Tire Pressure Question
Page: 1, 2, 3  Next
usrname
usrname is offline
PostPosted: Thu Nov 18, 2010 10:51 am    Post subject: Tire Pressure Question Reply with quote
What psi should I be running in the 165/80/R15's on my otherwise stock (mostly) '62 bug? The sidewall says 38 max and the 34 psi I'm running seems pretty stiff. The 16F/20R manual specs for the original stock tires can't be right for these newer tires. Anyone got my size tires? What psi are you running?
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Thu Nov 18, 2010 10:58 am    Post subject: Reply with quote
opening a can of worms here Wink I run 18 front 28 rear on my 165 80 15 on my 60 bug. No one can convince me any different after 200K +
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Thu Nov 18, 2010 10:59 am    Post subject: Reply with quote
It'll ride really rough if you pump them up close to those max numbers you mentioned. Try 18/27:
Max Welton
Max Welton is offline
PostPosted: Thu Nov 18, 2010 1:58 pm    Post subject: Reply with quote
Yeah, the max pressure on the sidewall of your tire is for when the tire is carrying the maximum amount of weight it's rated for. And that is a hell of a lot more than your VW.
Max
1967 Type-3 Fastback
joemac
joemac is offline
PostPosted: Thu Nov 18, 2010 3:38 pm    Post subject: Reply with quote
You're better off running higher pressures than low. The only down side of higher pressures is the chance that the tire will wear more in the middle of the tread than the outside, but given that you get better fuel mileage, handling and tread life, I think the trade-off is worth it.
Max Welton
PostPosted: Thu Nov 18, 2010 3:50 pm    Post subject: Reply with quote
I would include poor handling, driver fatigue and dangerously decreased traction (especially in rain or snow) as downsides.
But this has all been hashed out before.
Max
The Android
PostPosted: Thu Nov 18, 2010 8:25 pm    Post subject: Reply with quote
On my 62, when I've over-inflated the tires, and not even close to the maximum, I certainly do not get longer tread life, I get over-inflation wear.
usrname
usrname is offline
PostPosted: Thu Nov 18, 2010 9:23 pm    Post subject: Reply with quote
Gentlemen, I thank you for your replies. I believe I will let some air out. Out of the tires, I mean!
Bruce
Bruce is offline
PostPosted: Fri Nov 19, 2010 12:19 am    Post subject: Reply with quote
You are better off running the correct tire pressures prescribed by VW.
The biggest downside is you will have less traction, reducing your braking, increasing the possibility of lockup.
The trade-off you are putting up with is foolish.
Aynthm
Aynthm is offline
PostPosted: Sun Sep 11, 2011 4:38 am    Post subject: Reply with quote
Does anyone know what the third line from the top means? "Quality 32 psi?
Just curious!
Thanks
carcass
carcass is offline
PostPosted: Sun Sep 11, 2011 5:55 am    Post subject: Reply with quote
It may mean whichever tires you use should be rated for at least 32psi max inflation
(this is a guess,though,because I really don't know)
bill may
bill may is offline
PostPosted: Sun Sep 11, 2011 6:43 am    Post subject: Reply with quote
driving beetles from 8-65 till 8-2005 = i used 18-20 front and 27-28 rear. you must know something about driving them i do not.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
drscope
drscope is offline
PostPosted: Sun Sep 11, 2011 10:35 am    Post subject: Reply with quote
Here comes the worms!
You can't take the tire sticker from a 45 year old car and expect those pressures to apply to todays tires.
Just as the Bias plys and Radials on the sticker have different pressures, so do todays modern tires!
We have run flats and high pressure tires that were only a dream 45 years ago.
So when putting modern tires on an antique car, you really need to pay more attention to the tire manufacturer's recomendations then to the car manufacturer's recomendations.
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Sep 11, 2011 11:11 am    Post subject: Reply with quote
But nobody makes cars as light as a VW that uses tires that large (tall). Tire manufacturers haven't considered their products on old VWs for decades. I woudl never drive an old VW with more than 30# in the front tires, no matter what the tire manufacturer says.
The Android
PostPosted: Sun Sep 11, 2011 12:42 pm    Post subject: Reply with quote
All I know is that when I've run even mildly overinflated compared to VW's specs, I get overinflation wear.
bill may
bill may is offline
PostPosted: Sun Sep 11, 2011 12:47 pm    Post subject: Reply with quote
165 X 15 tires are close to 155 X 15 tires that are correct size for beetle. watch what pressure you run on a 1958-1967 swing axle beetle. maybe t-roy can give some input as he auto crosses beetles. i stand by my statement from driving them for a few years and having tried differant sizes and wheels. with front sway bars and original EMPI camber compensaters and without. to make a statement like "here comes the worms" without suggesting real world experience of yours is kinda lame. Very Happy
www.sv2s.com
SBS #100
Bruce
Bruce is offline
PostPosted: Sun Sep 11, 2011 3:49 pm    Post subject: Reply with quote
We've already been through this. Nothing has changed.
It was only 8 years ago that VW was still manufacturing the Beetle in Mexico, installing 155/80/15 tires. Recommended pressures are 18.5/27 psi. Just the same as in the 60s.
You will never find any tire manufacturer making specific tire pressure recommendations for any car because they have no idea how the tire is loaded.
wizcleland
wizcleland is offline
PostPosted: Sun Sep 11, 2011 5:49 pm    Post subject: tire pressure..HUGE difference Reply with quote
I totally agree with the lowering the front pressures! Had Pirelli p7's put all around and never thought to check what pressures they were at. Had just got the car so decided that its supposed to be 'rough' WRONG. WOW, what a difference. tHey were at 30 all around. Settled on 20 and 28 front and rear, may go lower on the front but a LOT of potholes here and think the extra pressure cushions the rims a bit more...
running Pirelli P7's 195/50R15s on all four corners.
starplot
starplot is offline
PostPosted: Sat Oct 29, 2011 10:54 am    Post subject: Great info, but what's the final word? Reply with quote
I just bought a '62 and the tires on it say maximum 44 psi. I was just curious what the recommended pressure was supposed to be since there is no sticker in the glove box anymore. Do we have a consensus here?
60ragtop
60ragtop is offline
PostPosted: Sat Oct 29, 2011 11:06 am    Post subject: Reply with quote
No, no consensus Wink never will be. Do a search and come up with your own.
Page: 1, 2, 3  Next
