Made my own 3rd brake light.
quartermilecamel
quartermilecamel is offline
PostPosted: Wed Dec 21, 2011 1:46 pm    Post subject: Made my own 3rd brake light. Reply with quote
Waiting for santa to drop off funky green. I can wish can't I????
jeremyrockjock
Samba Towbar Builder
jeremyrockjock is offline
PostPosted: Wed Dec 21, 2011 2:11 pm    Post subject: Reply with quote
I am putting some led strip lights in my corner windows. I have been rearended twice in the 15 window and had a few close calls where someone skids to a stop up on my ass. The factory lights are just not bright enough. I just hate to have some bright non factory lights on there but better to be safe.
Why buy what you can build.
sub-hatchtim
sub-hatchtim is offline
PostPosted: Wed Dec 21, 2011 2:14 pm    Post subject: Reply with quote
I have a 6in red unity spotlight mounted on the rear of my bus
it gets the job done well
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
LittleThunder
LittleThunder is offline
PostPosted: Wed Dec 21, 2011 7:40 pm    Post subject: Reply with quote
I used an old 67 bug back up light with a broken piece of red reflector stuck inside.
[img]
[/img]
KevinAlbrecht
Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota
KevinAlbrecht is offline
PostPosted: Wed Dec 21, 2011 8:19 pm    Post subject: Reply with quote
[img]
[/img]
Is that 'Please pass' sign lit up? That's dope.
Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
Click to view image
tanhis
tanhis is offline
PostPosted: Wed Dec 21, 2011 11:24 pm    Post subject: Reply with quote
[img]
[/img]
I think that you can still buy the plastic red lences from hella.
-58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton
quartermilecamel
PostPosted: Thu Dec 22, 2011 12:00 am    Post subject: Reply with quote
yeah I thought of using a reverse light but I wanted something that you just couldnt mistake for .......is that thing on or not. That sign isnt even at full voltage yet. I used it as a flashlight inside and outside.
Wolffeather
Wolffeather is offline
PostPosted: Thu Dec 22, 2011 8:17 am    Post subject: Reply with quote
I Really like that "Please Pass" Light too. Sometimes I get people that WONT pass because they're checking out my Bus, then when they do pas it turns into a photo OP. Any more info on the Please Pass light ?
'62 Bus named Biscuit
'62 Bus (go-cart) named Baby Biscuit
'57 356 named Wind
'67 Beetle named Blue Bear
DaveB
DaveB is offline
PostPosted: Thu Dec 22, 2011 9:45 am    Post subject: Reply with quote
Dave Brooks
USAF Retired
1966 Custom Camper
Emeritusx
Emeritusx is offline
PostPosted: Thu Dec 22, 2011 10:05 am    Post subject: Reply with quote
I like the VW 1/4mile... Here is my version...:
82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠
Rob Whitey
Rob Whitey is offline
PostPosted: Thu Dec 22, 2011 10:35 am    Post subject: Reply with quote
I like it. Will it work on 6 volt? Can you post how you did it and where you purchesed the led's?
Thank You
-Tim-
zozo
zozo is offline
PostPosted: Thu Dec 22, 2011 11:02 am    Post subject: Reply with quote
I went BIG with mine. I cringed every time I hit the brakes, just waiting to get slammed. It's not too noticeable when it's not lit, and it's easily removed without having drilled holes or done any other mods.
jeremyrockjock
PostPosted: Thu Dec 22, 2011 12:54 pm    Post subject: Reply with quote
Yep Thats how I am doing mine in the corner windows on the jail bars. I had some in the center of the trim but it was hard routing the wires and then one side burned out.
quartermilecamel
PostPosted: Thu Dec 22, 2011 1:59 pm    Post subject: Reply with quote
Thank You
-Tim-
I purchased leds from radio shack...at 2 somethign a bag of 2 Evil or Very Mad Gave up on them and looked on ebay. Under usa seller theres a guy that sells 10mm red ones for......get this..........100 for 9.95 Very Happy Im running 12 volt so, I put 5 leds in series for 10 volts then I will use a regulator to drop the remaining voltage. Yes you can make yours to work from 6 volts. Just use less leds in series. Or, use a resistor with every led. The average led is 2 volts @20ma. The regulator is for when your running the bus......to account for the alternator or generators higher than battery output voltage. If you put 6 leds together and dont regulate (lm317t) or use a resistor, Im guessing that when you start the bus......your leds will have a much shorter life due to the overvoltage. Leds arent like regular incandescent auto light bulbs, they are not as resistant to overvoltage.
quartermilecamel
PostPosted: Thu Dec 22, 2011 2:04 pm    Post subject: Reply with quote
Yeah your the one with that huge strip, I just couldnt remember who had it.. Laughing I looked but couldnt find it online so I decided to make my own. The plus side is if it fails or an led burns out.....I can replace it easily.
This whole idea was fueled by that 58 bus that got creamed. I might even add more leds........not sure yet. The picture was taken while it was running off a 9 volt battery. Testing to continue until I can practically light lawns on fire with it Laughing
dubstar
dubstar is offline
PostPosted: Thu Dec 22, 2011 6:34 pm    Post subject: Reply with quote
I made mine out of a reverse light, a type 1 bracket, and red reflector tape...
straightening the bracket:
bending the bracket:
adding ground wire:
essentials:
red tape used for lens...looks fairly good, but might redo it or look for an actual red lens:
here it is captured cruising around bus central on long island:
1963 Type II Kombi
1977 Type I Fuel Injection
http://instagram.com/john_aka_dubstar/
http://web.stagram.com/n/john_aka_dubstar/
"you could transport really tall things too, like a giraffe"
GarryA
GarryA is offline
PostPosted: Thu Dec 22, 2011 8:46 pm    Post subject: Reply with quote
Red lenses are available for the VW reverse lights.
I picked up a few at the 2010 Classic.
The were new in the box, glass and a perfect fit.
They were only $1 each.
Where's Garry
dubstar
dubstar is offline
PostPosted: Thu Dec 22, 2011 8:47 pm    Post subject: Reply with quote
red glass ones are expensive around here and online...much more than $1
you would have to look hard to see that I have red tail lens tape inside the clear glass on mine
1963 Type II Kombi
GarryA
GarryA is offline
PostPosted: Thu Dec 22, 2011 8:52 pm    Post subject: Reply with quote
Just saying. I was surprised at the price as well. The guy had boxes of them.
Where's Garry
dubstar
dubstar is offline
PostPosted: Thu Dec 22, 2011 9:05 pm    Post subject: Reply with quote
sounds like a great deal...I'll keep looking around
1963 Type II Kombi
