Skip Laubach Samba Member
Joined: December 13, 2011 Posts: 237 Location: Elgin, Illinois
Posted: Fri Dec 30, 2011 8:19 pm Post subject: Cleaning method for Westy curtains? |
1984 Westy 19L WBXR Manual
Thought I might clean the curtains (Westy is new to me since July 2011), perhaps drop them at the local dry cleaners. Anyone used this method? Or hand washed them at home? Or in the home washer? I imagine that mine have not been cleaned, ever. They are not dirty, just feel a bit "tired/grimy". Please advise and thank you.
Skip |
whynotvw Samba Member
Posted: Fri Dec 30, 2011 8:29 pm Post subject: |
i have 87 westy, i just threw mine in the washer, came out really nice and clean. |
kamzcab86 Samba Moderator
Posted: Fri Dec 30, 2011 8:32 pm Post subject: |
Washing machine on gentle cycle using Woolite... cleaned up nicely. _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Dec 30, 2011 8:44 pm Post subject: |
Thank you. Two votes for the home washing machine, gentle cycle.
By the way, I did not do a conversion to a 19L engine (weight considerations). I meant to type "1.9L", original engine...but soon to be "looked at" by a machine shop.
Skip |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Fri Dec 30, 2011 8:49 pm Post subject: |
kamzcab86 wrote: |
Washing machine on gentle cycle using Woolite... cleaned up nicely. |
same here, infact over half of my interior got done this way. |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Fri Dec 30, 2011 9:25 pm Post subject: |
Don't forget your fabric softener.  _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
beagling Samba Member
Joined: December 31, 2007 Posts: 30 Location: Santa Cruz
Posted: Fri Dec 30, 2011 10:00 pm Post subject: |
Agree with comments above. They turn out really nice. YOu can tumble dry them on low heat too. _________________ 1989 Westy WBX 2.1 automatic |
windnsea Samba Member
Joined: May 07, 2008 Posts: 424 Location: Pasadena, CA
Posted: Sat Dec 31, 2011 12:39 am Post subject: |
I'd carefully handwash with woolite or dash dish soap. They may look okay, but the sun can weaken the weave and you'll find out after machine washing.
I'd then carefully rinse and lay out to dry. You can then iron them with a very low setting.
Why use softener and subject them to yet another chemical?
... just a few thoughts! |
morymob Samba Member
Posted: Sat Dec 31, 2011 5:38 am Post subject: |
Wife washed mine, all the stains-?- etc came out and look great. A bit of help= as u remove and in a corner not seen take a perm marker pen an number all curtains (matched the ties too),,makes re-install a snap, no looking/matching, remember where u start and go in a circle. |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Sat Dec 31, 2011 3:34 pm Post subject: |
Little realized fact about fabric and laundry. It's actual dirt that starts the rotting process. My Westy's were original, hadn't been done in decades and I did gentle wash full cycle with some soap, then I put them thru another complete cycle without soap so that they get rinsed well. Soap residue grabs dirt. Usually after a complete cycle they can be hung as they only need some air drying. Mine came out looking and feeling like new. I was amazed.
My point is rinsing well is very important to get rid of soap residue as it grabs the dirt and then time and sun do the dirty deed of rotting. I made all new curtains for the Riviera. Will probably do a yearly laundry on them unless otherwise needed. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
chojinchef Samba Member
Posted: Sat Dec 31, 2011 3:54 pm Post subject: |
I washed mine 5 times when I got the Thingamajigger.
Gentle cycle.
Line dried.
May be faded from sun, but at least they are not as crunchy as when I got them Van smells better too.
The one behind the stove actually stood up by itself. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
DAIZEE Samba Member
Posted: Sat Dec 31, 2011 4:03 pm Post subject: |
stand up alone laundry is a sure sign needs cleaning. Wasn't there an old expression that you didn't wash (? your underwear) until it stood up on the floor after hitting the wall? something like that  _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
Posted: Sat Dec 31, 2011 4:16 pm Post subject: |
OK, I'll wash gentle cycle. I like the wash once with soap, then again without soap. I'll let you know how it goes.
Won't be for awhile as next on the list are fuel lines, rear heater T's, etc., including an engine drop and a trip to an auto machine shop to have a look at my 65 compression on the two front cylinders.
Hopefully these issues will all come out ..."in the wash".
Skip
Elgin, IL
84 Westy 1.9L Manual |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 947 Location: Portland, OR
Posted: Sat Dec 31, 2011 10:48 pm Post subject: |
go one step further and take the covers off your mattresses. gentle wash, air dry. So much better.
Mark _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
Terry Kay Banned
Posted: Sat Dec 31, 2011 11:47 pm Post subject: |
Dirt can't hide from intensified Tide.
After you get the curtains, rear rug & matress cover all squeaky clean, blow some pimp oil inside of the Van--
She'll be ready for the long ride--- _________________ T.K. |
