joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Thu Nov 24, 2011 9:09 am Post subject: springs |
springs on shocks puts to much load on to the shock mount. I have go westy on my van love them. I have a westy but it is only a tin top. So not to much weight , the ride is great. 1 vote go westy. thought I would add no stability problems, Actually I think its better in side winds. Go Westy 2 inch lift. _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Thu Nov 24, 2011 9:40 am Post subject: |
Aside from ride quality at the loaded end of the travel on the springs, has anyone that has lifted their vans had issues with them being too high, and feeling tippy or less stable? I'm interested in lifting mine when I add a Peloquin, but don't want to create an unstable monster....? _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
mwsnow Samba Member
Joined: November 13, 2007 Posts: 266 Location: Alton, NH
Posted: Thu Nov 24, 2011 7:44 pm Post subject: |
I will never buy 2WD lift springs again. I have the Syncro.org/Van Cafe springs, and do not like the effects on handling. The added height does make if feel less stable, especially in strong winds. The springs are on the stiff side for the available shocks. Even the Bilstein HD shocks are marginal for these springs. They begin sagging in the rear very shortly after installation. Mine are shimmed with cutting board circles to equalize the height at all four corners. I would really like a set of stiffer stock-height springs that are purpose-built for a diesel Westy with its extra-heavy left rear corner. |
dubbified Samba Member
Joined: March 03, 2010 Posts: 1406 Location: Redmond, WA
Posted: Thu Nov 24, 2011 8:22 pm Post subject: |
BlackDogVan wrote: |
I installed the GW springs a while back and absolutly love them. Other than the ride quality one of the best benefits for diesel conversion types is they allow large enough tires to be installed to put a TDi or AAZ in the perfect rpm range without any costly tranny mods. (225-70-17's to be exact & no they don't rub & yes I do have 3/8" spacers up front, 1/4" out back)
One question I have for anyone who has them... Every now & then over a nasty speed bump at parking lot speeds the shock tops out making a nice deep bang noise. I have stock rear shocks & HD Bilstens up front. I know the cure is probably bilstens in the rear, i'm just wondering if anyone else has experienced this. It is a transporter & I imagine a westie's added weight would make a difference. |
I have freshly installed Gws with the balljoint spacers.
First couple speedbumps.. I have noticed this bang.
and I'm not talkin that rendition of "she bangs" by William Hung..
I'd worried that something ill could occur with that level of force on various suspension components...
Perhaps I need new hydraulics.
It is very lifted though. |
r39o Samba Polizei
Posted: Thu Nov 24, 2011 9:01 pm Post subject: |
dubbified wrote: |
First couple speedbumps.. I have noticed this bang. |
Likely the shocks are bottoming out. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Thu Nov 24, 2011 9:59 pm Post subject: |
I had a problem with this too. Check that your shocks are *tight*. I had this horrible noise for 2-3 days before I could check. One of the shocks, at the top mount, took half a turn to make it *tight*. FYI _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
SSWesty Samba Member
Joined: August 20, 2008 Posts: 732 Location: Bellevue
Posted: Thu Nov 24, 2011 10:23 pm Post subject: |
I haven't noticed any stability issues that concern me with the GoWesty lift springs and Bilstein HD shock combo. I like the extra height for off-road needs and enjoy the higher ride. If I were to do it again I'd do the same combo over again. GoWesty has the 15% off this weekend, not sure if it applies to springs though. |
chazmataz Samba Member
Joined: October 10, 2010 Posts: 9 Location: Estacada, Oregon
Posted: Thu Nov 24, 2011 11:00 pm Post subject: |
i've had the GW 1.5 2wd lift springs in for over a month now and love them. in my opion it made my van more stable then it was with the old springs. FYI, my van is an 86 full camping westy w/175,000 plus miles. i like how high it rides for future off pavement driving and camping it also made the 215/75-15 goodrich a/t not hit the fender wells as before. |
Posted: Sat Nov 26, 2011 7:45 pm Post subject: |
I just cant get enough of them..
Not that I want my suspension too rigid.. but I do want some sways and all urethane too.
Yea on the hydraulics, they're very tight as far as how new they are.. they came from the PO. Unknown. I had intended to proactively replace them in the spring. |
TristanJP Samba Member
Posted: Mon Nov 12, 2012 1:51 pm Post subject: GW zero lift vs 1.5" lift vs VC 2wd springs |
It looks as though this thread hasn't been written on for some time. I've read all 4 pages currently available and dating back to 2008or9 and I'm guuessing some of the products have changed. Pricing appears to be lower than one quote I saw on this thread.
The reason I'm writing is because I did the unfortunate thing of lowering my van, far too low! I'm now interested in purchasing new springs. I still have the original Westy springs and the cheap side of me says just put those back in but I'm guessing they are likely saggy.
I'd like to get maximum lift out of my Westy, for logging roads and such, but still need it to fit in to my garage as well as others found here in Vancouver.
Can anyone comment on the current springs offered by gowesty and vancafe?
Also, if you can tell me what springs you are running, rim size and over all roof height I'd greatly appreciate it!
I'm currently running 16" rims w low profile tires and will probably swap them out for something more rugged.
Thank you in advance.
Tristan |
Posted: Mon Nov 12, 2012 2:00 pm Post subject: |
I was just looking up this thread when Tristan posted ~
I am also in the market to get a little lift on the '84 westy and have considered the GoWesty 1.5" lift for 2WD. This thread among others have said the VC springs are too soft...
Another option that has been recommended is to use syncro rear springs, and '85 westy front springs. I've considered going this way since the GoWesty springs have gotten less than stellar reviews, especially for heavier westys with conversions, but I too am concerned that I would just be trading one set of '84 worn out springs for another set of '85 worn out springs...
Anyone with experience with this option? How worn out and saggy do the springs get? _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
madspaniard Samba Member
I have the most recent version of the Van Cafe (syncro.org) springs.
There is a lot of info here, especially towards the end.
http://www.thesamba.com/vw/forum/viewtopic.php?t=499853&highlight=suspension
I can give you more info about my particular set up if needed but that thread contains most of it. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Mon Nov 12, 2012 2:03 pm Post subject: |
tarandusVDub wrote: |
Not the case (so far) for the newest version that I have installed in my westy. If something, they fall on the stiff side. _________________ 1991 Westy auto w/ Peloquin TBD
heidi85ho Samba Member
Joined: October 17, 2009 Posts: 298 Location: Williamsburg,Virginia
Posted: Mon Nov 12, 2012 3:38 pm Post subject: |
I have the newer synco.org springs, koni shocks, and nokian tires. I could not be happier. Stiff enough to handle a fully loaded camper in strong winds at highway speeds, comfortable enough to run around town with guests. _________________ 85 westy-1.9-standard trans, FAS GenV 2.0 |
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Mon Nov 12, 2012 5:05 pm Post subject: |
Madspaniard, which VC springs do you have? My 86 Westy has stock springs with Koni shocks. I like the ride, but wouldn't mind better handling and a slightly lower stance (my Westy just, and I mean just, clears my garage door opening). |
Posted: Mon Nov 12, 2012 5:21 pm Post subject: |
911pickup wrote: |
these ones
http://www.van-cafe.com/home/van/page_837_533/2wd_springs.html
Their latest version came out in late June and I instelled them shortly after.
From the other thread
madspaniard wrote: |
No affiliation to vanCafe or Syncro.org, just chasing my suspension nirvana here.
As far as I know, what has changed from the previous version of these springs is:
front springs: thicker spring wire, same spring rate
rear springs: slightly stiffer spring rate
The fronts are hot wound, the rears are cold wound and made of chrome silicon.
I have Knoni shocks and 15" Nokian WRC tires _________________ 1991 Westy auto w/ Peloquin TBD
Love My Westy Samba Member
Posted: Mon Nov 12, 2012 10:39 pm Post subject: |
911pickup wrote: |
these ones
I have Knoni shocks and 15" Nokian WRC tires |
These are the same springs I installed this spring. I have Koni Shocks with 15" wheels and 215 75 15 BFG's. I had to add a couple of spacers to the top to the front shocks to keep the BFG's from hitting the wheel well. I also have ADDCO Sway bars front and rear. My van handles great. The VC springs are not to soft, and for the first time since I have owned it I can ride along behind a Semi truck without being blown all over the road.
It definitely is taller than stock but not as high as the 1-1/2" lift springs.
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Tue Nov 13, 2012 9:15 am Post subject: |
I'm doing a Subaru conversion soon, likely 2.5.
Given the extra weight, can I use GW 2wd lift springs in back with spacers (?), or should I use their 4wd lift springs instead? _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Tue Nov 13, 2012 9:21 am Post subject: |
I've had the same question with mine. I have an '84 with a 2.5l conversion. Small Car says that it is approximately 100# heavier. GoWesty advises try the 2WD lift springs first, and then if it sags in back, put in spacers.
I think the 4WD would be too high regardless and you'd have to make other changes to your front end to deal with it... _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
Nuthin2It Samba Member
Joined: December 31, 2011 Posts: 306 Location: Marietta, GA
Posted: Fri Nov 23, 2012 2:55 pm Post subject: |
I'm looking for springs for my 1985 camper. In this thread on 1/8/2008, Christopher Schimke wrote glowingly of GoWesty's cold wound springs over the competition's hot wound springs. GoWesty's site now says their springs are "ultra-modern, hot wound" springs. Are hot wound springs now considered better or were the cold wound springs just too expensive? _________________ 1985 Westfalia 15 degree EA288 Boxeer |
