futhark Samba Member
Posted: Thu Oct 06, 2011 11:39 am Post subject: Best Jack Positions For A Rolling Floor Jack |
| Maybe I'm just getting old, but I'd like to be able to jack up my '64 Sundial camper, front and rear, without having to break out the Bilstein crank jacks. So what are the best places to position a rolling floor jack saddle to lift the front for a lube job and to lift the rear for a valve adjustment or cleaning the crankcase sump? I'll be putting jack stands under the torsion bar tubes after the bus is off the ground. I'd appreciate any advice promptly, since I will be working on the vehicle within the next couple of days and will probably not have another opportunity for some time. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13592 Location: Tejas!
Posted: Thu Oct 06, 2011 11:47 am Post subject: |
although I'm sure some stock hugging jack ass will tell you that your bus will feel bad if you use a non factory jack...
I use the front beam, and put jack stands under the beam yubes. In the back, I use the point under the spring plate, right were the torsion cover is. And put jack stands under the rear torsion tubes
Stock jacks are best for emergency only in my opinion _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
durfeec Samba Member
Posted: Thu Oct 06, 2011 11:55 am Post subject: |
| Erik G wrote: |
Stock jacks are best for emergency only in my opinion |
i use the same place for the rear but i used the frame where the OG front jack point meets the the main frame for the front. my bus is too low to use the front beam. _________________ 1960 Bus Panel/Camper |
Posted: Thu Oct 06, 2011 4:44 pm Post subject: |
| Thanks for the very practical tips in placing the rolling floor jack under the VW. You've been quite helpful and it is appreciated! |
kombisutra Samba Member
Joined: October 02, 2003 Posts: 4127 Location: San Anselmo, 10 miles North Of San Francisco
Posted: Thu Oct 06, 2011 5:48 pm Post subject: |
| Erik G wrote: |
X2
Maybe they were solid in the sixties, but 9 out of 10 jack points ain't solid in this century, I almost never use the stock jack except when needing to break the bead on a tire in the field.
I always carry and use a floor jack. If your trans cradle isn't all bent from jackasses,jacking off over the years, you can spread the load safely with some 2X stock and jack the entire rear from the one point. Also not recommended by the experts, I usually jack the entire front end directly off the center pin on the beam. I've never experienced any problems from using it as a center jack point.
DanM Samba Member
Joined: June 07, 2002 Posts: 1390 Location: Falls Church, VA
Posted: Thu Oct 06, 2011 5:52 pm Post subject: |
| My neighbor's aunt told me she and her husband went to Germany in the 60s and bought a used bus to tour and camp in. They got stuck in the mud along the way somewhere and he got out to use the jack to try and lift up the rear wheel and fill in the hole, but as the jack continued to go up - the bus stayed still. He realized after a minute he'd jacked the jack all the way up and all that happened was he crushed the jack point up through the rocker and floor. That bus wasn't more than 10 years old at the time! |
duhbrr Samba Member
Posted: Thu Oct 06, 2011 5:53 pm Post subject: |
| kombisutra wrote: |
I've never experienced any problems from jacking off the pin. |
Hahaha sig material? _________________ 1958 Dove Blue DD Panel
| pondoras box wrote: |
| We complain about people "flipping" cars on here but we have no problem hitting up Amazon or Walmart for flipping cheap foreign junk! |
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Thu Oct 06, 2011 7:25 pm Post subject: |
My jack points are as safe as day one. Very strong and thick metal. In the garage I use a flor jack on the front beam or the rear torsion tube then on jackstands it goes. _________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
| dawerks wrote: |
| Perfection only comes with delusion. |
http://www.oacdp.org/ |
Posted: Thu Oct 06, 2011 7:26 pm Post subject: |
| duhbrr wrote: |
| kombisutra wrote: |
Hahaha sig material? |
Har, har, look who beat me to the edit button! I've said worse  |
laughingboy Samba Member
Joined: May 28, 2007 Posts: 76 Location: Ottawa, ON Cana
Posted: Fri Oct 07, 2011 4:39 am Post subject: |
Okay, new to buses, so give me a break.
Maybe I'm just an idiot, but when I jack up the rear of my bus, using some wood under the transmission cradle, the rear wheels sag and touch the ground even though the bus is jacked pretty high.
I haven't had to change a tire or haven't serviced my brakes yet, but how frickn high do you need to jack it so that the wheels clear the ground? I'm worried about the wheels hanging and stressing the boots etc.
To service the wheels etc, should I be jacking the plate connecting the wheel and the suspension i.e. only one side at a time? How about when people used the stock jack - how high did that thing go? |
Posted: Fri Oct 07, 2011 6:41 am Post subject: |
You mus have a little jack? Is your bus lowered? Yes the wheels hang low but even my stock jack doesn't need to go too fat to get the tire off the ground. I wouldn't worry about it tearing your boots. If they tear they neded to be replaced anyway. Do one side at a time and place on jack stands. I never work on my brakes or pull a whel off in my garage unless its on stands. _________________ April 3rd 62 standard mgr/pw
Includes 6 popouts
025 Safety belts
| dawerks wrote: |
Clara  Samba Member
Posted: Fri Oct 07, 2011 8:43 am Post subject: |
| laughingboy wrote: |
I don't use the stock jack. Okay I have, in a pinch, changed a tire with it.
That is what it is there for. If your jack points are strong it works.
It is normal for the rear wheels to sag and tuck in when you jack up a VW with the swing axle tranmission. The wheels will sit funny when you let it down. Roll the bus and all goes back to normal.
When you lift the front of the bus up, the trailing arms should rotate down when the weight is lifted off them. If they don't, something is rusted stuck or broken in your suspension. You need the flex or you get a harsh ride. Seriously, the arms can get rusted stuck to the beam, and still be stuck even after the truck has been driven from Michigan to LA, or so I've heard.
I have a piece of wood I use for the front, notched for the swing lever pin.
At every 3K miles service, I use this system to jack it up to adjust the brakes and lube the suspension. Can't lube the swing lever pin if you have the bus resting on it.
you can jack the rear up one wheel at a time:
or both rear wheels at once:
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
pandanom Samba Member
Joined: March 16, 2005 Posts: 1165 Location: Lexington, S.C.
Posted: Fri Oct 07, 2011 9:34 am Post subject: |
You can look in my gallery and see the lifting points I use. _________________ It is never too late to have a happy childhood! |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Fri Oct 07, 2011 9:44 am Post subject: |
| Clara, your block of wood has character! You should name it |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Fri Oct 07, 2011 9:55 am Post subject: |
I, too covet Clara's big block 'o wood.
Aaron made a real sweet jack extension:
http://www.thesamba.com/vw/forum/album_search.php?...t_dir=DESC _________________ Founder and Chairman Emeritus, ECMSAS
| BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
| Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
Posted: Sun Oct 09, 2011 11:53 am Post subject: |
Thanks again to all, especially Clara for the wonderful pics. I wish now I had known about using the under transaxle frame member as a jack support point. It would have saved a lot of Bilstein cranking over the 34 years I have owned my bus. And yes, the big dents in this cross piece showed that it had been used before as a jack contact piece, but without the wooden block intermediary.
The really good news is Der alte bus lebt wieder! (The old bus lives again!). 17 months of just sitting in a field growing lichens and rusting away did not stop it from firing right up when I replaced the positive battery cable, put in a freshly charged battery, replaced the fuel pump to carburetor fuel line, topped up the transaxle lube, and gave it a whiff of diethyl ether starting fluid down the carburetor throat! Off we went, stopping only once to put the spark advance vacuum line back on the carburetor, then drove five miles into town to fill up the nearly empty fuel tank. The old swing-axle bus is the most fun car to drive that I've ever had, which surprises people who know I also own a '72 Karmann Ghia coupe.
Forum posters at thesamba are the greatest! |
quartermilecamel Samba Member
Posted: Sun Oct 09, 2011 1:58 pm Post subject: |
| Major Woody wrote: |
what should Clara call the piece of wood, "Woody"?  _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Fleisch Samba Member
Joined: February 20, 2013 Posts: 10 Location: Sonoma County, CA
Posted: Wed Aug 07, 2013 9:38 am Post subject: |
| Great pics Clara. That's what I was looking for. I use the jack points also but need both tires off today and the block of wood is an excellent suggestion but my bus is lowered so this won't work. Any suggestions? |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 1006 Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota > Babcock Ranch
Posted: Thu Aug 08, 2013 9:47 am Post subject: |
| Fleisch wrote: |
Use your jack just to the left or right of the pin? Once you get it up high enough, use the stands. _________________ Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
My '66 after the crash.
Click to view image |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Thu Aug 08, 2013 6:19 pm Post subject: |
| Fleisch wrote: |
I made ramps out of some leftover 2 x 6 boards stacked two boards thick with a shortie on the top and 45* angles cut at the leading edges of both. Drive up on them and jack to your hearts content! Works front and back. I actually had 4 that I made to get the whole bus up to work on it. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
