is correct for the tank.
I get at least 14 days of camping on a full tank with the refrigerator running exclusively on propane. A bigger tank will get you more but you will probably sacrifice some ground clearance to have it.
SCM
SCM is offline
PostPosted: Fri Sep 16, 2011 11:43 am    Post subject: Reply with quote
Hmm, maybe the attendant didn't know what he was doing that day. I'll have to give it another try when the time comes to refill.
Good to know about how long your tank lasts. I suspect we'll be surprised with no stove action one of these days although we've just about given up on the 'fridge. Between food and beer we end up bringing a cooler anyway and it just got to be easier to use the fridge for non-perishables.
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Sep 18, 2011 3:00 pm    Post subject: Reply with quote
See the FAQ!
I have done it a couple of times. It is and is not worth it.
The OP states his tank is rusted out. There fore it is done.
Time to find another.
Just type "propane" in to the classifieds search.
The tanks do come for time to time.
It costs me $75 to have one cleaned and powder coated with lots of zinc under it. It is better protected than the factory thin coat of paint.
So add up the costs and it may be just less issue to buy a new one for around $350.
For me, I now have a couple to work with for my install into my Multivan. Makes sense for me to have fun, but if the core tank from the OP is really that bad, he should consider another one.
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Sep 18, 2011 3:05 pm    Post subject: Reply with quote
{snip]
It has something to do with the ACME / something else I forget combination fitting.
You can buy a new fill cheap. Look in the FAQ under propane and look where I have bought them from.
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Sep 18, 2011 3:07 pm    Post subject: Reply with quote
See:
http://www.thesamba.com/vw/forum/viewtopic.php?t=479091
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sun Sep 18, 2011 3:53 pm    Post subject: Reply with quote
There are 2 common types of fitting on various age Westy tanks as well as other tanks. My local propane vendor has the other adapter stored right at the pump and simply looks at the tank to make sure the pump hose has the right end for a given tank. I have Westy tanks of both fitting type, mixed on the same van even. It causes no big issues, even when he has to switch hose ends when he moves from one side of that van to the other. Find a smarter filling station.
Mark
SCM wrote:
FWIW, I replaced my propane tank with a unit from GoWesty. .....
