Removing trim off deluxe bus?
guitarman63mm
guitarman63mm is offline
PostPosted: Tue Nov 01, 2011 7:50 am    Post subject: Removing trim off deluxe bus? Reply with quote
I tried to search, but I had no luck. I'm trying to remove the trim so I can get to some rust underneath it - it feels like they can just pull off, but I would really like to avoid destroying the trim. Thanks for any help guys.
busdaddy
busdaddy is offline
PostPosted: Tue Nov 01, 2011 8:33 am    Post subject: Reply with quote
Push up (or down) approx 1/8"+ and pull out on it, once you get a piece loose you'll develop the correct combination of moves.
I push up from the bottom with both thumbs and pull out on the top with all my fingers at the same time.
Слава Україні!
guitarman63mm
PostPosted: Tue Nov 01, 2011 9:07 am    Post subject: Reply with quote
Worked like a charm - ten minutes and a split fingernail later (need to watch those clips next time...), it's all off. Thanks busdaddy.
DrvwStevo
DrvwStevo is offline
PostPosted: Tue Nov 01, 2011 7:03 pm    Post subject: Reply with quote
A plastic trim remover works good too, and no hurts nails/fingers Wink Next time
Those who can, DO. Those who can't, wish they COULD
'68 bug
grandpa pete
grandpa pete is offline
PostPosted: Tue Nov 01, 2011 8:29 pm    Post subject: Reply with quote
Drvwstevo;do you have a photo of this tool?
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
