Can you install a 34 carb on a Type 3 right out of the box?
Page: Previous  1, 2
mxracer
mxracer is offline
PostPosted: Mon Nov 21, 2011 3:18 pm    Post subject: Reply with quote
It's pissing down rain right now but if you want I'll go down to my shop after it quits and see what came in mine and I should be able to tell you what I ended up with.???
RodneyW
RodneyW is offline
PostPosted: Mon Nov 21, 2011 3:25 pm    Post subject: Reply with quote
I'd be obliged my friend, but don't get drenched on my account. Where in NC? Just want to know which of my family all across the state are whining right now.
(1) No matter what the world brings, I am never anything but happy driving my Ghia.
(2) The Fastback is running, rolling and, especially important, stopping. Interior is done. Driving more often; commuting on occasion. Dreaming of paint.
'71 Bahia Red Karmann Ghia Coupe
'71 Marina Blue Type 3 Fastback
'03 Reflex Silver Passat Wagon (sold but still in the family)
mxracer
mxracer is offline
PostPosted: Mon Nov 21, 2011 5:29 pm    Post subject: Reply with quote
I'm down around Charlotte....
Well this sucks... I just boxed up all my spare stuff and put things on shelves and I can't find the damn jets. Evil or Very Mad I'll find them once I remember what the hell I did with them. Confused
I did however find the receipt. I ordered 55 and 60 idles so that tells me they came with 52 and I ordered 140 and 145 mains which tells me they came with 135. I originally thought rich but I think they were actually lean out of the box, which may coincide with you stumble on accel. Also thinking about it more I think I ended up with a 55 idle and a 140 main. My air correction jets were 1.60 out of the box.
This is a little interesting since the idle seems a step up from what usually comes with them and the main a step down.
RodneyW wrote:
Thanks for the suggestion. My idle out of the box was 55 and main was 127.5.
The 55 idle makes a little sense but the 127.5 mains seems a little on the lean side. I'd try bumping the mains up and see how it reacts. I'd also check and make sure the air jets are 1.60. Also when you say it does ok on hard accel, does it sputter at all when full throttle or is it smooth all the way after you get past that spot on accel?
The overall good news is that all the Weber 34ICT info you can get about jets on the web and here in the performance engine forum works for the EMPI's That's what I remember starting with when I did mine.
Also if you can get your hands on an A/F ratio meter it will tell you what the spot is on accel. I suspect it's a lean spot but that would tell you. You are more than welcome to come down here and use mine but it's a haul. Smile
vwfye
vwfye is offline
PostPosted: Mon Nov 21, 2011 5:41 pm    Post subject: Reply with quote
are these the 34s that CB sold for the bus that come with chokes? if so, there are a couple issues... the venturies are TOO small and the short linkage tends to have issues with binding if the plastic guide bits are cracked or missing.
contact me off list if these are the carbs and i'll tell you what i did to make them work well w/ the 'dreaded' 009.
64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK"
RodneyW
RodneyW is offline
PostPosted: Tue Nov 22, 2011 9:57 am    Post subject: Reply with quote
Working backwards ... Thanks fye, but they are EMPIs.
Mx, I am quite familiar with the Queen City ... Go Panthers; my mom lives in Pineville. I'd taking you up on your help, but driving there appears to be the issue.
CB's jetting chart suggests the Weber 34s are 52.5/130 out of the box. I was a bit surprised to be told mine were 55/127.5 out of the box.
My VW guy has the car so I am limited as to what more I can tell you. It will be next week before we start playing around with the new jets. I'll post an update for those who come along behind me.
vwfye
vwfye is offline
PostPosted: Tue Nov 22, 2011 11:35 am    Post subject: Reply with quote
The EMPIs are very similar. Let me know.
1974 Ghia "PUK"
toddgsanford
toddgsanford is offline
PostPosted: Tue Nov 22, 2011 8:54 pm    Post subject: Reply with quote
the 34 ict I had once upon time did not have the balance tube and would not synch for crap either.
ditched them
Pierce manifolds I have used fo rjets and have found to be a pretty good supplier.
have dcnfs on my notchback and they were tricky to get set up but once they are dialed in sweet
Page: Previous  1, 2
Page 2 of 2
