Time for a rear sway bar?
Buellistic
Buellistic is offline
PostPosted: Sun Dec 04, 2011 10:06 am    Post subject: Time for a rear sway bar? Reply with quote
My bug has always been a joy to drive in the winter because I can go take it out and slide around large parking lots.
Last night I tried it and I was getting excessive understeer somehow... Aside from the bigger engine in the rear, I changed all 4 tires to taller, slightly wider ones. That's all that has changed.
Where did my sliding go?! :p
I'm thinking that I could fit a rear sway bar and get my oversteer back. I really don't handle understeer well... not even in videogames! So, is it time to fit a rear sway bar or is there something simpler I can do?
(As an aside, anyone on here should get a hold of Gran Turismo 4 and drive the 49' beetle with all the upgrades/some suspension tuning)
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sun Dec 04, 2011 10:38 am    Post subject: Reply with quote
Easiest thing to do is try different tire pressures.
If they are radials, lowering tire pressure can make it easier to slide tires on dry pavement.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
DarthWeber
DarthWeber is offline
PostPosted: Sun Dec 04, 2011 11:48 am    Post subject: Reply with quote
Adding a rear sway bar will increase understeer.
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
mark tucker
mark tucker is offline
PostPosted: Sun Dec 04, 2011 11:56 am    Post subject: Reply with quote
or ,put the old tires back on.old=hard,hard=easy to slide.
UK Luke 72
UK Luke 72 is offline
PostPosted: Sun Dec 04, 2011 1:14 pm    Post subject: Reply with quote
really? thought the drifters braced the rears up and did very little to the fronts?
DarthWeber
PostPosted: Sun Dec 04, 2011 1:50 pm    Post subject: Reply with quote
Drifters aren't racers (my opinion), they aren't concerned with going fast through corners and getting the best handling. Any book on road racing or chassis set up will back up what I said. It's all about achieving a good balance between front and rear anti-roll bars, springs and tire pressures, among other things.
Altema
Altema is offline
PostPosted: Sun Dec 04, 2011 2:35 pm    Post subject: Reply with quote
Agree 100%. By larger engine, do you mean heavier? If so, that or the new tires would be most likely. Some tires have more rounded shoulders than others which will affect breakaway in snow.
Paul
modok
modok is offline
PostPosted: Sun Dec 04, 2011 2:51 pm    Post subject: Reply with quote
on slippery surfaces like loose gravel and snow, our cars often understeer
The vehicle does not have enough grip to lean enough for the sway bars to be effective, so the balance on snow is pretty much all about the tires.
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sun Dec 04, 2011 3:04 pm    Post subject: Reply with quote
X100
its just show boating.
Real speed = traction
Bikerchris
Bikerchris is offline
PostPosted: Sun Dec 04, 2011 6:40 pm    Post subject: Reply with quote
He didn't say he was drifting as a "sport". He's just having some fun in a parking lot. Geez.
DarthWeber
PostPosted: Sun Dec 04, 2011 6:58 pm    Post subject: Reply with quote
Me==> Very Happy What I said==> Buellistic's thought of adding a rear sway bar would have just made a bad situation worse. I merely wanted to make him aware of this so he wouldn't spend money on something that wouldn't help him have fun in a parking lot. OK?
Bikerchris
PostPosted: Sun Dec 04, 2011 7:15 pm    Post subject: Reply with quote
First your unsolicited opinion
Agreed on this though. I'm sure he appreciates the help.
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Sun Dec 04, 2011 7:23 pm    Post subject: Reply with quote
Actually, everything is solicited here.......if you ask a question in the samba be prepared to get an answer that you may not like......
And I tend to agree.....drifting is a bit silly.....kind of fun to watch, but silly......the newer wider and taller tires are keeping you from sliding around......take it as a sign that you should protect your car from bad driving......maybe save you from an accident down the road.
I'm Chris and the above is what I said Wink
Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc
Bikerchris
PostPosted: Sun Dec 04, 2011 7:28 pm    Post subject: Reply with quote
Lol. That's true. It's part of what makes this forum entertaining. I happen to agree with you and Darth, drifting is silly.
fivelugshortaxle
PostPosted: Sun Dec 04, 2011 7:29 pm    Post subject: Reply with quote
Lol! I think the poster just wants to be able to do donuts in the parking lot......drive that thing nice Buellistic........how did the race with your brother go?
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Buellistic
PostPosted: Sun Dec 04, 2011 8:55 pm    Post subject: Reply with quote
Oh yes, don't get me wrong. I don't look at drifting as a form of race or even something worth competing in. I just like sliding around from time to time when the weather is a little wet. I wont do it in high-grip (dry pavement) situations because I doubt my transmission could really handle that.
I would think stiffening the rear would transfer cornering pressure from the rear to the front inner tire... But then again, I haven't read any books.
FiveLug, I actually could keep up with my brother. He was a tad faster, but not by much. In a race around a track his HP advantage would be null. So there you have it, RC makes heads that unlock enough power to keep a 1776 competitive with a 1915.
fivelugshortaxle
PostPosted: Sun Dec 04, 2011 8:58 pm    Post subject: Reply with quote
Almost makes you wish you had him throw in bigger valves and you put in a bit bigger cam...Lol! But that's pretty cool for you......you still got bragging rights that you kept up with his big bad 94's....
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Buellistic
PostPosted: Sun Dec 04, 2011 9:09 pm    Post subject: Reply with quote
Naw, the driveability of the engine is about perfect, honestly. I think I'll fit up some higher ratio rockers eventually and call it finished Smile
fivelugshortaxle
PostPosted: Sun Dec 04, 2011 9:12 pm    Post subject: Reply with quote
Ha ha ha ha! That's one thing about a VW, partner......they're never finished!
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Buellistic
PostPosted: Sun Dec 04, 2011 9:21 pm    Post subject: Reply with quote
HAH! Yeah, okay, I meant THIS ENGINE is finished. I'm still going to redo the entire interior, the wiring, the TRANSMISSION, and so many other things eventually.
