SP SinglePort Heads P&P
Page: Previous  1, 2
xavi_242
xavi_242 is offline
PostPosted: Sat Nov 26, 2011 6:52 am    Post subject: Reply with quote
3 anlge valve job is what it's going to be happening, that's for sure.
I'm going to run a CB 2232 cam and a 8 CR...
http://cbperformance.com/catalog.asp?ProductID=1244
1967 Split SO-42 Dormobile
ralf
ralf is offline
PostPosted: Sat Nov 26, 2011 7:00 am    Post subject: Reply with quote
Sounds good, for the cam and comPression , it looks like its gona be a decent street engine Smile just do a few more clean up on the intake , more so on the inner walls of the intake coming from the chamber
This will naturally shape the divider in a more profiled manner but dont take too much material out Smile
Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk
xavi_242
xavi_242 is offline
PostPosted: Sat Nov 26, 2011 9:06 am    Post subject: Reply with quote
Where are you exactly talking about? the guide side wall? Or the one that towards the center an joints the other intake duct?
Thanks!
ralf
ralf is offline
PostPosted: Sat Nov 26, 2011 9:38 am    Post subject: Reply with quote
Opposite the bowl (guide side wall) the side that joins the other port , clean it up and contour it from the chamber side
xavi_242
xavi_242 is offline
PostPosted: Sun Nov 27, 2011 1:28 pm    Post subject: Reply with quote
I just worked there today... my 'entrada Ășnica' doesn't looks as nice as yours, though.
BTW I managed to enlarge the intake to 32mm and I'll stop here. Embarassed
Looking fordward to start with the other head, then get it oppened for 90,5s, then worked on the combustion chambers and then the 3 angle valve seat job... Very Happy
xavi_242
xavi_242 is offline
PostPosted: Wed Apr 01, 2015 12:53 am    Post subject: Reply with quote
so... after a loooong time I took again this project and took odd the heads from the shelf (they where literaly part of our book shelf at home) and started the work again.
Got the head from the machine job, now the 90,5s just slip in very smooth Wink
This easter holidays I'll finish the porting job and then the 3 angle valve job...
more to come!
FreeBug
FreeBug is offline
PostPosted: Wed Apr 01, 2015 1:28 am    Post subject: Reply with quote
remember, the exhaust is like on a dual- port, so to keep an interesting inlet to exhaust ratio, concentrate your efforts on porting the intake. Exhaust maybe just polish to reduce heat absorption, don't over-port it.
Alstrup
Alstrup is offline
PostPosted: Wed Apr 01, 2015 1:58 am    Post subject: Reply with quote
Have you assembeled the case yet?
- I have used the 2232 in dual carbed sgl port engines a couple of times. I found that it provided good torque, but the engines were a bit short breathed, like 4300 rpm, - end of story. So I decided to go 2239 on the next build, which - did - create a slightly rough idle, but gave me more power above 4000 rpm.
Depending on what youtre after, you might want to take that into consideration.
T
xavi_242
xavi_242 is offline
PostPosted: Wed Apr 01, 2015 3:10 am    Post subject: Reply with quote
T
case is still to close. I'm looking for low end torque to push the bus from low revs. Don't planning to over rev over 4000...
thanks thou!
mark tucker
mark tucker is offline
PostPosted: Wed Apr 01, 2015 12:10 pm    Post subject: Reply with quote
get a set of good twin port heads.scat has some prostreet heads that are midely ported and ready to go, perfect for this type of engine.
xavi_242
xavi_242 is offline
PostPosted: Tue Apr 07, 2015 1:53 am    Post subject: Reply with quote
I want to keep the SPs because I want to keep the SP EMPI manifold for the Zenith 32 NDIX carb...
xavi_242
xavi_242 is offline
PostPosted: Tue Apr 07, 2015 2:16 am    Post subject: Reply with quote
marked the inner cylinder walls on the heads
then draw the area to unshroud
it took me one hour per chamber... tough work!
and the final result, note that I am very conservative...
BTW on the exhaust side of the right chamber, not the small scratch from the dremel tool. There's half of the sealing surface intact, the other half is scratched, not too deep, noticeable, though.
My plan was so just put some fine lapping compound on the cylinder sealing surface and rub a little bit the cylinder against the head, just to smooth it a little bit. I was planning to do that on all 4 cylinders, not just on the scratched one.
What do you think?
Thanks!
xavi_242
xavi_242 is offline
PostPosted: Mon Apr 13, 2015 6:36 am    Post subject: Reply with quote
finished the porting work after removing the valve guides...
intake:
exhaust:
Now time for the guides to go in... Rolling Eyes
Page: Previous  1, 2
Page 2 of 2
