USB ports and 12v power
Page: 1, 2, 3  Next
chojinchef
chojinchef is offline
PostPosted: Fri Sep 23, 2011 5:43 am    Post subject: USB ports and 12v power Reply with quote
Anyone hardwire and install a usb power source without having to go throught a cigarette lighter or have a clunky adapter kicking around?
Want to power up the USB for another phone. My iphone charges off the ipod interface of the audio unit, but the wife was asking if I could install something for her droid (and my droid too).
Was thinking a USB port would be best idea, not having to have clunky adapters and such taking up space and getting in the way. Maybe mount one up front and one in rear somewhere.
Have seen some adapter type items (three 12v plugs and a USB) that look to be able to be disassembled and installed, but I was wondering if anyone went this route yet?
LP
Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory.
rubbachicken
rubbachicken is offline
PostPosted: Fri Sep 23, 2011 6:20 am    Post subject: Reply with quote
i know some inverters have USB outlets
chojinchef
PostPosted: Fri Sep 23, 2011 6:36 am    Post subject: Reply with quote
Still trying to determine which inverter I wanted to go with. That is for later this winter to determine. I was hoping this port could be separate from anything and running off aux battery.
fairweather
fairweather is offline
PostPosted: Fri Sep 23, 2011 6:51 am    Post subject: Reply with quote
I put this under the passenger seat, got it off ebay.
squeegee_boy
squeegee_boy is offline
PostPosted: Fri Sep 23, 2011 8:51 am    Post subject: Reply with quote
I did this:
They use a cigarette lighter outlet, but are anything but clunky Smile
Whatever USB power solution you use, be certain that it supports at least 1 amp of current. If it won't supply that, many devices won't work right (iphone especially).
Robyn
1984 FrankenSyncro Westy. EJ25 RMW kit
shepherdsond
shepherdsond is offline
PostPosted: Fri Sep 23, 2011 9:05 am    Post subject: Reply with quote
squeegee_boy wrote:
I did this:
Robyn
Robyn,
Just to clarify, are those USB outlets or USB adapters inserted into a 12v output? Do you have a URL?
Thanks
danfromsyr
danfromsyr is offline
PostPosted: Fri Sep 23, 2011 9:14 am    Post subject: Reply with quote
they're USB adapters,
they're all over Fleabay for $5ea to $2ea shipped.
I order them by the (5) pack..
they're $10~15 ea at local retail shops & truck stops..
Abscate wrote:
WAgrower
WAgrower is offline
PostPosted: Fri Sep 23, 2011 9:23 am    Post subject: Reply with quote
If you want a truly hard wired one, you could use a 7805 voltage regulator (radio shack) to supply power to pin 1(+) and pin 5(-) of a USB port.
Less then $5 worth of parts and only a little soldering.
Let me know if that's what your looking for and I can give you a better explanation.
whafalia
whafalia is offline
PostPosted: Fri Sep 23, 2011 9:54 am    Post subject: Reply with quote
Hey grower, do you know what that would give in amps? My android runs at a deficit plugged into its adapter when using nav.
bosruten
bosruten is offline
PostPosted: Fri Sep 23, 2011 10:30 am    Post subject: Reply with quote
'87 Syncro Weekender
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Sep 23, 2011 10:36 am    Post subject: Reply with quote
I(peak) is 2.2AMPS - BUT, BUT, BUT it is gonna get hot!
Sticking in a 7805 and the like for low current draw applications is simple.
But, for higher current and noisy environments they can leave something to be desired.
http://www.engineersgarage.com/electronic-components/7805-voltage-regulator-ic
These days cheap off the shelf boost buck converters like you can buy enmasse for many voltages tends to be a better solution.
PLUS wiring to and mounting most standard (surplus) USB connectors can be a challenge to the hobbyist.
Best just spend for something off eBay.
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Sep 23, 2011 10:40 am    Post subject: Reply with quote
bosruten,
I *REALLY* likes that cup holder.
Where you get that?????
squeegee_boy
PostPosted: Fri Sep 23, 2011 10:47 am    Post subject: Reply with quote
shepherdsond wrote:
squeegee_boy wrote:
I did this:
Robyn
Robyn,
Thanks
They plug into generic 12v outlets that I bought at Canadian Tire, but AutoZone will have them, too.
Here's the product data:
http://www.belkin.com/IWCatProductPage.process?Product_Id=489423
I do have to note that you should buy a good unit. The $3 ones on eBay may or may not support 1A of current, and even if they say they do, they may not actually do it in real life. Really weird behaviour will result, ask me how I know. Yay for spec inflation.
Stick with a name brand if you want everything to be guaranteed to work.
Edit: Yeah, you're right, r39o, if you have an iPad, you need something with more current capacity. The above won't allow you to charge and operate it at the same time.
Edit again: Ahh, here we go: http://www.cyberguys.com/product-details/?productid=51740
Belkin makes one, too, in the same form factor as the ones I currently (hah!) have: http://www.belkin.com/IWCatProductPage.process?Product_Id=525940
Robyn
danfromsyr
PostPosted: Fri Sep 23, 2011 10:50 am    Post subject: Reply with quote
you could mount an Jeep/motorcyle all weather USB plug like this
http://cgi.ebay.com/ebaymotors/USB-All-Weather-Pow...35b4f4ee61
Abscate wrote:
bosruten
bosruten is offline
PostPosted: Fri Sep 23, 2011 12:09 pm    Post subject: Reply with quote
r39o wrote:
bosruten,
...Canadian Tire. Had to saw the bottom few inches and paint it, screwed it to the wall. I want easy access to the back so this works for me.
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Sep 23, 2011 12:41 pm    Post subject: Reply with quote
bosruten wrote:
r39o wrote:
bosruten,
No Canadian Tire stores near me.
Got a part number or URL to it?
vanis13
vanis13 is offline
PostPosted: Fri Sep 23, 2011 12:45 pm    Post subject: Reply with quote
I just picked up a handful of 12v-> USB cigarette lighter plug-ins at Dollar Tree for $1 each. each of these have 2 USB ports.
for a $1 I could think alot of uses for them like changing some LED lights I really like which run on 3xAAAs into something I can power from the 12V westy power.
bosruten
bosruten is offline
PostPosted: Fri Sep 23, 2011 12:49 pm    Post subject: Reply with quote
r39o wrote:
bosruten wrote:
r39o wrote:
bosruten,
Sure... http://www.canadiantire.ca/AST/browse/4/Auto/Vehic...?locale=en
randywebb
randywebb is offline
PostPosted: Fri Sep 23, 2011 12:52 pm    Post subject: Reply with quote
anyone know if that cup holder can be purchased in the US?
1986 2.1L Westy 2wd Auto Trans.
WAgrower
WAgrower is offline
PostPosted: Fri Sep 23, 2011 1:23 pm    Post subject: Reply with quote
Good question with two answers...
There are a plethora of regulators out there, rated from 500ma to 5a. So get a larger one and you can make a USB power hub of sorts.
In fact the ones I've gotten from radio shack were rated at 1amp.
You could create a pass transistor circuit with a PNP transistor rated at your desired amperage.
Most data sheets for the 7805 will show you a pass circuit.
Just remember to mount it to a heat sink- could use the dash or any metal bit in the van- use a little toothpaste as heat sink compound.
Page: 1, 2, 3  Next
