cambarner Samba Member
Joined: October 27, 2010 Posts: 101 Location: Southern Maine
Posted: Mon Oct 24, 2011 7:20 pm Post subject: Front Door seals/gaskets |
This may belong in the stupid questions thread, but...
While I have searched on this topic, I have not found an answer to my specific question.
First, when installing the front door seals do the doors need to come off? I would think you could replace it with out removing the door...
And Second, should I use any glue in attaching the seal to the door?
Thanks in advance,
Cam _________________ 1972 Microbus, AKA 'SurfBus' |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9156 Location: Syracuse, NY
Posted: Mon Oct 24, 2011 7:44 pm Post subject: |
No, and no. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
| borninabus wrote: |
| a measurement of your rod would be extremely useful. |
| notchboy wrote: |
| my dad wasnt a belittling cock when he tought me how to wrench on cars. |
| EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
curtis4085 Samba Member
Posted: Mon Oct 24, 2011 7:47 pm Post subject: |
No and maybe. my OG seals i pulled off had a bit of it in places.. and no it did not apear to be from PO. I pulled all the seals off my bus and some had and some didnt. So Im up in the air. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4148 Location: Seattle, WA
Posted: Tue Oct 25, 2011 12:16 am Post subject: |
The checkstraps will need to be disconnected. The front of the door does
not have a channel to retain the seal, and will certainly require glue. As I
recall, the top corners will also flop around if not glued. _________________ '67 bug: seized by the authorities
Posted: Tue Oct 25, 2011 4:15 am Post subject: |
Then how come everyone else said I didn't need it? haha. What type of glue would you recommend? _________________ 1972 Microbus, AKA 'SurfBus' |
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Tue Oct 25, 2011 5:48 am Post subject: |
| cambarner wrote: |
| Then how come everyone else said I didn't need it? haha. What type of glue would you recommend? |
First of all, make sure the channel is good and clean where the seal sits. Then do a dry run. Set the seal in place, make its correctly installed, and see how the doors close.
At this point, if you feel comfortable with the fit, you can use a bit of adhesive where necessary. You may get away without using adhesive at all. The quality of seal you are using will probably have an impact on whether you need adhesive, or not.
I used quality door seals when I did mine, but still decided to use adhesive in a few areas - corners, at the top, etc.
This is what I used:
http://www.permatex.com/products/Automotive/adhesi...ealant.htm _________________ '76 Deluxe Campmobile |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42943 Location: at the beach in Northern Wokistan
Posted: Tue Oct 25, 2011 5:55 am Post subject: |
3-m yellow weatherstrip glue. VW used glue. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Desertbusman Samba Member
Posted: Tue Oct 25, 2011 6:10 am Post subject: |
Weatherstrip glue or contact cement. There will be places that do need an adhesive. _________________ 71 Superbug
71 Westy |
Posted: Tue Oct 25, 2011 6:38 am Post subject: |
| SGKent wrote: |
| 3-m yellow weatherstrip glue. VW used glue. |
You are correct. Indeed that is what I used. It's been a few years, and I was almost certain it was a Permatex product.  _________________ '76 Deluxe Campmobile |
Tuna Tim Samba Member
Joined: November 24, 2005 Posts: 181 Location: Saddlerock, Aurora, Colorado
Posted: Tue Oct 25, 2011 7:22 am Post subject: |
I just did my driver's door seal last week. It was eezy-shmeezy.
- Remove the old seal.
- Clean the contact area well.
- Pop the pin out of the check-strap to allow the front portion of the seal to be positioned.
- Install the seal without adhesive, but using blue painters' tape to hold it in place. Taping the seal in place will allow you to identify those areas of the seal that require some adhesive, without it flopping all over the place. (It's the next best thing to having a third arm)
- Lift the section of seal that requires adhesive, apply glue, tape back down. If the adhesive is a quick set you can skip the tape.
- Move on to next section that requires adhesive.
- Follow manufacturer's recommendation for time to allow adhesive to cure.
- Remove tape
- Reinstall check-strap.
- Admire your handy work.
Words of wisdom:
- Not all seals are created equal.
- The door may be difficult to close for awhile, until the seal compresses.
- The latch may require adjusting. _________________ 1974 Bay
CSII
091
Dual 40 Dells
Unilite
Thunderbird Extractor |
Posted: Tue Oct 25, 2011 2:21 pm Post subject: |
Quality info. Thank you very much! _________________ 1972 Microbus, AKA 'SurfBus' |
stevo Samba Member
Joined: January 22, 2004 Posts: 1009 Location: the eugeniverse
Posted: Tue Jul 03, 2012 9:31 pm Post subject: |
| Tuna Tim wrote: |
- Pop the pin out of the check-strap to allow the front portion of the seal to be positioned. |
does the check strap pin pop out? appears that it should. i removed the circlip, tapped it hard with a hammer and it hasn't budged. should i hit from below full force? |
Posted: Wed Jul 04, 2012 6:13 am Post subject: |
| stevo wrote: |
| Tuna Tim wrote: |
It does lift out once the clip has been removed. Mine lifts out using my index finger. Hitting it "full force" risks mushrooming the pin. You don't want to do that. Try wiggling the door back-n-forth as you tap it lightly from the bottom. If the pin is still reluctant to move, try some PB Blaster or similar concoction. A few light taps on the strap and side of the pin might also help to free it. _________________ 1974 Bay
CSII
091
Dual 40 Dells
Unilite
Poptopcamper Samba Member
Joined: June 23, 2012 Posts: 493 Location: Sheridan, Wyoming
Posted: Wed Jul 04, 2012 6:35 am Post subject: |
In the early 60's vws were known to be so well sealed that they would float. I remember seeing a YouTube of a bug floating in a lake or some body of water. I don't know about busses. I do remember that a friend got a new bug in the 60's and it was easier on the ears to crack the window before shutting the doors. Do your ears pop when you shut your doors? Do busses really float? I need to replace my door seals too. I'll keep you posted. _________________ If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2021 Dodge Ram 3/4 ton
2020 VW Tiguan
2001 Harley Electraglide Classic
1986 BMW R 800cc motorcycle
2002 Chevy Camaro Z28
1999 Harley Sportster 1200 Custom |
Busdriver79 Samba Member
Joined: July 22, 2011 Posts: 1655 Location: The Peoples' Republic of "No" Jersey
Posted: Wed Jul 04, 2012 6:38 am Post subject: door seals |
| Thanks for reminding me to replace my front door seals....I just ordered a pair online a few minutes ago....They will be here within a week. |
stevo Samba Member
Posted: Wed Jul 04, 2012 2:23 pm Post subject: |
| Tuna Tim wrote: |
| stevo wrote: |
| Tuna Tim wrote: |
It does lift out once the clip has been removed. Mine lifts out using my index finger. Hitting it "full force" risks mushrooming the pin. You don't want to do that. Try wiggling the door back-n-forth as you tap it lightly from the bottom. If the pin is still reluctant to move, try some PB Blaster or similar concoction. A few light taps on the strap and side of the pin might also help to free it. |
thanks tim. that's the way it looks in bentley, but i'm glad to double check before reefing on it. will blaster it. |
HarryFD Samba Member
Joined: February 24, 2012 Posts: 836 Location: Portland, OR
Posted: Thu Oct 03, 2013 8:32 pm Post subject: |
| Tuna Tim wrote: |
| stevo wrote: |
| Tuna Tim wrote: |
Just did my doors. One of the pins was rusted into place. After trying to drift it out, I gave up and dremeled the head off. It was replaced with a Stainless steel 30 mm M6 buttonhead bolt and nylock nut.
The rubber is thicker than my old rubber and the doors are hard to close but with a bit of energy, close and latch. I will wait a few months before I take more drastic measures. _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1971 Jaguar XKE 2+2 V12 Coupe
1973.5 911 Targa
2009 MB C300 |
