Bleeding Brakes!
cj1971
cj1971 is offline
PostPosted: Fri Dec 09, 2011 8:02 am    Post subject: Bleeding Brakes! Reply with quote
Need a brake expert please!??..........ive replaced all wheel cylinders,master cylinder and brake hoses.
Tried today to bleed the brakes........pumped the air out until the fluid flowed,3 times but no joy getting a pedal??
Could it be that the old stock Master Cylinder isnt any good????or do i have adjust pedal to master cylinder???
Your thoughts please gentlemen
my59
my59 is offline
PostPosted: Fri Dec 09, 2011 8:11 am    Post subject: Reply with quote
NOS master? VW had a time limit about keeping brake components on the shelf becuase of rubber getting old. You may need new rubber components.
Did you fill master with fluid prior to install (ie bench bleed) as the system is not designed to pump air.
You might try to gravity bleed the system- open the bleeder valves and keep the reservoir full and leave overnight
Dont adjust the pedal rod just yet
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
drscope
drscope is offline
PostPosted: Fri Dec 09, 2011 9:26 am    Post subject: Reply with quote
Are the shoes adjusted out against the drums? If not, you NEVER will get a pedal!
Motorhead55
Motorhead55 is offline
PostPosted: Fri Dec 09, 2011 10:17 am    Post subject: Reply with quote
DITTO
2007 Dodge Cummins Diesel 4x4 6spd stick
1939 WILLYS pickup
1967 Triumph Tiger Cub
vwbrewer
vwbrewer is offline
PostPosted: Sat Dec 10, 2011 5:26 am    Post subject: Reply with quote
Are the e-brake cables connected?
1957 Oval Rag
ozarkbaha
ozarkbaha is offline
PostPosted: Sun Dec 11, 2011 6:42 am    Post subject: Reply with quote
all hoses,must be very good and rubber inlet side, and you have to let the pedeal up very very slow or it will suck air from the piston side.your master cyl is prob good, its very aggravating but there is such a little line feeding the cyl and so much volume to all the wheels. hope this helps. ive been there
drscope
drscope is offline
PostPosted: Sun Dec 11, 2011 9:15 am    Post subject: Reply with quote
That should have NO effect on bleeding the brakes.
So how did you make out with this thing? Any Luck?
cj1971
cj1971 is offline
PostPosted: Sun Dec 11, 2011 9:51 am    Post subject: bleeding brakes Reply with quote
Thank you for your words...............think i may have to adjust shoes,the car was away a long time having welding work after i recommissioned chassis-so may have forgotten to adjust first!!! Embarassed
Fitted new master cylinder'wheel cylinders and hoses and most of brakes lines.........let you all know soon
Motorhead55
PostPosted: Sun Dec 11, 2011 10:46 am    Post subject: Reply with quote
Make sure that you have about 1/4-3/8ths inch free play at the brake pedal when the pedal is at the rest position. This allows the master cyl piston to open to the fluid port. The free play is adjustable at the brake pedal push rod.
1939 WILLYS pickup
cj1971
cj1971 is offline
PostPosted: Thu Dec 15, 2011 8:10 am    Post subject: Bleeding Brakes! Reply with quote
Well to answer all those who helped with a response-i've adjusted the shoes lovely,nice handbrake BUT still no joy pumping up the pedal,so i've ordered a 'new' ate master cylinder today.fingers crossed!!
Motorhead55
PostPosted: Thu Dec 15, 2011 12:11 pm    Post subject: Reply with quote
After you install the new master cylinder, Bleed it FIRST at the Master cylinder itself. Do that by having someone pump up the pedal and hold pressure on it. Loosen the top brake line fitting and bleed the air out. Also make sure that it has the right pedal free play also.
1939 WILLYS pickup
cj1971
cj1971 is offline
PostPosted: Fri Dec 30, 2011 12:24 pm    Post subject: bleeding brakes Reply with quote
Ok...........latest update,am i just the unluckiest person bleeding brakes???Bench bleed the new ATE master cylinder and fitted it..........but still not getting the pedal to come up-have actually got resistence and the lower end of the pedals travel.please help.
Motorhead55
PostPosted: Fri Dec 30, 2011 12:36 pm    Post subject: Reply with quote
Sounds like you might still need to readjust your brakes. at each wheel, turn the adjuster until it gets hard to turn. Then back off around 3-5 clicks or when the wheel turns with a LIGHT drag. When you do this with the adjacent adjuster at the same wheel, you might have to back off the previous one one or two more clicks.
Repeat this whit each wheel trying to get the adjusters up as far as you can but having a light drag resistance at the wheel.
When bleeding, are you still seeing air bubbles? If you replaced the shoes along with all the wheel cylinders, it is not uncommon to have kind of a spongy pedal until the shoes are seated in.
1939 WILLYS pickup
cj1971
cj1971 is offline
PostPosted: Fri Dec 30, 2011 12:43 pm    Post subject: Reply with quote
I adjusted brakes until the shoes(nos linings) were just rubbing....no bubbles.
Motorhead55
PostPosted: Fri Dec 30, 2011 2:11 pm    Post subject: Reply with quote
You have to go BEYOND "just rubbing" to seat the shoes in. Run the adjusters down until the wheel won't move THEN de-adjust to light drag.
Are you running a 19mm master cyl. or a 17mm master cylinder
1939 WILLYS pickup
cj1971
cj1971 is offline
PostPosted: Fri Dec 30, 2011 2:21 pm    Post subject: Reply with quote
Ive just fitted a brand new 19mm cylinder.........
Motorhead55
PostPosted: Fri Dec 30, 2011 4:27 pm    Post subject: Reply with quote
That is good. More volume per stroke.
1939 WILLYS pickup
my59
my59 is offline
PostPosted: Sat Dec 31, 2011 4:58 pm    Post subject: Reply with quote
You're going from RR to LR to RF and left front wheel last, right?
Double check the hard line seating into the master from the reservoir. I had a hellish time when I redid the whole system and it turned out the line was not seated and leaked out from there (and I assumed sucked air in as well). Once I got it seated it bled out ok.
cj1971
cj1971 is offline
PostPosted: Sun Jan 01, 2012 3:52 am    Post subject: Reply with quote
Oh yeasssss,rr-lr then rf-lf..........master cylinder has new bung in it from res,with no leaks!?
