New 72
werker
Redwood Wrencher
werker is offline
PostPosted: Tue Oct 18, 2011 10:51 pm    Post subject: New 72 Reply with quote
Thought I'd post up the 72 I've been working on lately. Sold off the 58 single cab because I needed a smooth vehicle to travel in. Don't get me wrong, I like the old split window, but it is more of a piece of farm equipment than an actual vehicle. With that in mind, I picked up this nice 72 from Berkeley Ca. So far it has been the most original, least molested and finest running of any VW I've ever purchased (as purchased). Even the clock works!
Does anything appear to be missing or wrong in the engine compartment?
(I know about the air filter to body snorkel, and the missing start injector)
Best yet, look at all the stuff that came with it. A few extra rubbers, an interior kit I have no intention of installing, a muir manual, and even some bonus coolant. Shocked (The PO had no idea about cars. He told me on the phone that it was carbureted and didn't know how to work the heater or vent controls.)
Finally, does anybody know what this rack is off of?
The four parts that connect the rack to the roof are hose clamped on and aren't part of the rack. But the four posts with rubber feet are. What the heck is this rack from??
Also, how would I know if this car came originally with overriders?
Check out the aftermarket side stripping that a PO put on. Instead of a chrome line, a black line. It almost doesn't look that bad. I will replace it eventually.
Does it look lowered a little? I can't tell.
72 Squareback
9th air-cooled
Proud Member #8, SBS (Stock Bus Society)
Gremlin Killer
Robert Bills wrote:
The guys on this forum can talk you through any issues you may have. Don't give up on the fuel injection - your Type 3 will thank you.
Getdownthump
Getdownthump is offline
PostPosted: Wed Oct 19, 2011 2:43 am    Post subject: Reply with quote
Looks great and does look like it escaped the molesters! Not sure on what's missing as I'm a twin carb guy but it does look OG in there too.
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Oct 19, 2011 8:21 am    Post subject: Reply with quote
It does look like a Good Score! You'll need 20+ feet of 5/16" gas hose and new clamps to replace All your gas hoses. The original woven hoses will spring pin hole leaks any time now!
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
supaninja
supaninja is offline
PostPosted: Wed Oct 19, 2011 9:15 am    Post subject: Reply with quote
I agree with Mike, sweet score but I would replace the fuel line. Cheap insurance, here is the best deal I have been able to find http://www.jegs.com/i/JEGS-Performance-Products/555/15995/10002/-1?parentProductId=760825
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
kage
kage is offline
PostPosted: Wed Oct 19, 2011 9:19 am    Post subject: Reply with quote
I made the switch from a 67 crew cab and I have to agree, ride is a bit smoother. I'm also in a 72 square (f.i.) which looks pretty identical to yours. It's white, but the original color was the same. Mines got over riders front and rear and the same bumper with the rubber strip in the center, I think that was stock. I've got the same carpet kit too ( in oatmeal not black), which I'm in the process of installing. Looks nice so far, you should try it.
werker
Redwood Wrencher
werker is offline
PostPosted: Wed Oct 19, 2011 9:50 am    Post subject: Reply with quote
Hmmm fuel lines. I suppose that would be a good idea. I've actually seen now a few VW burning up in front of me. (Never mine). Nick, thanks for the jegs link. I'll pick that up and get replacing.
So there is a short soft span from the tank to the hard line, then again at the hardline to the rear. Right? And then it's all engine compartment lines. Will that hose work for my fuel rails as well? Or would I need different hose. Also, are we talking normal screw driver hose clamps or those weird ones that hold the fuel rail together?
And ideas about my rack?
72 Squareback
9th air-cooled
Gremlin Killer
Mike Fisher
PostPosted: Wed Oct 19, 2011 10:09 am    Post subject: Reply with quote
There is a bunch by the fuel pump supply/return/filter/dampener etc. I eliminated my metal 'pancake' dampener. Replace ALL of it! I just bought 20 worm drive slotted/hex head clamps at my local Knecht's for $13.80. Use the hex head to tighten them. I think I'm gonna need more clamps!
Root_Werks
Root_Werks is offline
PostPosted: Fri Oct 21, 2011 8:41 am    Post subject: Reply with quote
Umm, woah dudes. I normally don't chime in with my opinions....but that looks like "universal" fuel hose correct? D-Jet runs around 30psig right? Most "universal" fuel line is only rated to 15psig. Why not just go to Pelican Parts dot com and order up the correct High Pressure rated 7mm and 9mm hoses for supply and return? It's the correct made in Germany stuff. I've replaced all fuel lines on 1 stock squareback FI and one L-Jet bug. I would never use "universal" fuel lines.......never on a FI car.
Sad
When I set my timing, why do I flush, then take a pee?
supaninja
PostPosted: Fri Oct 21, 2011 8:45 am    Post subject: Reply with quote
The modern fuel hose is called "universal" but is rated to 50psi, more then plenty for djet Wink SAE30R6 has a bust rating of 175psi, plus Jegs usually substitutes it with SAE30R7 which is even better stuff. It's 2011 there isn't a lot of carbed cars on the road anymore since FI has been standard for the last 25 years or so.
Nick
Root_Werks
PostPosted: Fri Oct 21, 2011 8:48 am    Post subject: Reply with quote
Here:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VHD%2DN20%2D2811
Mike Fisher
PostPosted: Fri Oct 21, 2011 8:49 am    Post subject: Reply with quote
Russ Wolfe told us Mahle tested 'universal' fuel hose to 250lbs.
Root_Werks
PostPosted: Fri Oct 21, 2011 8:50 am    Post subject: Reply with quote
Kay, I can buy that in concept. Still not gonna change what I put on my VW's or friends VW's. Cool
I've done my old man "safety" speach. I'll shut up now. Very Happy
supaninja
PostPosted: Fri Oct 21, 2011 8:58 am    Post subject: Reply with quote
When I upgraded the entire fuel system on my honda (turbo and ethanol, giggity) I did a ton of research on fuel hose. For us the SAE30R6 and SAE30R7 is way overkill plus you can buy it at your local FLAPS or online from Jegs and Summit for cheap, it's a no-brainer. It also has the Russ and Jake R. stamp of approval, it's good stuff.
Nick
KTPhil Premium Member
KTPhil is offline
PostPosted: Sat Oct 22, 2011 9:42 am    Post subject: Reply with quote
Use the right EFI hose clamps so you don't cut the jacket tightening them:
werker
Redwood Wrencher
werker is offline
PostPosted: Sat Oct 22, 2011 9:59 am    Post subject: Reply with quote
Nice. So are there two sizes of line (7mm and 9mm inlet/outlet) that need replacing and the 5/16 universal will work for both? That sounds odd. But let me know if I'm understanding correctly.
And KTPhil, do you have a source for those improved clamps?
72 Squareback
9th air-cooled
Gremlin Killer
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Sat Oct 22, 2011 10:17 am    Post subject: Reply with quote
those hose clamps are the best... i got tired of hose get cut by the worm gear clamps so ive gone to these, best decision ever.. i even discovered that where i removed one of the hoses i had cut through the hose and was leaking fuel Shocked im just glad i didnt turn into a fireball
FergU
FergU is offline
PostPosted: Sat Oct 22, 2011 10:43 am    Post subject: Reply with quote
The 5/16 is about the same as 9mm. For anything that uses 7mm, you use the clamp to reduce/tighten down to it. You just cannot make the hose bigger, but can tighten down to a little smaller.
1962 Type 1
1963 Type 14 - Karmann Ghia "Sadie" (Restoration progress - http://vwsexysadie.wordpress.com)
1972 Type 3 - Squareback "Joseph" (Restoration Progress - http://jpdproject.wordpress.com/)
KTPhil is offline
PostPosted: Sat Oct 22, 2011 11:23 am    Post subject: Reply with quote
Easy, I found them at Kragen and Pep Boys. They are common. In fact, they had too many sizes so I bought a couple and used the ones that fit best. Bring a snippet of new hose with you and see how they will fit best. Someone posted a link online a while ago but I always found them at most FLAPS.
werker
Redwood Wrencher
werker is offline
PostPosted: Thu Dec 13, 2012 2:40 pm    Post subject: Reply with quote
Small update, finally got the foglights and some bumper overriders installed.
Before:
After:
72 Squareback
9th air-cooled
Gremlin Killer
oxsign
oxsign is offline
PostPosted: Sun Dec 16, 2012 2:39 pm    Post subject: Reply with quote
Looks real good. I just picked up a '71 fastback and want to add the same fogs & bumpers.
